Pi 3 acting as temp nvr - Overclock.net - An Overclocking Community
post #1 of 3 (permalink) Old 05-12-2019, 12:25 PM - Thread Starter
FurryGamerGirl
TechnoVixen's Avatar
Rep: 1 (Unique: 1)
Okay I'm not going to explain it all but the jist is, I bought a cheaper camera system and the nvr is crap so I'm returning it. Zosi brand if you want to know.
Anyways my pi 3 is laying around not being used so I was thinking of using zoneminder and 4 mid-range cameras. Thinking the reolink or amcrest Poe ones in the 60 range. I have a 2 tb HDD I just got because the zosi system didn't have one with it like it was supposed to work Amazon gave me a 50$ credit and I got a 2tb seagate.
So I guess my question is, if I am just recording and not watching them 24/7 can a pi 3 run 4 cameras? I know I'll need a Poe injector,which is fine.
The cameras I'm looking at are these
Reolink
Amcrest
Sv3c
Sv3c dome
https://www.amazon.com/dp/B07BNGWZVR..._xrj2Cb66DK0TN
https://www.amazon.com/dp/B07C5JWK4K..._Xsj2CbRFF87RQ
https://www.amazon.com/dp/B07KJ1PRMC..._ptj2CbB2R4X4K
Just a furry gamer girl, married to a furry gamer girl.
TechoFox
Ryzen 5 2600
Gigabyte B450M DS3H
Nvidia GeForce GTX Titan X
CORSAIR - VENGEANCE LPX Series
Samsung EVO 850
Western Digital Blue
Seagate Barracuda
Seagate Barracuda
Corsair CX750M
Corsair iCUE 220T
Operating System
Windoss 10 Pro
LG - 24" IPS LED FHD FreeSync Monitor
Mouse
CORSAIR - M65 RGB Elite
TechnoVixen is offline
post #2 of 3 (permalink) Old 05-14-2019, 09:03 AM
Cheapest Man On Earth
Kleer Kut's Avatar
Rep: 76 (Unique: 68)
Unfortunately the Pi's released so far are all based on the same architecture which utilizes a single USB 2.0 lane for networking as well as the USB ports. Trying to connect a drive to a Pi means it is limited to USB 2.0 speeds, and using networking at the same time cuts in on the available bandwidth. The Pi Foundation said the next generation will use a newer architecture, but the currently available ones are crippled in this manner. They are learning devices and not meant for what most people try to do with them.
There are other options out there for Pi-like devices that have multiple, faster I/O options from the likes of Pine64, FriendlyElec (FriendlyArm), Odroid and others which tend to have less or no support. You can look at some Options Available at AmeriDroid. The companies mentioned supply working OS images. Alternatively you can look at the Options From Armbian for Debian and Ubuntu based images.
After buying all of the extras to get an ARM device up and running, and getting it suitable to connect a drive for writing a significant amount of data usually ends up costing around the same as a cheap x86 machine. There are plenty of people using ARM devices in that way, but I personally don't see any clear winners. There are lots of x86 devices using similar or slightly more power with substantially more versatility because of all the connections they have such as SATA, PCI-E, USB 2/3, and networking.
You can set up the Pi as a POE camera with a POE hat and Pi camera (the CSI port isn't on the same USB bus as nearly everything else). I have one set up to look down my driveway, but it just broadcasts on the network where another machine can be used to record. A cheap Atom based board has worked fine for me in my testing, recording using Motion on Raspberry Pi x86 and other Linux distros.
It may be possible to do some recording using the Pi and only using motion activated recording, but it will quickly get saturated trying to juggle more than one camera.
*Comprehensive Memory Overclocking Guide*
Low Power Ryzen
(5 items)
Ryzen 5 2400G
ASRock B450M-PRO4
Team T-Force Vulcan 16GB (2 x 8GB)
Tuniq Tower
Operating System
Lubuntu 18.10
Kleer Kut is offline
post #3 of 3 (permalink) Old 05-14-2019, 01:06 PM - Thread Starter
FurryGamerGirl
Rep: 1 (Unique: 1)
Alright I appreciate the response, I'll have to use my main rig for now then and probably go a VM Linux distro route until I can get a cheap desktop to make into a dedicated Linux system
TechoFox
Ryzen 5 2600
Gigabyte B450M DS3H
Samsung EVO 850
Seagate Barracuda
Seagate Barracuda
Corsair CX750M
Corsair iCUE 220T
Operating System
Windoss 10 Pro
Mouse
