resetting monitor - Page 2 - Overclock.net - An Overclocking Community
resetting monitor
post #11 of 17 (permalink) Old 05-28-2005, 11:27 PM - Thread Starter
I wanna swear so bad right now....this is so ******* *** as ******* **** **** ****
demol1sh3d is offline
post #12 of 17 (permalink) Old 05-28-2005, 11:30 PM
Linux Guru
Rep: 484 (Unique: 264)
That is why you always want to buy quality brand name parts, my LCD has an autoadjust button that jsut saves me so much time.
Lostnhell is offline
post #13 of 17 (permalink) Old 05-30-2005, 07:27 PM
yea i had the same problem with one of my monitors cept it was like / / and curved on one side just keep playing around with any setting you see if not open your monitor up and check for a battery that you can take out
JUST DONT TOUCH ANY CAPASITORS OR ANYTHING LIKE THAT mabye try wearing rubber gloves to insulate your hands if you find a battery?
Hope I helped!!
tdunks is offline
post #14 of 17 (permalink) Old 05-30-2005, 07:56 PM
zokus's Avatar
Rep: 194 (Unique: 136)
Isn't there a button that will restore default settings, my monitor has one, and yes it's a CRT. The picture looks like a upsidedown and tilted 'U' that is crossed out like the no smoking signs. When you press it your monitor shakes and goes wacky, then settles out.
doh.gifNever argue with an idiot; they will bring you down to their level and beat you with experience.
zokus is offline
post #15 of 17 (permalink) Old 05-30-2005, 08:51 PM - Thread Starter
degauss...that doesnt reset for me. that just makes it jiggle\\
btw zokus that is a kickarse avatar.
post #16 of 17 (permalink) Old 05-30-2005, 08:55 PM
In the monitor menu you should have restore factory setting or default settings depending on your monitor...........if not just use the adjustments to fix it
ItsLasher is offline
post #17 of 17 (permalink) Old 05-30-2005, 09:00 PM - Thread Starter
thats the problem itslasher...whatever I do to oneside, it automatically does to the other. so I cant fix it and there is no reset button.....
