resetting monitor - Overclock.net - An Overclocking Community
resetting monitor
post #1 of 17 (permalink) Old 05-28-2005, 10:55 PM - Thread Starter
how do you reset a monitors settings, mine is all outta whack and I want to fix it so I can read it.
demol1sh3d is offline
post #2 of 17 (permalink) Old 05-28-2005, 10:59 PM
Linux Guru
Rep: 484 (Unique: 264)
I don't know how to reset the monitor settings besides no using it for a year, just post what seems to be off in the settings and we will try to help you through it.
Lostnhell is offline
post #3 of 17 (permalink) Old 05-28-2005, 10:59 PM - Thread Starter
it looks like this...
post #4 of 17 (permalink) Old 05-28-2005, 11:01 PM
PROBN4LYFE's Avatar
Rep: 603 (Unique: 367)
You could try reinstalling the driver for it or finding a new one...that helps sometimes
PROBN4LYFE is offline
post #5 of 17 (permalink) Old 05-28-2005, 11:06 PM
Linux Guru
I have seen that before, but I can't remember the setting.
I beleive it is the vertical arc settings for your monitor itself, do you have a setting to play with that is labeled by two horizontal lines joined by two inward arcs?
post #6 of 17 (permalink) Old 05-28-2005, 11:12 PM - Thread Starter
no....GOD!! I hate myself...this is unfixable.....
post #7 of 17 (permalink) Old 05-28-2005, 11:15 PM
Linux Guru
well maybe, I mean if the arc is only on one side of the screen it could be that a controller chip in the monitor went out. try leaving it unplugged for a couple of hours and see if that resets the monitor(cheap ones don't hold a charge for long).
post #8 of 17 (permalink) Old 05-28-2005, 11:22 PM - Thread Starter
how long does a good one hold one for...
post #9 of 17 (permalink) Old 05-28-2005, 11:24 PM - Thread Starter
well their is a controller but it does it to both sides at once....so its impossible.
post #10 of 17 (permalink) Old 05-28-2005, 11:25 PM
Linux Guru
WEll, i have a pretty good 21" Dell CRT downstair thats I tested and it retained the setting (and charge) after 1 months of not being plugged in.
