Vid Card/Mobo problem. Easy Reps! - Page 2 - Overclock.net - An Overclocking Community
post #11 of 16 (permalink) Old 05-30-2005, 04:27 PM
Linux Guru
Rep: 484 (Unique: 264)
Originally Posted by UberN00B
Well, just letting you guys know. I find it confusing.. =/.. I tried booting it 10 times, Didnt work, 11th time, It worked, but then i had to restart to check.. next 9 times, never booted.. (Booting as in.... Turning it on and getting to the page where u can go to bios.. Moniter keeps saying, PLEASE CHECK SIGNAL when no boot.)
My guess it that you did fry the vid card, go ahead and test another card in the same slow and see it if works.
Lostnhell is offline
post #12 of 16 (permalink) Old 05-30-2005, 04:27 PM
PROBN4LYFE's Avatar
Rep: 603 (Unique: 367)
You've gotta lower some clocks and volts...homie....
put it back the way it was for 24 hrs...leave it on all night at that...next day get it burnin' again
PROBN4LYFE is offline
post #13 of 16 (permalink) Old 05-30-2005, 04:31 PM
PROBN4LYFE's Avatar
it might be a driver issue...reinstall is all I can give you dawg...
post #14 of 16 (permalink) Old 05-30-2005, 05:06 PM - Thread Starter
Retired Staff
UberN00B's Avatar
Rep: 344 (Unique: 259)
Uhm, not sure you understand the situation. Cant see ANYTHING on the screen when turned on. Thus, i cannot boot up and Lower clocks or update drivers or anythin.
UberN00B is offline
post #15 of 16 (permalink) Old 05-30-2005, 07:22 PM
Sorry to say this but i think yopu broke something off. Does your motherboard have onboard video or do you have a spare video card? If yes use it to see if it truly if the video card is busted. If that doesnt work you might have accidentally shocked the motherboard sending it down or any other component might have got a little shock.
Hope I helped!!
tdunks is offline
post #16 of 16 (permalink) Old 05-30-2005, 07:26 PM
TRy reseating the GFX card and the monitor cable and I'd go the extra step and clear the CMOS with the jumper then try to boot
ItsLasher is offline
