What is this TJ Max in RealTemp - Overclock.net - An Overclocking Community
post #1 of 10 (permalink) Old 08-15-2012, 08:25 AM - Thread Starter
Rep: 49 (Unique: 35)
I'm playing around with all this temp monitoring programs I've downloaded. I came across with this "Distance to TJ Max". What is this? Is a higher value good or bad? I'm getting around the mid 60s.
Cheaptrick is offline
post #2 of 10 (permalink) Old 08-15-2012, 08:28 AM
Not new to Overclock.net
TwoCables's Avatar
Rep: 6215 (Unique: 3521)
It is the "Distance to TJ Max", so the higher the better.  The reason why is that the Tj Max is the temperature where the CPU would throttle itself down in order to reduce the heat.  The Tj. Max is 98°C, so the further you are away from it, the better.  ;)
In other words, your core temps are in the 30s, so you're all set.
Loneliness is a good thing to share with someone.
The virtuous spirit has no need for thankful approval, owning a certain conviction that what has been done is right.
i5-2500K @ 4.5GHz (1.368-1.384V fixed voltage)
ASUS P8P67 EVO B3 (UEFI ver. 1850)
MSI GTX 1070 Ti Gaming Titanium 8G
G.SKILL Ripjaws X 8GB (2 x 4GB) 1866MHz, CL9
250 GB Samsung 840 EVO (OS)
3 TB Toshiba P300 (D: drive)
Optical Drive
Samsung SH-S243N 24x DVD Burner
Optical Drive
Samsung SH-S203N 20X DVD Burner
Corsair RM550x
Thermaltake Frio
CM 690
Operating System
Windows 10 Home
AOC G2460PG (24" 1920 x 1080 144Hz G-SYNC)
Keyboard
Filco Majestouch 104-key Cherry MX Blues w/NKRO
Mouse
Intellimouse Optical (1.1A) 1000Hz polling rate
Mousepad
It's just a mousepad
Audio
X-Fi Titanium HD
Audio
Klipsch ProMedia 2.1 (with 16 AWG Monster Cable speaker wires)
TwoCables is offline
post #3 of 10 (permalink) Old 08-15-2012, 08:29 AM
Forrester's Avatar
Rep: 30 (Unique: 24)
it's the thermal junction max. if the cpu reaches the tj max, it will throttle to prevent damage
Forrester is offline
post #4 of 10 (permalink) Old 08-15-2012, 08:30 AM
Leyaena's Avatar
Rep: 62 (Unique: 51)
Leyaena is offline
post #5 of 10 (permalink) Old 08-15-2012, 08:33 AM
Forrester's Avatar
Originally Posted by Leyaena View Post
haha he beat me to it by a second
post #6 of 10 (permalink) Old 08-15-2012, 08:34 AM
TwoCables's Avatar
I was recently told that it throttles to only reduce the heat, but if it doesn't throttle for some reason, then the CPU will turn itself off at 130°C in order to prevent damage.  So if this is true, then these things are tougher than we think (not that I would want to test it...).
Optical Drive
Optical Drive
Corsair RM550x
Thermaltake Frio
CM 690
Operating System
Windows 10 Home
Keyboard
Mouse
Mousepad
Audio
X-Fi Titanium HD
Audio
post #7 of 10 (permalink) Old 08-15-2012, 08:35 AM
TwoCables's Avatar
1000
I see that your BCLK is at 99.90 MHz.  Disable CPU Spread Spectrum.  smile.gif
Optical Drive
Optical Drive
Corsair RM550x
Thermaltake Frio
CM 690
Operating System
Windows 10 Home
Keyboard
Mouse
Mousepad
Audio
X-Fi Titanium HD
Audio
post #8 of 10 (permalink) Old 08-15-2012, 09:11 AM - Thread Starter
I thought it's better turn ON. Guess not then. I'll turn it OFF.
post #9 of 10 (permalink) Old 08-15-2012, 09:21 AM
TwoCables's Avatar
It is for the P67 chipset, but the Z68 chipset seems to have a problem with it for some reason.
Optical Drive
Optical Drive
Corsair RM550x
Thermaltake Frio
CM 690
Operating System
Windows 10 Home
Keyboard
Mouse
Mousepad
Audio
X-Fi Titanium HD
Audio
post #10 of 10 (permalink) Old 09-06-2016, 08:07 AM
2ndLastJedi's Avatar
Rep: 1 (Unique: 1)
Hello , sorry to open this up again but i saw you mention the CPU spread spectrum and wanted to know if mine at 100.11x40.0 on a i5 6600k @ 4.0GHz should be turned off ?
Temps are 25-35C and TJMax is 74-78 .
Thanks
2ndLastJedi is offline
