Complete Overclocking Guide: Sandy Bridge & Ivy Bridge | *ASRock Edition* - Page 991 - Overclock.net - An Overclocking Community
View Poll Results: Was this guide helpful?
Yes (and I DO have an ASRock motherboard). 237 80.07%
Yes (but I DO NOT have an ASRock motherboard). 45 15.20%
No (and I DO have an ASRock motherboard). 7 2.36%
No (but I DO NOT have an ASRock motherboard). 7 2.36%
Voters: 296. You may not vote on this poll
post #9901 of 9909 (permalink) Old 04-01-2019, 11:18 AM
deepor's Avatar
Rep: 479 (Unique: 325)
Quote: Originally Posted by PauliePeanuts View Post
@DarthFK or anyone else here paying attention to this thread... I no longer can get into my bios, and I am not sure why.. i click f2/del, but it just bypasses and goes right into windows... I read there is an option under settings to restart into UFEFI , but my windows doesn't have that option displayed.. no idea what to do..
Do you actually use UEFI boot or do you use "Legacy" = "BIOS" boot? If you don't use UEFI there's no such option to reboot into the UEFI/BIOS menus in Windows. You know that you use UEFI boot if you can see a 100MB sized partition with a text "EFI System" in the Disk Management tool in Windows.
If you do use UEFI, this kind of thing is caused by enabling a "fast boot" option somewhere in the UEFI/BIOS menus. At boot it will then not look for the keyboard and will instead go into Windows immediately. There should be a way to make the UEFI/BIOS boot with its default, slower mode where it will look for the keyboard. I don't know how to trigger this, but what I would try is disconnecting power for the whole PC for something like ten seconds.
If you do not use UEFI, then maybe your problem is that the UEFI/BIOS can't detect your keyboard at boot. Did you change something about that recently? Like, are you using a different keyboard? Or did you connect it to a different USB port? I've seen motherboards where only PS/2 keyboard were guaranteed to work, and USB keyboard were often problematic, especially gaming stuff with "n-key roll-over" over USB.
This keyboard problem idea could of course also hit you when using UEFI boot, so the keyboard not being detected is always something to think about.
deepor is offline
post #9902 of 9909 (permalink) Old 04-01-2019, 04:31 PM
Rep: 0
Try shutdown /r /f /t 0 /fw at the command prompt, or if you are using an asrock mobo download restart2uefi from their website
aflack is offline
post #9903 of 9909 (permalink) Old 04-03-2019, 02:47 PM
Rep: 0
When i look in system info, it says my bios is legacy mode.. Is that something I should change? I got it to work by resetting the bios with the jumper , Im not sure what happened. I was always able to get into the bios using the F2 key.. I might have shut off legacy USB in bios, maybe that is what disabled it? Not sure. It seems to be working now after the CMOS clear with the jumper.. I see USB legacy is now enabled by default.. I think someone recommended i turned that off to help trouble shoot some issues with my VR headset.
PauliePeanuts is offline
post #9904 of 9909 (permalink) Old 06-29-2019, 12:49 PM
pel
pel's Avatar
Rep: 1 (Unique: 1)
I try to change offset voltage on bios and it wont change,it will not update, i can only change it via Asrock Extreme Tunner in windows
pel is offline
post #9905 of 9909 (permalink) Old 06-29-2019, 01:37 PM
DarthFK's Avatar
Rep: 7 (Unique: 7)
Sorry everyone whom I didn't reply previously - was away and them moved to another apartment. Still navigating between boxes. As I said earlier I will leave this thread soon.
Anyway, before that:
pel, what's the exact model of the board, BIOS revision and CPU?
P.S. i might reply only sporadically due the the move-in.
I am your father?
Workhorse
Intel i7-9700k
Asus Maximus X Hero WiFi
Powercolor Red Devil RX5700 (flashed with RX5700XT BIOS)
Adata XPG Spetrix D41 16Gb dual kit (2x8Gb) 3600c17 Samsung B-die.
Crucial P1 NVMe 1Tb QLC
EVGA 850W P2
Enermax Liqmax 240 II with 2 x Nidec GT2150rpm PWM
Fractal Design Define C
Operating System
Windows 10 Pro x64
AOC G2590FX 1080p 144Hz
Keyboard
CORSAIR K70 RGB MK.2 RAPIDFIRE Low Profile
Mouse
Pictek Gaming Mouse 7200dpi
Mousepad
Corsair MM300 XL
DarthFK is offline
post #9906 of 9909 (permalink) Old 06-29-2019, 04:51 PM
deepor's Avatar
@DarthFK : You might want to know that there's a terrible bug right now on overclock.net when people are posting with a smartphone browser. For people browsing with a desktop PC, in your post the "s" and "S" letters disappear and are replaced by strange codes "& # 1 1 5 ;" and "& # 8 3 ;", making things very hard to read. This only shows up for people using desktop browsers, you can't see it on the smartphone.
You can check out the problem on your smartphone as well if you choose "show desktop site" in your browser's menu. You'll then see the same broken text that's showing up on a desktop browser.
deepor is offline
post #9907 of 9909 (permalink) Old 06-29-2019, 04:55 PM
DarthFK's Avatar
Rep: 7 (Unique: 7)
Thanks @deepor ! Was on the phone, as I am moving into another apartment. Will re-write right away from a laptop:
Sorry everyone whom I didn't reply to previously - was away and then moved to another apartment. Still navigating between boxes As I said earlier I will leave this thread soon. Anyway, before that:
@pel , what's the exact model of the board, BIOS revision and CPU?
P.S. i might reply only sporadically due to the move-in.
I am your father?
Workhorse
Intel i7-9700k
EVGA 850W P2
Operating System
Windows 10 Pro x64
Keyboard
Mouse
Mousepad
Corsair MM300 XL
DarthFK is offline
post #9908 of 9909 (permalink) Old 01-05-2020, 04:22 PM
Retrorockit's Avatar
Rep: 28 (Unique: 13)
I just started looking at the Ivy Bridge unlocked Xeons and found some guys getting 4.7Ghz overclocks on HP Z420 workstations using XTU and a water loop.
https://h30434.www3.hp.com/t5/Busine...ck/m-p/6853518
This thread starts off slow but if you read the whole thing it get's pretty good. This was the closest I could find here to a live Ivy Bridge Xeon thread.
Dell Dimension E520 [email protected]
Delta GFB1212VHG, 8GB DDR2-800
R9-285 ITX 2GB DDR5, 240GB SSD
http://valid.x86.fr/l2j5p1
Retrorockit is offline
post #9909 of 9909 (permalink) Old 01-06-2020, 09:44 PM
flexy123's Avatar
Rep: 24 (Unique: 17)
Some months ago I built my wife a PC with this board and a 3570k.
This board and its behaviour, although general considered great for OC etc. gives me NIGHTMARES. And trust me, I am experienced overclocking all kinds of systems. (My own machine is an old Z87 Pro with 4770k).
* First, and this is important to realize (there is a thread about this somewhere), this board OVERVOLTS your CPU like a mofo. I am talking about up to 0.100V higher than what you set in bios what some people have reported to measure with a DMM on the CPU.
In other words: You may set 1.200V in bios, but it really may apply 1.300V. This explains why so many can run their CPUs with a seemingly very low voltage and even with negative offset V like -0.100 IN BIOS...
*** Second, and this is the most bizarre thing, the board/CPU gets more unstable the more voltage I give. Forget "standard" voltages like 1.300 which would work for other Z77/Z87 and Haswell CPUs.
The normal routine would be stress testing (P95, OCCT, whatever) and then see whether you get WHEA errors or BSODs. With a "normal" board, WHEA almost always means you increase V (as long as safe, say below 1.375), and you get more stable. HERE, it is exactly the opposite. I am not even getting remotely stable (talking about a ridiculous low OC like 43x100) unless I am applying -0.40 (at LLC 2) or lower. Leave V at stock, and this thing isn't even stable at stock multi. I have never seen anything like this.
And I am sure this has to do with that the board so massively overvolts your CPU. Temps are not even an issue as at those low volts CPU barely reaches 60/70 degrees.
flexy123 is offline
