Why is my bus speed always 99.xx? - Overclock.net - An Overclocking Community
post #1 of 5 (permalink) Old 03-05-2012, 05:14 PM - Thread Starter
AllDay028's Avatar
Rep: 1 (Unique: 1)
Instead of 100? So when I put my multiplier to 45 or 46 I always end up below 4.5 or 4.6 ghz.
AllDay028 is offline
post #2 of 5 (permalink) Old 03-05-2012, 05:16 PM
Swift Castiel's Avatar
Rep: 55 (Unique: 50)
It's completely normal for it to do that. It has to fluctuate since it's almost impossible to keep it at constant 100.
Swift Castiel is offline
post #3 of 5 (permalink) Old 03-05-2012, 05:18 PM
anubis1127's Avatar
Rep: 149 (Unique: 125)
because you have CPU Spread Spectrum enabled in your BIOS/UEFI, disable that and it will be 100.
anubis1127 is offline
post #4 of 5 (permalink) Old 03-05-2012, 05:34 PM - Thread Starter
AllDay028's Avatar
Rep: 1 (Unique: 1)
Thanks for the quick replies. Is the spread spectrum something that is important for safety/shouldn't turn off?
post #5 of 5 (permalink) Old 03-05-2012, 05:37 PM
anubis1127's Avatar
It's used to help eliminate EMI. It's typically fine to disable it if it helps with your OC.
