SYSTEM_THREAD_EXCEPTION_NOT_HANDLED BSOD yet again. DMP analysis included. - Overclock.net - An Overclocking Community
post #1 of 31 (permalink) Old 05-29-2011, 02:53 PM - Thread Starter
Retired Staff
pjBSOD's Avatar
Rep: 738 (Unique: 566)
I've been getting random SYSTEM_THREAD_EXCEPTION_NOT_HANDLED BSODs. At first they were only happening while gaming. I was just browsing Facebook looking at an album while downloading The Witcher 2, and boom, BSOD. This has been an ongoing issue which seemed to have spawned around the time I decided to install my second 5850, or sound card.
Things I have done already.
1. Complete reinstall of Windows.
2. Ran Memtest86, was going strong with no errors after I woke up (11 hours).
3. Ran Prime95 Blend to ensure CPU stability, was going strong after I woke up (11 hours).
4. Reinstalled display drivers. Uninstalled 11.4, restarted, installed 11.5b, restarted.
5. Ran a chkdsk, found no errors or bad sectors.
Someone linked me to this hotfix, from MS. At first I thought it fixed my previous SYSTEM_THREAD_EXCEPTION_NOT_HANDLED BSODs, but it's still here.. and now it's happening while NOT gaming.
I am totally and completely out of ideas. I can't think of anything that can be causing this. I don't believe it's my 2600k overclock. It's 11 hours stable and I'm already pumping 1.35 core voltage into it.
DMP file:
On Sun 5/29/2011 9:41:51 PM GMT your computer crashed
crash dump file: C:\Windows\Minidump\052911-21637-01.dmp
This was probably caused by the following module: [FONT=Segoe UI, Arial]fltmgr.sys[/FONT] (fltmgr+0x5141)
Bugcheck code: 0x3B (0xC0000005, 0xFFFFF880012F4141, 0xFFFFF880093A8920, 0x0)
Error: [FONT=Segoe UI, Arial]SYSTEM_SERVICE_EXCEPTION[/FONT]
file path: C:\Windows\system32\drivers\fltmgr.sys
product: [FONT=Segoe UI, Arial]Microsoft® Windows® Operating System[/FONT]
company: [FONT=Segoe UI, Arial]Microsoft Corporation[/FONT]
description: Microsoft Filesystem Filter Manager
Bug check description: This indicates that an exception happened while executing a routine that transitions from non-privileged code to privileged code.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system which cannot be identified at this time.
[/FONT][FONT=Segoe UI, Arial]
[/FONT]
pjBSOD is offline
post #2 of 31 (permalink) Old 05-29-2011, 02:54 PM
Rep: 38 (Unique: 29)
are the 5850's running at stock ?
masonkian is offline
post #3 of 31 (permalink) Old 05-29-2011, 02:58 PM - Thread Starter
Retired Staff
pjBSOD's Avatar
Yes, always have been except for the very few times I tried overclocking the first 5850 I owned. But yes, they're at stock.
Here's my only theory..
My only theory is that my Hard Drive is dying. I mean, I BSOD'd while downloading The Witcher 2 off of Steam, and the % complete went from mid 30s to 18%.
Sounds like corruption to me, no?
Edit: Ran chkdsk, no bad sectors or errors.
pjBSOD is offline
post #4 of 31 (permalink) Old 05-29-2011, 02:59 PM
tried new card on its own for abit to eliminate it ?
sound card could be at fault also take it out for abit see if you can replicate the BSOD
post #5 of 31 (permalink) Old 05-29-2011, 03:10 PM - Thread Starter
Retired Staff
pjBSOD's Avatar
I have not tried either of those. I see my buddy Ganja in the users viewing! Haha.
I just ran a chkdsk, no errors or bad indexes, so that eliminates my HDD theory.
pjBSOD is offline
post #6 of 31 (permalink) Old 05-29-2011, 03:10 PM
GanjaSMK's Avatar
Rep: 626 (Unique: 466)
Send me the crash dump E-Peen.
I'll gladly help you figure out what likely is causing it.
@drbaltazar posts
Originally Posted by dave12
I like your posts. Every time I see one I read it multiple times trying to discern meaning, ultimately failing, but enjoying the experience.
GanjaSMK is offline
post #7 of 31 (permalink) Old 05-29-2011, 03:12 PM - Thread Starter
Retired Staff
pjBSOD's Avatar
If you help me fix this, I seriously wouldn't know how to thank you. I can't take much more of this.
How would I go by sending you the crash dump file? To get that analysis I used a free program called "WhoCrashed", so I don't exactly know how to "officially" view crash files.
pjBSOD is offline
post #8 of 31 (permalink) Old 05-29-2011, 03:14 PM
Rucka315's Avatar
Rep: 21 (Unique: 17)
Rucka315 is offline
post #9 of 31 (permalink) Old 05-29-2011, 03:16 PM - Thread Starter
Retired Staff
pjBSOD's Avatar
Originally Posted by Rucka315;13679822
More voltage imo
frown.gif I already have 1.35 core voltage going into it.
pjBSOD is offline
post #10 of 31 (permalink) Old 05-29-2011, 03:17 PM
GanjaSMK's Avatar
Ok, navigate to C:\Windows\Minidump
You'll find a bunch of in there unless you have things set to overwrite the dumps. Send me the latest one you've gotten, either via Megaupload or some other sharing site, or here via PM. thumb.gif
@drbaltazar posts
GanjaSMK is offline
