SMB same physical location, separate lans - Overclock.net - An Overclocking Community
post #1 of 5 (permalink) Old 01-13-2020, 10:49 AM - Thread Starter
Dante_son_of_sparda's Avatar
Rep: 3 (Unique: 3)
Hello everyone,
I have a... Unique.. Set up that I am wondering if this is even possible on.
I rent a room where the owner of the home has given me leave to add my own router into the DMZ for purpose of portforwarding a server I own. It's been working great minus some double NAT issues preventing NAT Loopback working but I digress...
I'd like to open up access to my file server to someone in the same physical location, but connected onto the other LAN.
Could I forward the SMB ports used by windows to my server on my router to my server and connect to it from the router IP given to me by the second router?
Or is it not possible?
Dante_son_of_sparda is offline
post #2 of 5 (permalink) Old 01-13-2020, 11:05 AM
Shawnb99's Avatar
Rep: 46 (Unique: 31)
Couldn't this be accomplished by using a subnet? It's been years since I learned CCNA so I'm just spitballing
My Baby
(23 items)
Delidded Direct Die I9 9900K
ASUS Maximus XI Apex
EVGA FTW3 Hydro Copper GeForce RTX 2080 Ti
G.SKILL TridentZ Series 16GB DDR4 3600 F4-3600C15D-16GTZ
2x Samsung 970 EVO Plus 1TB
Asus Hyper M.2 card
2 x Intel 660P 2TB
Seasonic PRIME Ultra 1000 Titanium
Optimus Signature V2
2x Swiftech MCP35X2 with MCP35X2 Heat Sink w/ 2x NB-BlackSilent Pro's
2x Hardware Labs Black Ice Nemesis 560GTX w/ 8x Arctic P14 PST PWM's
2x Hardware Labs Black Ice Nemesis 480GTX w/ 16x Noctua NF-A12x25 PWM
Aquacomputer aqualis XT 450 ml with nano coating
9x Noctua NF-S12A PWM
Hardware Labs Black Ice Nemesis 360GTS w/ 6 Arctic P12 PST PWM's
Case Labs Magnum TH10A with Pedestal
Asus PG278Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Light Harmonic Oscar XXI
Audio
Geek Pulse Inifnity DAC/AMP
Audio
Cavalii Audio Liquid Carbon HPA
Other
Aquacomputer Aquaero XT
Shawnb99 is online now
post #3 of 5 (permalink) Old 01-13-2020, 12:15 PM - Thread Starter
Rep: 3 (Unique: 3)
Could you elaborate?
The networks subnets are different and to my knowledge cannot be the same, else they'd be the same network.
10.0.0.x
Is the "primary"
192.168.0.x is my own.
post #4 of 5 (permalink) Old 01-13-2020, 03:24 PM
Rep: 170 (Unique: 132)
Sure, why wouldnt you? Depending on what routers your have theres no reason you couldnt
So on the network, assuming that 192.168.0.1 is the router, 192.168.1.1 is your router, 192.168.0.2 is a client on the first lan, and 192.168.1.2 is the server
Easy / correct option
Router 1 needs a static route adding so it knows that 1.1/24 is hanging out off a port thats plugged into it, then it will just work. https://www.linksys.com/id/support-a...icleNum=135048
Medium / Eh option
If you want to keep nat, (bad idea as you allready know!) , then you may be able to do it if 192.168.0.1 supports DNAT or Dynamic routing.
If dynamic routing, (try this first it may "just work") : if you have plugged the routers in the correct way *(client port on 192.168.0.1 to the WAN port of 192.168.1.1) and both routers support whatever random protocol the router manufacture chose, you may only need to add a rule on 192.168.1.1 to forward SMB to the server and it will work.
For DNAT : If it supports DNAT, you can add a nat rule to forward the traffic from 192.168.0.1 to 192.168.1.1 and then add another DNAT onto router two to forward the traffic onto your server. Most consumer routers will set up a rule to forward the traffic back, and as SMB is all client initated, it should all be NAT safe and work.
Super Easy method, Just get 2X 10 quid wireless adapters from Amazon, connect one to Lan 1, one to Lan 2, and dual host the sever. Turn off routing on windows server to prevent network insanity and boom done, lan 1 connects to lan 1 wifi adapter, lan 2 connected to lan 2 wifi adapter
Also the Networks can be "the same" if your router supports it, is called super netting and it lets you have a /24 over all, and then each router just manages a /25.
AWESOME. Buy 1600 point card = $19.99. Buy two 800 point cards = $19.98
Save big.
Shhhh! Don't tell Microsoft. They might discover our secret.
>XXX
Ulquiorra is offline
post #5 of 5 (permalink) Old 01-13-2020, 06:37 PM
EniGma1987's Avatar
Rep: 342 (Unique: 252)
Ulquiorra is correct, this is done with setting up static route in the routers.
You will also need to be doing port forwarding in the main router as well to get around your double-NAT situation to access your server properly. Just because you are in a DMZ specified port doesn't mean you arent still behind the router and going through his NAT stuff.
EniGma1987 is offline
