BSOD after some light overcloking, weak cpu? - Overclock.net - An Overclocking Community
post #1 of 5 (permalink) Old 06-26-2012, 10:34 PM - Thread Starter
vziera's Avatar
Rep: 0
it occured during prime95 blend after I set the system to run on following specs:
RAM:
Corsair CMZ16GX3M4X1600C9G(three used)
timing, speed, voltage : 9-9-9-24 , 12:1600 , 1.4v
uncore multiplier, voltage: x24 , 1.25v
Processor:
i7 980x
bclk, multiplier : 135mhz , x28 x28 x28 x28 x29 x29
voltage,tdp,tcp : All default
V-Droop : High V-droop
Everything else:
All default.
Question:
since 0x0000007E BSOD is known to be OS related BSOD, can you guys confirm that this time this BSOD has nothing to do with OS?
thanks
ps:
tried medium vdroop, suddenly lagged terribly after like 5 minutes of prime95 blend test
tried low vdroop, seemed stable but as far as I know using low vdroop has never been a good idea so I revved back,
vziera is offline
post #2 of 5 (permalink) Old 06-26-2012, 10:37 PM
That Guy's Avatar
Rep: 288 (Unique: 249)
It's probably driver related. Just a shot in the dark though.
If you upload the dump file, someone may be able to go through and narrow down the issue further.
Windows 7: An OS so nice, it doesn't need a service pack twice.
Steam: KangarooCornchips
That Guy is offline
post #3 of 5 (permalink) Old 06-26-2012, 10:38 PM
Rep: 40 (Unique: 28)
Increase mem voltage to 1.5 and see if it fixes the issue, lagging in prime is usually ram or storage related issues(HDD/SSD,sata cable, drivers etc)
Then run chkdsk /r and sfc /scannow if it Bsod's again.
Can you upload the dump file?
Tyreal is offline
post #4 of 5 (permalink) Old 06-26-2012, 11:09 PM
DirektEffekt's Avatar
Rep: 142 (Unique: 96)
The BSOD codes in the sandy stable club here https://www.overclock.net/t/968053/official-the-sandy-stable-club-guides-voltages-temps-bios-templates-inc-spreadsheet would seem to suggest it is due to a corrupt OS file, you can try to run some repairs but you may need to re install.
DirektEffekt is offline
post #5 of 5 (permalink) Old 06-26-2012, 11:23 PM
spud84's Avatar
Rep: 18 (Unique: 17)
Could be oc but i'd say its more os/driver related. BSOD codes are usually on the money for what has one wrong.
spud84 is offline
