Complete Overclocking Guide: Sandy Bridge & Ivy Bridge | *ASRock Edition* - Page 3 - Overclock.net - An Overclocking Community
View Poll Results: Was this guide helpful?
Yes (and I DO have an ASRock motherboard). 237 80.07%
Yes (but I DO NOT have an ASRock motherboard). 45 15.20%
No (and I DO have an ASRock motherboard). 7 2.36%
No (but I DO NOT have an ASRock motherboard). 7 2.36%
Voters: 296. You may not vote on this poll
post #21 of 9909 (permalink) Old 01-24-2012, 03:41 AM - Thread Starter
sɪɴɢɪɴɢ ɢᴏᴅᴅᴇss
kennyparker1337's Avatar
Rep: 352 (Unique: 304)
Originally Posted by sherman9800 View Post
Hey all,
Just recently purchased my new rig. Loving it so far and having fun OCing it. Upgraded from a cheapy MSI board and Phenom II X3 720BE to this 2500k. Having trouble getting stable at 4.7GHz and want to push higher for fun but would like to leave it around 4.6-4.7 for daily use. After 15 mins prime 95 blend worker 4 gets an error. Help would be greatly appreciated. Thanks!
Ambient Temps - 23C
Idle around - 27C
Under load - Max 61C <-- REALLY GOOD temps! thumb.gif Max under load should be 85C. It will rise alot with vcore but will be perfectly fine. The chip won't even shut down till a whopping 98C.
BIOS settings are below:
BCLK - 100 X 47 Multiplier
Vcore - 1.35 in cpu-z Wowsers... thats really low imho. 1.5v is the max for me, and almost all agree that 1.45v is the low max. So I would at least got to 1.4-1.45v and try to get stable at 4800MHz.
LLC - Level 2
Voltage offset + .090v
Internal PLL - Disabled (possibly need to enable for higher OC's but would like confirmation) Enabling will help a TON, but It may cause Sleep problems (or it may not, different across boards). Try going to your max vcore before enabling this if you want.
Spread Spectrum - Auto Disable this.
Dram - 1.529v 1600mhz XMP
PCH Voltage - 1.059v Leave auto.
PLL Voltage - 1.832v (I've read that's set pretty high and might want to reduce it) 1.89v is the limit, however raising it rarely affects overclocking.
VTT - 1.047v Leave auto.
VCSSA - 0.925v Leave auto.
Gave you some tips, which almost all are in my guide. tongue.gifrolleyes.gif(My comments are in bold or italicized.)
Originally Posted by Derko1 View Post
Well that both sucks and gives me relief that it's not something that is dying.
Now ANOTHER issue that I am having... is that several games will crash either when loading at the begining... loading in between levels... or when exiting. The worst is NFS The Run... which will crash and then I can kill it through the task manager, but will BSOD right after I kill it. It's usually that the driver has stopped working... with a 126 BSOD.
Any ideas on what could be causing this?
That BSOD isn't on the list of related ones to Overclocking the CPU, so I would suspect that your GPU drivers are doing it. I would get the latest drivers from AMD/ATI for your graphics card and make sure that you pass the final test on my guide. Also when you install the drivers, make sure you do a clean install, or use driver sweeper to wipe the old drivers out.
Originally Posted by griffulas View Post
Nice guide, helped me get stable at 5ghz + rep had been using manual control of vcore, and L1, L2 is working better for me biggrin.gif
https://www.overclock.net/image/id/1676791/width/600/height/374
5hrs on prime95 blend, still trucking going for 12
I tried so hard to get 5GHz but my chip won't go more than a min in prime95 at 5GHz even with a 1.52v. But I've learned to let it go...4.9GHz is blazingly fast. devil-smiley-019.gif
"If you wish to make an apple pie from scratch, you must first invent the universe." ― Carl Sagan
"That which can be asserted without evidence, can be dismissed without evidence." ― Christopher Hitchens
"The good thing about science is that it's true whether or not you believe in it." ― Neil deGrasse Tyson
kennyparker1337 is offline
post #22 of 9909 (permalink) Old 01-24-2012, 04:32 AM
griffulas's Avatar
Rep: 6 (Unique: 4)
another place i deviate from your guide, i found the sweet spot for my chip to be 1.709 for pll so if you bsod is x0124 try this change i bet it will work
edit: https://www.overclock.net/t/940091/bsod-codes-when-ocing-must-have-info great resource, list of common error codes and causes, if your getting x0124 try lowering pll ive read some 1155 chips like the lower voltage at higher multis
update374
12hrs of custom blend if you look my pll voltage is 1.709
griffulas is offline
post #23 of 9909 (permalink) Old 01-24-2012, 05:02 AM
sherman9800's Avatar
Rep: 0
Have currently tried 4.8 on 1.40 fixed vcore with Internal PLL enabled, no dice. Wont even post with these settings, but can get 4.7 running prime 95 blend for a bit with 1.35vcore...
Spread spectrum disabled.
LLC Level - 2
My power supply is the less current Corsair TX550 (non modular). I dont have a crazy setup with the HD6870 not being overclocked with a single 10k Raptor drive and a 500GB HDD and 4 fans plus the H60. Could my power supply being running out of juice trying to get those speeds? Its never shown to have been bad before but I save the BIOS settings and it just continually restarts itself with either no power the peripherals or shuts down right away. I have to clear CMOS and start over again. I've looked at the draw on Real Temp and its hovering around 95w which isnt much. VID is 1.3861.
sherman9800 is offline
post #24 of 9909 (permalink) Old 01-24-2012, 05:57 AM
Derko1's Avatar
Rep: 200 (Unique: 157)
Cool. I think I'll stop playing with the OC settings then... that's really the only two issues I am having with it and seem like they are unrelated to the OC.
I have tried the other drivers too... but still have the same issue. It might just be a problem with the games them selves too. Cause Skyrim runs flawlessly. Above 60fps everywhere and no crashes at all.
I'll probably be back when I get my water set up to try to hit 5.0.
skull.gif[Official] Delidded Crewman skull.gifCurrently Playing
Dead Space 2 | Batman Arkham Asylum | Grid AS | Mass Effect 2 | The Wolf Among Us | Max Payne 3
Finished Games
Anamoly | Home | DLC Quest | Limbo | Dead Space | Tomb Raider | Oil Rush | Legendary
The Walking Dead | Ittle Dew | Saints Row The Third | Outlast | Dyad | Max Payne | Max Payne 2
Steam Profile
Derko1 is offline
post #25 of 9909 (permalink) Old 01-24-2012, 03:32 PM - Thread Starter
sɪɴɢɪɴɢ ɢᴏᴅᴅᴇss
LLC Level - 2
http://extreme.outervision.com/PSUEngine
System Type: 1 physical CPU
Motherboard: Regular - Desktop
CPU Socket: Socket LGA 1155
CPU: Intel Core i5-2500K 3300 MHz Sandy Bridge
Overclocked: 4800 MHz, 1.4 V
CPU Utilization (TDP): 90% TDP
RAM: 4 Sticks DDR3 SDRAM
Video Card 1: AMD Radeon HD 6870
Regular SATA: 1 HDD
High rpm SATA: 1 HDD
DVD/CDRW Combo Drive: 1 Drive
USB: 4 Devices
Fans
Regular: 4 Fans 120mm;
Water Cooling Kit: Corsair Hydro H60
Keyboard and mouse: Yes
System Load: 90 %
Capacitor Aging (+ W %): 20 %
Minimum PSU Wattage: 486 Watts
Recommended Wattage: 536 Watts
post #26 of 9909 (permalink) Old 01-25-2012, 01:15 AM
Rep: 0
Thanks for that. I might look into getting a new power supply. Possibly a silver or gold 750w for Crossfire later as well.
Also, I took griffulas' advice and changed the PLL lower to 1.75 and it was much much better. No restarts, boots first try and just needed more voltage to get up to 5.0 Ghz. Worker 4 is always the culprit on prime and I just clocked it back down to 4.6 as that was the last rock solid stable with much lower voltage. Way better temps but once I get a new PSU and push pull typhoons I will give it a try again for a better stable OC.
post #27 of 9909 (permalink) Old 01-25-2012, 09:07 AM - Thread Starter
sɪɴɢɪɴɢ ɢᴏᴅᴅᴇss
If you want a great power supply to last you for at least 2-3 years, get one of these:
Non-modular ($90): http://www.newegg.com/Product/Product.aspx?Item=N82E16817139020
Modular ($125): http://www.newegg.com/Product/Product.aspx?Item=N82E16817139012
Personally unless I could find a cheap used HX650, I would get the non-modular V2 one.
I have more power demand then your setup, and both the TX and HX650 worked fine for me.
post #28 of 9909 (permalink) Old 01-25-2012, 11:47 AM
griffulas's Avatar
Rep: 6 (Unique: 4)
LLC Level - 2
i also hit a brick wall at 4.8, but after using this guide and going from fixed to offset vcore i was able to get to 5ghz no problem so i would try it
ill be posting my bios screens when i get home sometime tonight if that can also be helpful
under 100% load vdroop puts bounces my vcore between 1.486 and 1.520 so it really does need some voltage, but lowering the pll and setting everything but vcore to offset, setting your ram to 1.5x or 1.6x and setting pll to 1.7x should give you some wattage to work with
post #29 of 9909 (permalink) Old 01-25-2012, 04:37 PM
Cico14's Avatar
Rep: 0
Been trying to overclock my 2600k. I got it to run stable @ 4.5 GHz and 1.4V, but my max temp while running prime was 97C. For some reason my temps seem really high. I am currently @ 4.2 and 1.25V with a max temp of 75C. Does this sound Okay?
Cico14 is offline
post #30 of 9909 (permalink) Old 01-25-2012, 04:43 PM
crondable's Avatar
Rep: 2 (Unique: 2)
97C is WAY too hot. You should be able to go a LOT lower with your voltages at those speeds. Average for most chips at 4.5 is somewhere between 1.28 and 1.35.
Steam/Origin/XBL: lecrondable
crondable is offline
