Running cabling inside my walls? - Page 3 - Overclock.net - An Overclocking Community
post #21 of 36 (permalink) Old 11-24-2015, 09:37 AM
cones's Avatar
Rep: 91 (Unique: 70)
Originally Posted by NKrader View Post
OP, I think you should train a rat to pull the wires.
Because, awesome.
That sounds like the only way so far.
cones is offline
post #22 of 36 (permalink) Old 11-24-2015, 07:36 PM
jgrote's Avatar
Rep: 3 (Unique: 3)
It takes too long to train them. Just hire someone that already has a trained rat.biggrin.gif
If you think this is far fetched, watch this: https://www.ted.com/talks/bart_weetjens_how_i_taught_rats_to_sniff_out_land_mines?language=en
The damned things are really smart, and easy to train.
jgrote is offline
post #23 of 36 (permalink) Old 11-25-2015, 02:07 AM
Senioritis Member
Lady Fitzgerald's Avatar
Rep: 522 (Unique: 329)
Ferrets are often used to route a pull string in conduit. They are far easier to train.
Jeannie
i7-3930k
ASUS P9X79 WS
MSI R7850 Twin Frozr 2GD5/OC Radeon HD 7850 2GB 256-bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX Support Video Card
Monoprice 1x2 powered HDMI Splitter
Kingston HyperX 32GB (8 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model KHX1600C9D3K8/32GX
128GB Samsung 840 Pro SSD
4TB Samsung 850 EVO SSD
Optical Drive
LG 12X BD-ROM 16X DVD-ROM 48X CD-ROM SATA Internal Blu-ray Drive CH12LS28
Corsair HX750W
COOLER MASTER GeminII S524 120mm Long Life Sleeve CPU Cooler
Antec Two Hundred v2
Operating System
Windows 7 Ultimate
3 x Asus VG248QE
Vizio VO320E 32" TV
Keyboard
Logitech G510s
Mouse
Logitech M525 with Unifying Receiving
Audio
Corsair SP2500 2.1 Speakers
Audio
ASUS Xonar Essence STX Virtual 7.1 Channels 24-bit 192KHz PCI Express x1 Interface 124 dB SNR / Headphone AMP Card
Other
LSI 9211-8i HBA card
Other
HooToo® HT-CR001 3.5" PCI-E to USB 3.0 Multi-in-One Front Panel Internal Card Reader (6 Memory Slots, Genesys GL3220 Chipset) & SuperSpeed USB 3.0 3-Port Hub (VIA VL800 Chipset), can read & write: M2/MS Micro, High-Speed CF(UDMA), UHS-I, SD, SDHC,...
Other
StarTech HSB220SAT25B 2 Drive 2.5in Trayless Hot Swap SATA Mobile Rack Backplane
i7-5930K Haswell-e
Asus X99-E WS/USB 3.1
Visiontek Radeon 7870 2GB with 6 miniDisplayports
G-Skill Ripjaws 64GB (8x8GB) DDR4 2133
Samsung 850 EVO 4TB SSDs
Samsung 950 Pro 512GB m.2 SSD boot drive
Corsair AX760
Noctua NH-D15S Cpu cooler
Scratch built. Currently under construction at https://www.overclock.net/t/1602023/preparing-for-a-scratch-built-case
Operating System
Win 7 Ultimate
Mouse
Logitech M525
Mouse
El Cheapo Allsop hard plastic
Lady Fitzgerald is offline
post #24 of 36 (permalink) Old 11-25-2015, 07:28 AM - Thread Starter
Razroid's Avatar
Rep: 20 (Unique: 16)
Originally Posted by HardheadedMurphy View Post
This + This = win!
I know its technically not quite an option but short of running cable that is the best solution I can think of. My wife was firmly against running cable to the second floor of our house for my son to game on, standard housing, and on the ac band my son can game and stream effortlessly to his hearts content.
In a previous life, I worked for a security company (before everything was wireless). It is ALWAYS possible to hide a wire. Here are some options:
1) Baseboard- You can pull the base board and cut a notch in the back to staple the wire to. The re-install baseboard and be careful where you put the nails.
b. Get some 1/4 round or shoe molding. Notch the back corner of it on table saw. Lay the wire down where the baseboard meets the floor, and install molding over it. care with nails again.
2) Crown molding- Same idea, but a little more difficult since the run up the wall to get to the ceiling is more difficult to hide.
3) A/C ducts. You have to use plenum rated wire! All of your duct work connects to all of your rooms. This way is REALLY difficult, and it doesn't help in hiding the wire once it comes out of the duct. If you have floor ducts, this can look pretty decent. I've seen people tie fish string (not fishing line, but string meant specifically for pulling wire) to duct cleaning tools, RC cars with a camera attached, and even a trained rat! (The guy with the rat was eff'ing awesome!)
Just a couple of tricks of the trade for getting from room to room. We used closets a lot. Hide a wire in a closet along the corner behind the door. No one looks there. Doorways: If you are going to use the baseboard technique, you will need to get around door jambs to get from one room to another. Drill a hole through the wall where the baseboard meets the door casing, but don't try to go straight to where you want it to pop out on the other side. You will either miss and be in the middle of the wall on the other side, or catch the edge of the casing and split it on the other side. Drill from both sides at the same angle toward the door. About a 20 degree angle works well. Drill about half way through, and do the same on the other side. The goal is for the two holes to intersect, but not at such a sharp angle that the wire won't make the turn when shoving it through.
My favorite way to do it was to pull the base board, but everyone had their own way.
1) Unfortunately my baseboards are also marble, same material as my floor.
2) I do have crown molding! But I think its made of concrete.
3) No A/C ducts in my house frown.gif
Because, awesome.
Well I guess I need to go buy a rat now, the ocn community just keeps impressing me with the interesting ideas wheee.gif
Warning: Spoiler! (Click to show)
No, I'm kidding, no rats, my mum would kill me (and the rat).
I was thinking of attaching the CAT6 to the existing CAT3 and pulling it over, I just need a way to identify the CAT3 on each end :/
I also realised, using a RAT to pull CAT, that's funny, huehuehue
Razroid is offline
post #25 of 36 (permalink) Old 11-25-2015, 01:13 PM
cones's Avatar
cones is offline
post #26 of 36 (permalink) Old 11-25-2015, 01:44 PM
NKrader's Avatar
Rep: 105 (Unique: 93)
Or a dolphin, they are super smart.
[Build Log] - Pizza Under the Sea - SuperNAS - Caselabs/Seasonic/Supermicro
Integrated - Intel® Xeon D-1540 8c/16t 2Ghz
SuperMicro X10SDV-TLN4F-O
Integrated - Aspeed AST2400
Samsung 64GB (2 x 32GB) ECC Registered DDR4 2133
SuperMicro - 64GB DOM SSD - vSphere & NAS VM
LSI 9300-8i w/ Noctua NF-A4x10 40mm
2x SuperMicro CSE-M35T-1B
Samsung 960 EVO - 250GB - Media Server VM & Seedbox VM
3x WD Red Pro - 8TB (14TB ZFS Array)
WD Black - 4TB - NAS Scratchspace
Seasonic SS-660XP2
CPU - Noctua A-Series NF-A9x14 w/ 3d printed 50mm/92mm fan adapter
Top Exhaust - 2x Noctua NF-A14 ULN 140mm
Front Intake - 2x Noctua NF-A9 PWM 92mm
Rear Intake - Noctua NF-A12x15 PWM 120mm
Caselabs X2M & MNPCTech ITX Case Feet
Operating System
VMware vSphere ESXi-6.5
Operating System
NAS VM - Ubuntu Server 16.04 - ZFS Array, SMB/NFS
Operating System
Media Server VM - Ubuntu Server 16.04 - PLEX, Owncloud
Operating System
Seedbox VM - Windows 10 Pro - QBittorrent, Sonarr
Other
Travel Case - Pelican Storm iM2875 & Custom Foam
Other
APC Back-UPS Pro 1500 UPS
Intel Core i7-8700K
ASUS ROG STRIX 3270I w/TPM
Ballistix Tactical 32GB Kit (16GB x 2) DDR4 3000
SAMSUNG 960 PRO M.2 512GB NVMe
SAMSUNG 960 EVO M.2 1TB NVMe
Optical Drive
ASUS External 12X Blu-Ray Writer
CORSAIR SF600 - 600W
Noctua NH-C14S w/ Noctua 140mm NF-A14 IndustrialPPC 2000 IP67 PWM
4x Noctua NF-F12 IndustrialPPC 2000 IP67 PWM
Operating System
Windows 10 Professional
Samsung - S34E790C - 34" 21:9 Curved Screen
Keyboard
CODE 87 - Cherry MX Green
Mouse
RAZER DeathAdder Chroma
Mouse
Glorious PC Gaming Race 3XL Mouse Mat - 48X24"
Audio
Steelseries - Arctis 7
Audio
Bose Companion 2 Series III
Other
CyberPower UPS - PR1500LCDRTXL2U - 1500w
NKrader is offline
post #27 of 36 (permalink) Old 11-26-2015, 10:09 AM - Thread Starter
Razroid's Avatar
Where would I get a ferret from in Singapore...
At least with rats I can just capture one from the dumpsters at night.
Yeah, let me just go flood my walls with water and go find myself a microdolphin to pull my cables for me.
Razroid is offline
post #28 of 36 (permalink) Old 11-26-2015, 10:17 AM
cones's Avatar
Just to keep derailing the thread, they don't sell ferrets there? I guess the US is weird that we sell so many pets.
cones is offline
post #29 of 36 (permalink) Old 11-26-2015, 10:39 AM - Thread Starter
Razroid's Avatar
The thread is gonna end up in a river and kill 10 people. Too soon? Okay frown.gif
Anyway, ferrets are actually banned as pets here in Singapore, along with chewing gum and a huge list of other things :/
Razroid is offline
post #30 of 36 (permalink) Old 11-26-2015, 10:50 AM
cones's Avatar
Weird.
cones is offline
