My monitor image is all green? Think a DVI problem... - Page 2 - Overclock.net - An Overclocking Community
post #11 of 24 (permalink) Old 05-05-2005, 02:05 PM
Some call me... Bifford
BFRD's Avatar
Originally Posted by Atticus
I really hope it is the DVI adapter my dad has another DVI converter but that's XFX too, he bought an XFX dual DVI so he got two converters with it. Since he uses a DVI TFT I decided to steal a converter and dual screen. My dual screens look good coz I have two monitors which are exact same I got 'em next to eachother on my desk. Anyway you reckon it's worth a try with the other XFX converter?
The make of the converter really should not matter.
BFRD is offline
post #12 of 24 (permalink) Old 05-05-2005, 03:03 PM - Thread Starter
Atticus's Avatar
Rep: 7 (Unique: 4)
Yeah the only reason I made a point of the make was it says XFX on the converter and I've seen Belkin ones, etc. thought perhaps some were better quality than others. You'd expect XFX to be pretty good though.
Atticus is offline
post #13 of 24 (permalink) Old 05-05-2005, 03:08 PM
actualy some have all the pins and some have minimal pins in the dvi side but yah i dont think it matters the missing pins on those probibly arnt even used
SPHERE is offline
post #14 of 24 (permalink) Old 05-05-2005, 04:26 PM
DFA
i think its your monitor...my monitor does that too...
DFA is offline
post #15 of 24 (permalink) Old 05-05-2005, 04:29 PM
we already ruled that out dude but thx
SPHERE is offline
post #16 of 24 (permalink) Old 05-06-2005, 12:42 PM - Thread Starter
Atticus's Avatar
Rep: 7 (Unique: 4)
You guys think it could be that my monitor isn't DVI compatible? Or is DVI not a format just a method of connection if you get what I mean. Is DVI just a different type of video port and a converter will make it the same as a standard VGA or is it actually a different format?
Atticus is offline
post #17 of 24 (permalink) Old 05-06-2005, 12:50 PM
no thats not it ive used 20 year old monitord on a dvi adapter and its been fine
SPHERE is offline
post #18 of 24 (permalink) Old 05-06-2005, 01:00 PM - Thread Starter
Atticus's Avatar
Rep: 7 (Unique: 4)
Thanks that's a total relief I know I can keep both my monitors now, I'll rep you for that.
Atticus is offline
post #19 of 24 (permalink) Old 05-07-2005, 06:24 PM
OMG, i had same problem. There was a bent pin on the cable, try that. yeah
comrad is offline
post #20 of 24 (permalink) Old 05-09-2005, 03:29 PM - Thread Starter
Atticus's Avatar
Rep: 7 (Unique: 4)
But it does it on both monitors whichever is connected to the DVI and when either are connected via VGA tehy are fine...
Atticus is offline
