Realtemp on sandy i5 2500k Core speed MHZ Flucuating to crazy high amounts?! 5.9 MHZ - Overclock.net - An Overclocking Community
post #1 of 11 (permalink) Old 01-31-2012, 01:50 PM - Thread Starter
pent's Avatar
Rep: 40 (Unique: 37)
Realtemp on sandy i5 2500k Core speed MHZ Flucuating to crazy high amounts?! 5.9 MHZ For like a split second. Yes i have EIST and C1E on so it being lower is expected But sometimes i notice occasional very short, Less than a split second Spikes ABOVE my allocated 4.5 GHZ (4500 MHZ) to some crazy amount like 5900 MHZ or 5600 MHZ or 5000 MHZ (5.9 GHZ or 5.6 GHZ or 5.0 GHZ) is this a glitch in realtemp 3.70 or my system doing this??? im puzzled!!?
pent is offline
post #2 of 11 (permalink) Old 01-31-2012, 03:22 PM
Retired Staff
munaim1's Avatar
Rep: 921 (Unique: 603)
munaim1 is offline
post #3 of 11 (permalink) Old 01-31-2012, 03:26 PM
Comatosed's Avatar
Rep: 6 (Unique: 6)
Try reloading or reinstalling before u roll back. I started up cpu-z while stress testing the other day and it showed me 60xmulti at 1.44v lachen.gif
Sharing is the first step to solving all the problems of humanity.
Main
(16 items)
9600k 1.38 -1.39 (still testing)
Asus PRIME Z370-P II
GTX 980ti
Corsair vengence
samsung evo
Optical Drive
LG blu-ray rw/r
thermaltake 730w modular
xspc rasa block, dual front rad, 900lh pump
ModdedTrendsonic
Operating System
win 10 64
23"GD245HQ & 2 x 21" in surround
3x1920 nvidia surround
Keyboard
logitech wireless
Mouse
g602
Mouse
Thermaltake tai chi m2
Audio
logitech G935
Comatosed is offline
post #4 of 11 (permalink) Old 02-01-2012, 02:39 PM - Thread Starter
pent's Avatar
Yeah seems like a glitch LOL. im pretty sure my chip couldn't do 5.9 GHZ @ 1.37 Vcore LOL even for a split second.
pent is offline
post #5 of 11 (permalink) Old 03-04-2012, 12:55 PM
unclewebb's Avatar
Rep: 203 (Unique: 168)
Turn off all other monitoring software except for RealTemp and see if this glitch is still there. Also make sure you turn off all of your side bar monitoring gadgets when testing.
The main problem is that the monitoring timers in the Intel CPUs are not a protected resource. That means that any monitoring program can come along and change these timers and that can completely screw up other monitoring programs.
Most users like to run a handful of monitoring apps and compare the results but with shared monitoring timers, this isn't such a good idea.
If you run RealTemp by itself and everything is OK, start adding one additional monitoring app at a time until RealTemp goes buggy. This will help you track down what program is abusing your system monitoring timers by randomly stopping or resetting them. I think Intel frowns upon that but they don't do anything at the hardware level to prevent this from happening.
unclewebb is offline
post #6 of 11 (permalink) Old 03-05-2012, 05:38 AM - Thread Starter
pent's Avatar
IM just wondering if this is Electromagnectic interference causing the CPU to spike to these frequencies. caused by some other device.
pent is offline
post #7 of 11 (permalink) Old 03-05-2012, 08:38 AM
unclewebb's Avatar
Electromagnectic interference is a nice theory but it is definitely not that. I could tell you what monitoring program is causing the problem on your computer but I prefer that users do their own research to get to the bottom of this issue. Do exactly what I said to do in my previous post and you will discover what monitoring software is causing chaos with your internal system timers.
post #8 of 11 (permalink) Old 03-05-2012, 10:26 AM - Thread Starter
pent's Avatar
Alright Well the only program running in the background was HW Monitor and i have now closed it. The spikes are very random and i think this should resolve it. Is my research correct? I have followed your instructions. And good that EMI isn't the cause as that one had me a bit worried. Good to know it isn't EMI interference causing havoc on the system. But HW Monitor does monitor more things than realtemp so i guess ill just run HW monitor and close real temp as only 1 program is accesing sensors now. Should fix the problem correct?
pent is offline
post #9 of 11 (permalink) Old 03-05-2012, 11:31 AM
Tangoseal's Avatar
Rep: 9 (Unique: 8)
El SOL!!
You probably just took a direct hit from a CME right inside your case.
Tangoseal is offline
post #10 of 11 (permalink) Old 03-05-2012, 11:44 AM - Thread Starter
pent's Avatar
Originally Posted by Tangoseal View Post
El SOL!!
please define this EL SOL and CME you speak off. I am rather undecided on whether your joking or trolling or stating an actual plausable scenario as i don't understand what those two phrases mean. A simple google search did not answer said questions. Please explain. Im leaning towards joke but iv just started physics in college so ill listen hehe.
pent is offline
