New HDTV as second display problems! - Overclock.net - An Overclocking Community
post #1 of 11 (permalink) Old 12-16-2004, 04:31 PM - Thread Starter
KuipeDogg's Avatar
Rep: 4 (Unique: 3)
Yo hey peeps, I havent posted in a bit hows everybody doing?
I just got a JVC 30" Widescreen HDTV,
finally got it to run as my second display but it wont run as a clone [ony extended] and if i try to run games the dont boot, any Ideas?
If what I said was helpfull, or unhelpfull, or even just
slightly interesting EFFECT MY REP
*check out my system-click my profile
KuipeDogg is offline
post #2 of 11 (permalink) Old 12-16-2004, 05:16 PM
Rep: 461 (Unique: 275)
Games dont like dual displays, you might want to search for games that support them.
blob is offline
post #3 of 11 (permalink) Old 12-17-2004, 10:13 PM
RunningRioT's Avatar
Rep: 81 (Unique: 62)
there are mods for unreal, quake, and a few others, google them up.
FOLD for OVERCLOCK.net! GO TEAM! #37726
ADD ME A REP IF I HELPED YOU!
The X-Factor of AMD vs. Intel eXplained
L00K at my RIG and COmment!
RunningRioT is offline
post #4 of 11 (permalink) Old 12-17-2004, 10:33 PM
hmmm I'm just fine. I am loving my dual display (thanks again slow'puter). I can read people's IM's while "Killing the baddies" in Day of Defeat.
MrSmiley is offline
post #5 of 11 (permalink) Old 12-18-2004, 06:11 PM
Retired Staff
Burn's Avatar
Rep: 520 (Unique: 309)
can i dual disp 2 CRT's?
My CNC Mill Project
Originally Posted by CyberDruid
Burn + Electricty + Water =
But the man has the patience of a saint...
We cannot change the cards we are dealt, just how we play the hand.
--Randy Pausch
Current Best Benchmark
Burn is offline
post #6 of 11 (permalink) Old 12-19-2004, 12:15 AM
if ur fx5200 has a dvi adapter, just get a dvi-vga adapter.
post #7 of 11 (permalink) Old 12-19-2004, 09:32 AM
Retired Staff
Burn's Avatar
yeah, is there any performance gain from it? cuz i have it hooked up to the blue connector. will the dvi-vga adapter give me better results? also, can i dual setup 2 crt's with it?
My CNC Mill Project
--Randy Pausch
Burn is offline
post #8 of 11 (permalink) Old 12-19-2004, 07:10 PM
No, i wouldnt use the dvi-vga for just a single display on a crt.
because the video that comes out of the card is digital, then the converter would have to put it in analog.
then the vga is the same thing, except its better.
vga only for crt,
or adapter for dual display.
so for dual display
display 1 ------------- analog blue
display 2 ----adapter---dvi
post #9 of 11 (permalink) Old 12-19-2004, 07:28 PM
Retired Staff
Burn's Avatar
ooooh it makes sense now. so i hook up 1 crt to the blue vga, then another to the dvi using an adapter? i think i have it right... now will i get problems w/ recognizing the two displays?
vga only for crt,
so for dual display
My CNC Mill Project
--Randy Pausch
Burn is offline
post #10 of 11 (permalink) Old 12-19-2004, 07:34 PM
Retired Staff
adas's Avatar
Rep: 595 (Unique: 324)
nope, they both are recognized the same way, and work the same way, jjust depends how u put the displays to function
btw i send the card Atvkid ull get it on wednesday
adas is offline
