Haswell Overclocking Guide [With Statistics] - Page 1961 - Overclock.net - An Overclocking Community
post #19601 of 19696 (permalink) Old 11-16-2017, 07:07 PM
Overclocker
JackCY's Avatar
Rep: 346 (Unique: 244)
It sure can help with Ring stability to volt it high, but having 5GHz core and under 4GHz ring will worsen performance a bit. Something like 4.2GHz ring would be fine and most chips can do it. I've tried the high ring voltage route but from my experience it's better to raise Vcore to get proper stability than to fake force it somehow with Vring. Chips differ though.
JackCY is offline
post #19602 of 19696 (permalink) Old 11-18-2017, 07:35 PM
Overclocking
Unknownm's Avatar
Rep: 391 (Unique: 306)
How does one find ring stability and voltage?
Personally for voltage I set AUTO voltage with current ring overclock. 42x says 1.280v with auto so little undervolt and its 1.260v
How about stability?
Sent from my HTC 10 using Tapatalk
Youtube
Retired: Unlock older bios , USB 2.0 @ 1000hz , [Dell M6400] Nvidia Quadro FX2700M / Intel QX9300
Gaming
(17 items)
SM-G960W
(12 items)
Ryzen 5 2600X @ 4100Mhz
Asus ROG Strix B450-F Gaming
06G-P4-1996-KR
F4-3200C16-8GVKB @ 3600Mhz
Samsung MZVLV128HCGR-00000
ADATA SU650
2x ST2000DM001-1ER164
ST1000LM024 HN-M101MBB
CP-9020056
RR-212E-20PK-R2
CC-9011035-WW
Operating System
Win 10 190318-1202
Samsung LU28E590DS/ZA
LG 22MP48HQ
Keyboard
Xtreme Gaming 8048064
Mouse
CH-9301011-NA
Audio
Fiio K5 Pro
Kryo 385
Adreno 630
4x 32-bit LPDDR4X
Samsung
SDSQUAR-128G-GN6MA
Li-Ion 3000 mAh (11.55 Wh)
Operating System
Android 9.0
Super AMOLED @ 1440 x 2960
Audio
WCD9341
Other
Spectra 280 ISP
Other
Hexagon 685 DSP
Other
X20 modem & Wi-Fi
Unknownm is offline
post #19603 of 19696 (permalink) Old 11-18-2017, 11:43 PM
Shweller's Avatar
Rep: 9 (Unique: 9)
I have been running my 4670k overclocked for the past 4 years. Between x44-46 on the multiplier with voltage set to auto. The only time use manual voltage is when stress testing the cpu. Voltage is between 1.2 to 1.35 in auto as long as your cooling solution's adequate your over clock will be sustained by using Auto on your overclock.
Shweller is offline
post #19604 of 19696 (permalink) Old 11-19-2017, 12:44 PM
Technodox's Avatar
Rep: 5 (Unique: 4)
for ring its a simple formula for the 4790k which I think holds true from most of those, but the 4690k may be different, in that it has 6MB cache.
44 core, 42 ring = same voltage 42 core, 40 ring= same voltage 46 core, 44 ring = same voltage
and the core to ring ratio doesnt matter, once you have the core voltage, the ring is the same voltage -200Mhz, can be used in any combination.
Technodox is offline
post #19605 of 19696 (permalink) Old 11-20-2017, 09:39 AM
El Rotten
SgtRotty's Avatar
Rep: 3 (Unique: 3)
I have found that mine is 300mhz difference,same volts
i7 [email protected]/4.8 - 1.385v
asus prime-a z370
3200c14 gskill ripjawsV @ 4000 16-16-16-41 1.45v
1x EVGA rtx2070 super XC Ultra+
850w evga super nova G2
SgtRotty is offline
post #19606 of 19696 (permalink) Old 11-27-2017, 04:23 PM
d0mini's Avatar
Rep: 65 (Unique: 60)
I made a post here not too long ago about how better cooling gave me better overclocking results. I’ve since realised it was in fact down to me changing my BIOS’ microcode from 19 to the latest (22, released in 2017).
The water cooling loop and delid had very little to do with it. With the newer microcode an extra 100 MHz requires roughly 0.04v less than it otherwise would: 4.8ghz needs 1.3 instead of 1.34, 4.9 1.36 instead of 1.4, etc.
I cannot recommend enough that anyone still actively overclocking their haswell CPUs try updating their microcode. It’s very easy and can be done through the tool and instructions in this guide: https://www.win-raid.com/t154f16-Tool-Guide-News-quot-UEFI-BIOS-Updater-quot-UBU.html
You’ll need to download MMTool.exe and put it into the folder with the UBU.bat file. A copy can be found here under the link MMTool (aptio 5): http://voltground.com/haven/threads/13/
Flashing your modded BIOS must be done through USB BIOS Flashback on ASUS boards, or some other similar method for others to get around safety checks. Obviously I’m not responsible if you damage your hardware/brick your motherboard.
That being said, if anyone tries this and gets similar results, please say! I haven’t seen this posted at all and I suspect that’s because people lost interest in testing microcode when Haswell left the CPU limelight. Happy overclocking! smile.gif
Intel Devil's Canyon Owners Club
"i can still turn the computer on, it just catches on fire when i do...", from this wonderful thread.
[email protected], 1.36v (4.5GHz uncore)
Maximus VII Impact
MSI 980 Ti Gaming 6G
Corsair Dominator Platinum 16gb 2133 CL9
2x 840 EVO 500GB
Toshiba XG3 1TB (M.2 NVMe SSD)
MX 500 2TB
EVGA G2 850 PSU
EK Supremacy Evo & VGA
11x ML 120 PRO fans
5x Gentle Typhoons 1850rpm intake, 1x GT 1450rpm exhaust
PE-240; XT45 120; SR-2 360 multiport; XSPC RX 360; 2 x XSPC RX 480 rads
Corsair Commander Pro
Aquaero 6 LT; Splitty 9; Hubby7
2 x Ek Xres 140 pump/res
Phanteks Enthoo Elite
Operating System
windows 10
Acer Predator XB271HU
Keyboard
Corsair Strafe RGB
Mouse
Logitech G Pro Wireless
Mouse
MX Master AMZ
Mousepad
XXL neoprene mousemat goodness
Audio
Sennheiser HD 650
Audio
Senheisser Game Zero SE
Audio
Bose companion 20
Audio
GSX 1000
Audio
SMSL M6
[email protected], 1.23v (4.5GHz uncore)
Maximus VII Impact
2x 840 EVO 500GB
Corsair SF 450
2x Gentle Typhoons 1850rpm exhaust
PE-240 radiator
EK-DDC 3.2 PWM
M1 NCASE reservoir
NCASE M1
Operating System
windows 10
Acer Predator XB270HU
Keyboard
Corsair Strafe RGB
Mouse
Logitech G502
Mousepad
Audio
Sennheiser HD 650
Audio
Bose companion 20
d0mini is offline
post #19607 of 19696 (permalink) Old 11-27-2017, 04:50 PM
Overclocking
Unknownm's Avatar
what's with 19 being best overclocker? I did this so do I just flash the BIOS is there a chance it will brick?
Also could you update others like LAN/NVMe/RAID/GOP chances of those bricking?
Youtube
Gaming
(17 items)
SM-G960W
(12 items)
06G-P4-1996-KR
ADATA SU650
CP-9020056
RR-212E-20PK-R2
CC-9011035-WW
Operating System
Win 10 190318-1202
LG 22MP48HQ
Keyboard
Mouse
CH-9301011-NA
Audio
Fiio K5 Pro
Kryo 385
Adreno 630
4x 32-bit LPDDR4X
Samsung
SDSQUAR-128G-GN6MA
Operating System
Android 9.0
Audio
WCD9341
Other
Spectra 280 ISP
Other
Hexagon 685 DSP
Other
X20 modem & Wi-Fi
Unknownm is offline
post #19608 of 19696 (permalink) Old 11-27-2017, 04:56 PM
Optimal Pessimist
GeneO's Avatar
Rep: 126 (Unique: 96)
Originally Posted by d0mini View Post
I made a post here not too long ago about how better cooling gave me better over locking results. I’ve since realised it was in fact down to me changing my BIOS’ microcode from 19 to the latest (I think 22, the one released in 2017).
The water cooling loop and delis had very little to do with it. With the newer microcode an extra 100 MHz requires roughly 0.04v less than it otherwise would: 4.8ghz needs 1.3 instead of 1.34, 4.9 1.36 instead of 1.4, etc.
I cannot recommend enough that anyone still actively overclocking their has well CPUs try updating their microcode. It’s very easy and can be done through he tool and instructions in this guide: https://www.win-raid.com/t154f16-Tool-Guide-News-quot-UEFI-BIOS-Updater-quot-UBU.html
Flashing your modded BIOS must be done through USB BIOS Falshback on ASUS boards, or some other similar method for others to get around safety checks. Obviously I’m not responsible if you damage your hardware/brick your motherboard.
Thanks. I updated to 22 microcode some time ago, but I don't think I checked to see if I could lower volts, just that it was still stable. I will have to try it.
FDR4-8086k
(23 items)
8086k 5.1/4.8 GHz @ 1.28v, 5.2/4.9 GHz @ 1.326v (AVX 0)
Gigabyte Aorus Master
Asus GTX 2070 Super A8GB
64GB Trident Z RGB 3200 CL14 @3600 Cl16
Samsung 850 EVO 1TB
Western Digitial Caviar Black 2 TB in USB 3.0 enclosure
Western Digital Black 6 TB
Western Digitial Caviar Green in USB 3.0 enclosure
Samsung 960 Pro 512 GB
Samsung 860 EVO 1TB
Seasonic Prime Ultra Titanium 750W
Noctua NH-D15 (only middle NF-A15 Chromax)
4 x Noctua NF-A14 Chromax black swap
Noctua NF-F12 Chromax black swap
Fractal Design R4
Operating System
Windows 10 Pro 64 bit
Eizo CG2730
ViewSonic VP2768
Keyboard
Cooler Master Quickfire Rapid TKL
Mouse
Logitech G305
Mouse
perixx dx-2000
Audio
On Board ALC1220-VB/ESS SABRE 9118 DAC
Audio
Vanatoo Transparent One
GeneO is offline
post #19609 of 19696 (permalink) Old 11-27-2017, 05:15 PM
Overclocking
Unknownm's Avatar
I just updated everything besides my iGPU. I could flash the BIOS through mflash (BIOS) and everything works fine. RAID updated and CPU microcode updated
Now 4600Mhz NEEDS 1.360v++ to be stable prime95. I'm 4600Mhz with 1.30v, lets see if it passes prime95
EDIT: Nothing. BSOD right away like nothing changed. However everything else got updated so thanks REP+
Youtube
Gaming
(17 items)
SM-G960W
(12 items)
06G-P4-1996-KR
ADATA SU650
CP-9020056
RR-212E-20PK-R2
CC-9011035-WW
Operating System
Win 10 190318-1202
LG 22MP48HQ
Keyboard
Mouse
CH-9301011-NA
Audio
Fiio K5 Pro
Kryo 385
Adreno 630
4x 32-bit LPDDR4X
Samsung
SDSQUAR-128G-GN6MA
Operating System
Android 9.0
Audio
WCD9341
Other
Spectra 280 ISP
Other
Hexagon 685 DSP
Other
X20 modem & Wi-Fi
Unknownm is offline
post #19610 of 19696 (permalink) Old 11-28-2017, 12:22 AM
d0mini's Avatar
Hey guys, happy you're all trying it and glad you're at least happy with the updated modules even if it didn't help with overclocking! I guess before 22 came out, 19 was the best for overclocking, and that's why it has that message. My board had 19 on its BIOS as standard so for me at least 22 is far superior.
I also updated all my other BIOS modules without any issues, there's always a chance of bricking your board with a BIOS flash but it shouldn't be any greater than usual after using this tool, it seems pretty safe to me. If it's not giving everyone better results then maybe microcode benefits aren't as straightforward as I was hoping.
For me it is very obvious. I flashed back to microcode 19 and couldn't get 4.9GHz stable at 1.36 volts, crashed in x264 immediately. With 22 back in it can run all night.
Maximus VII Impact
2x 840 EVO 500GB
MX 500 2TB
EVGA G2 850 PSU
11x ML 120 PRO fans
Operating System
windows 10
Keyboard
Corsair Strafe RGB
Mouse
Mouse
MX Master AMZ
Mousepad
Audio
Sennheiser HD 650
Audio
Audio
Bose companion 20
Audio
GSX 1000
Audio
SMSL M6
Maximus VII Impact
2x 840 EVO 500GB
Corsair SF 450
PE-240 radiator
EK-DDC 3.2 PWM
M1 NCASE reservoir
NCASE M1
Operating System
windows 10
Keyboard
Corsair Strafe RGB
Mouse
Logitech G502
Mousepad
Audio
Sennheiser HD 650
Audio
Bose companion 20
d0mini is offline
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
