[How To] Delid your Ivy Bridge CPU with out a Razor Blade! - Overclock.net - An Overclocking Community
post #1 of 1400 (permalink) Old 03-28-2013, 01:37 PM - Thread Starter
Linux Lobbyist
KuuFA's Avatar
Rep: 197 (Unique: 177)
Razorless De-liding
Welcome to the short and sweet guide to delid your Intel Ivybridge 3570k/3770k CPU These steps were developed by the local user fnarfbargle
Before we get started Here is an excellent place to read a few facts and to learn about the what,why, and how to(delid with a razor).
Alright to begin with gotta have a disclaimer:
We take no responsibility of your injures and the possibility of personal harm and destruction of your chip.
Doing any procedure where de-lidding is happening will obviously void your warranty.
While delidding this way is "easier" it can leave marks/Indentations on the side of the IHS This will not harm the CPU but may interfere with any aftermarket coolers if the Indentations are severe enough.
What I mean when I say Indentations! (Click to show)
Usually Caused by over tightening the vice
Now lets list what you need
You need a Vice (could have rubber arms or metal its up to you, Personally just use what you have). Some Useful Advice from Jayjr1105 on how to choose your vice (Click to show)
OK just some advice for people wanting to do this. I just tried 5 different Vice's in a shop and none of them would bite down on the CPU. (I am testing with a non soldered 775 Pentium). If the vice you use is an older vice with rounded off teeth, forget about doing it until you get a smaller electronics or precision vice. If a larger style shop vice is fairly new and still has good sharp corners on its jaw, that should be fine as well. You probably only have a 1/16 of an inch to bite down on.
Second a hammer! Or "Calibrated Hammer" biggrin.gif (The Favorited tool of Jeremy Clarkson!).
Some piece of extra wood (Needs to have a flat side)
The Cpu (if you can guess which socket it comes from KUDOS to you) Hint: its not 1155 biggrin.gif
Here is a quick video by the man himself fnarfbargle (Click to show)
More Videos By Adopters of this technique! (Click to show)
-Thanks to jamdox
Now onwards to the steps!
  1. You want to make sure your vice is secure(you could have it mounted to something or just have someone holding it opposite to the direction you are hammering)
  2. Proceed to clamp the IHS down Now you will find that your IHS has 2 "lips" or "ridges" you could clamp to, Now you want to clamp it on the ridge that is furthest away from the PCB(refer to pictures) You want to clamp it to the point where you can no longer move it by hand and it is secure. (Warning: Over tightening could lead to some Indentations left on your IHS Depending on the type of Vice). Some tips on how to align the CPU on the vice (Click to show)
    • one suggestion, I see most have been placing the chip with the long axis of the die in line with the strike direction. it may be better to place the cpu in the vise with the long axis of the die perpendicular just in case it whacks the far side of the IHS. Unlikely, but worked well in this direction too. - Thanks To Jpmboy
    • Took longer to get to the garage than I spent in it... This is a fantastic idea. I'm not sure if it was mentioned or not, but I would recommend placing the cpu in the vice so that the two little tabs/ears on the lid are resting on top of the jaws. This places the core(under the lid) parallel to the vice jaws. This way, when the lid starts to come loose and shift, it has more room to do so before hitting the core. Not that you should be hitting it THAT hard anyway... - Thanks to dbranger94
  3. Now after you have securely clamped it, You then want to pick up the piece of wood, Line up the flat side Horizontally against the PCB (see picture)
  4. Finally take the hammer and give it a few good solid whacks, If you have it clamped securely the CPU should not come loose, in an event that it should come loose then re-clamp it and proceed after a few good solid hits the PCB will separate from the IHS.
Some Optional Tips! (Click to show)
  • Suggest adding a longish adhesive tape to the PCB and the vice to reduce the risks of flying objects and damage, should help some what. - Thank you MacClipper
After you have Separated the IHS form the CPU You would need to "scrape" the glue/adhesive Off both the PCB and the IHS, Using a credit card worked great for me! For more tips on how to do this, Refer the the Delidded Club( linked above)
Here is a quick video I did on my 3770k Excuse me as I was quite nervous lol.
Here is a quick video I did on my 3770k Scraping off the Adhesive and how to apply CLU to the CPU die. Excuse me as I was quite nervous lol. (Click to show)
After "Scraping off the Adhesive you then proceed to apply TIM to the CPU die The most recommended TIM to apply on the die is Coollabroatory Ultra/pro here are some links on where to buy!
USA Links and I think International(Thanks to iwalkwithedead and WiSK for finding these links!) (Click to show)
Any questions and comments can be posted here!(If there are any changes to be made to the OP just leave a comment below and I'll change it ASAP(
MEMBERS LIST
To become a member just post a pic with your delidded CPU with a Hammer or vice or a piece of wood! and ill add you asap!
KuuFA is offline
post #2 of 1400 (permalink) Old 03-28-2013, 01:42 PM
512TBofRAM's Avatar
Rep: 12 (Unique: 10)
Thanks for the guide. It looks dangerous but if done properly, you'll have a safe de-lidded ship! Just in time for the new EK blocks thumb.gif
I hope I helped in the post above and I hope that you're satisfied with the information that I've given you. PM me if you need any advice outside of this thread; I'm always happy to help. If you're reading this in a news article, chances are the post isn't too resourceful. wink.gif
wheee.gifsniper.gif Can't touch this
512TBofRAM is offline
post #3 of 1400 (permalink) Old 03-28-2013, 01:43 PM
Rep: 33 (Unique: 30)
I've been wondering if there's a vise-less method of doing this. Can you just use a pair of 2x4's instead of the vise, and then have one end backstopped by a bunch of cinder blocks? (You would then need a 3rd piece of wood to hammer on)
Quit OCN. Done with overmoderation.
dr/owned is offline
post #4 of 1400 (permalink) Old 03-28-2013, 01:46 PM
PC Evangelist
ZealotKi11er's Avatar
Rep: 1800 (Unique: 1176)
Thank you so much. I will be doing it this weekend. Is there any chance the PC will rip from this?
Yamato
(10 items)
Ishimura
AMD Ryzen 7 3700X
ASUS TUF Gaming X570-Plus (Wi-Fi)
NVIDIA GeForce RTX 2080 Ti FE
G.SKILL Trident Z RGB (2x8GB) DDR4 3200MHz CL14
Samsung SM961 512GB
HGST DeskStar NAS 6TB
EVGA SuperNOVA 750 P2
Gamdias Chione M1A-280R
Fractal Design Meshify C TG
Operating System
Microsoft Windows 10 Pro 64 Bit
Intel Core i7-3770K @ 4.8GHz
ASRock Z77E-ITX
AMD Radeon Vega Frontier Edition
AVEXIR Blitz 1.1 16GB DDR3-2400MHz CL10
SanDisk Ultra II 960GB
Toshiba X300 5TB
EVGA SuperNOVA 750 G3
Corsair H100i GTX
Fractal Design Define Nano S
Operating System
LG OLED55C7P
Keyboard
Cooler Master MasterKeys MK750
Mouse
Finalmouse Air58 Ninja
ZealotKi11er is offline
post #5 of 1400 (permalink) Old 03-28-2013, 01:46 PM
oh wow... but a razor is 50 cents, a vise 50 bucks
dealio is offline
post #6 of 1400 (permalink) Old 03-28-2013, 01:48 PM - Thread Starter
Linux Lobbyist
KuuFA's Avatar
That sounds like plan but you would need to hold 2 sides of the IHS down, If you can achieve that with out it moving so much while hammering it would work.
As long as you hammer parallel to the PCB there isn't a chance as the adhesive would give first.
agreed this is a useful method to those who already have a vice, if have access to a vice. thumb.gif
I could see how a 50 dollar vice just used for a few seconds and then returned could be happening lol.
KuuFA is offline
post #7 of 1400 (permalink) Old 03-28-2013, 01:52 PM
PC Evangelist
A 4 inc vice is like $30. You can use it for other things too and much safer then the razer and faster.
Yamato
(10 items)
Ishimura
AMD Ryzen 7 3700X
Samsung SM961 512GB
Operating System
ASRock Z77E-ITX
Toshiba X300 5TB
Corsair H100i GTX
Operating System
LG OLED55C7P
Keyboard
Mouse
post #8 of 1400 (permalink) Old 03-28-2013, 01:52 PM
Who are you again?
iwalkwithedead's Avatar
Rep: 73 (Unique: 55)
This is true but that little .50 cents can kill your CPU much easier/quicker than that 50$ part would.
Like OP said, rent/borrow/buy then return many options lolz
EDIT: Or you can buy the vice and parts, then start delidding and selling the chips online for those who don't want to risk it their self.
iwalkwithedead is offline
post #9 of 1400 (permalink) Old 03-28-2013, 01:53 PM
malmental's Avatar
Rep: 376 (Unique: 153)
hmmm. I got all the tools to do that....
now I need the video on how to apply TIM.
(A.S.) - IT | CompTIA A+, Net+ | MCDST | PMP | DSCE (Dell)
US Navy Vet - GS-E (PO3)
daily driver | surround boi
Clubz... (Click to show)
malmental is offline
post #10 of 1400 (permalink) Old 03-28-2013, 01:54 PM
john1016's Avatar
Rep: 67 (Unique: 60)
That's a great idea.
Is there a way to fix any indent without making it more uneven?
How much temp difference does a (small) indent make?
My wife said "It's me or the computer!" I still miss her.
MINE
(17 items)
Wifes/backup rig
I7 7700k
Gigabyte Aorus Z270x Gaming K7
EVGA GeForce GTX 980 Ti SC
16gb Gskill Trident Z 3400
Samsung 850 EVO 500GB ssd
2tb cavier black
WD 2 tb
Optical Drive
BD RW
1000w coolermaster silent pro gold
Thermaltake water 3.0 Ultimate
coolermaster HAF 932 advanced
Operating System
Win 10 64bit
Dell Ultrasharp U2412M x3 surround
Dell 1804fpv
Keyboard
Ducky zero
Mouse
G500s
Audio
Klipsch Promedia 2.1
I5 2500K
AsRock Z68 Professional Gen 3
MSI 950 twin frozr
16gb ripjaws 1600
750 gb caviar black
512gb Mushkin Reactor ssd
750w seasonic gold
hyper 212plus
coolermaster HAF 912 advanced
Operating System
win7 home premium
Dell SE198WFP X3 surround
Keyboard
Logitech G710+
Mouse
G700
john1016 is offline
