help redesigning the network and securing the edge (firewall, ips, ids) - Overclock.net - An Overclocking Community
post #1 of 2 (permalink) Old 08-23-2013, 07:01 AM - Thread Starter
Sparta's Avatar
Rep: 5 (Unique: 4)
My current network setup looks like the following:
ISP modem --> Cisco 2611xm --> managed 3550 switch --> vlans
Since I will be setting up a public facing web and email server, I decided that my network security needs improvement before they go live. I built a pfSense box which I would like to configure to perform Firewall, IPS, and IDS duties. I believe I have 3 options on its placement: before the router, after the router, or replacing the router with it. I would appreciate any insight and suggestions.
Thanks
Current setup details:
ISP modem:
Configured as a bridge just to perform the rj11 to rj45 hand-off
2611xm:
Routing
NAT
ACLs
basic firewall functions
3550:
layer 3 enabled
inter vlan routing
DHCP
ACLs
Vlans:
Guest wifi
private lan
private servers
Public servers (coming soon)
management PC (SNMP, Solarwinds, ect.)
Originally Posted by Le_Loup
Something about the # 2 alot, 2 items, #2, and the roman numeral II, and rep is also 2
AND a core "2" duo! DDR "2" sp2! So many 2's!!! Ahh attack of the 2's!
Sparta is offline
post #2 of 2 (permalink) Old 08-23-2013, 07:29 AM
beers's Avatar
Rep: 893 (Unique: 710)
You could probably just phase out the 2611XM at this point, the pfsense box would just end up routing packets between interfaces anyway, and you are already using layer 3 switching for inter-vlan routing.
beers is offline
