Haswell Overclocking Guide [With Statistics] - Page 1966 - Overclock.net - An Overclocking Community
post #19651 of 19696 (permalink) Old 01-15-2018, 09:24 PM
LagunaX's Avatar
Rep: 14 (Unique: 5)
I dropped my 4.8ghz voltage from 1.24v to 1.23v for x264 16 run testing, but 4.9ghz remained the same at 1.28v after the microcode bios flash:
https://www.overclock.net/t/1643053/improved-overclocking-for-haswell-with-updated-microcode-update-cpu-microcode-through-software/180#post_26550836
LagunaX is offline
post #19652 of 19696 (permalink) Old 01-18-2018, 03:03 PM
Silmatharien's Avatar
Rep: 0
I'm impressed this thread is still going. Currently working on my overclock.
Got my 4670k going at 4.6 GHz with x46 uncore multiplier on air. Vcore is 1.21V and cache voltage is 1.2V. Prime95 stable for 8.5 hours when I stopped stress testing. I haven't optimized the cache voltage yet. We'll see how far I can take this.
Silmatharien is offline
post #19653 of 19696 (permalink) Old 01-18-2018, 06:43 PM
EarlZ's Avatar
Rep: 27 (Unique: 25)
Is your 4.6Ghz unstable if you leave the cache voltage at stock ?
9700K / Gigabyte Z390 Master / Gigabyte 2080TI Gaming OC / 16GB G.Skill Trident Z RGB / Samsung Evo 860 & 850 500GB / Creative Sound Blaster Z / Acer Predator X34P
EarlZ is offline
post #19654 of 19696 (permalink) Old 01-18-2018, 07:25 PM
Rep: 0
I need to mess with it and see. I got stable at 4.6 GHz once I increased vcore to 1.21 and already had cache voltage at 1.2v. Gonna run a stress test at the auto cache voltage and see what happens.
post #19655 of 19696 (permalink) Old 02-25-2018, 01:52 AM
Rep: 0
Post
hello just want to check here. i have oc my 4690[email protected] ghz at Vcore 1.277v and vccin is at 1.344v is it save?
temp at max 86c in prime95.
theghost05 is offline
post #19656 of 19696 (permalink) Old 02-26-2018, 12:38 PM
gonX's Avatar
Rep: 1157 (Unique: 647)
Quote: Originally Posted by theghost05 View Post
hello just want to check here. i have oc my [email protected] ghz at Vcore 1.277v and vccin is at 1.344v is it save?
VCCIN should be kept at atleast 0.5v above VCore as stated in the OP:
keep your Vccin or total CPU voltage to 0.5v above Vcore.
This is because Haswell has integrated circuitry to manage its Vcore manually, and all buck converters (the DC to DC converters used inside the chip) need extra voltage to step down to their designated voltage.
They're tuned for specific duty cycles, the duration of which are determined by the voltage delta between VCCIn and true VCore.
Hence, a 0.4-0.7v delta is needed depending on CPU and overclock.
Intel specs says 0.4v delta at least.
What does OCN offer as a site?
What are infractions and warnings?
How to make quality posts
#well
(19 items)
Intel Core i7 4770k
Gigabyte Z87X-UD4H
Sapphire RX 580
2x G.Skill F3-2400C10-8GTX
Samsung 840 EVO
Optical Drive
Generic DVD±RW Burner
Corsair TX850
Noctua NH-D14
Fractal Design Core 2500
Operating System
Arch Linux
Dell U2711
Samsung SyncMaster 2233
LG W2453TQ
Keyboard
Ducky DK9008G2, Cherry MX Blue, Overclock.net Edition
Mouse
Logitech G303
Mouse
Xtrfy GP3 HeatoN
Audio
Beyerdynamic DT-770 80 Ohm
Audio
AntLion ModMic v3
Audio
M-Audio Fast Track USB
gonX is offline
post #19657 of 19696 (permalink) Old 02-26-2018, 02:51 PM
kikimaru024's Avatar
Rep: 0
Babby's first OC
5820K / 1.149v / 4.00GHz
Noctua NH-U14S / Cooler Master Master Case Pro 3
Name:	stabilitytest 2018-02-26.png
kikimaru024 is offline
post #19658 of 19696 (permalink) Old 04-02-2018, 12:29 PM
AmcieK's Avatar
Rep: 0
Hello .
I have a problem with my i5 4670k . For a long time my processor was oc'd to 4.4 , 1.26 V without any problems . for several days i have freezes on PC and buged sound when i playing bf1 ... Only restart help. I test memory in memtest and is ok. I try prime 95 and por few sec freez and BS https://i.imgur.com/jIiOAgn.jpg . I try add more voltage but still the same freez on Prime. Ok Load Default seting in bios and try prime95 after few second the same problem ... I try second bios but the same problem . :/ Sometime ago i have problem with boot loop with post code 32 ? Its my motheboard ded ?
CPU: Intel i5 8600k
Mobo: Asrock z730 extreme 4
Ram:G.Skill Trident Z Rgb 2x8GB, 3000MHz, CL16
GPU: SAPPHIRE Nitro+ Radeon RX Vega 56
SSD: Plextor 128GB M5S , Goodram Iridium pro 240
PSU: Seasonic Focus Gold 650W
CASE: Phanteks Enthoo Evolv OS: Windows 10 64 Bit MOUSE:Mionix Avior 7000
AmcieK is offline
post #19659 of 19696 (permalink) Old 04-02-2018, 01:23 PM
Overclocking
Unknownm's Avatar
Rep: 391 (Unique: 306)
Quote: Originally Posted by AmcieK View Post
Hello .
Could be anything. Sounds like more cpu.
Could you list your voltages or post screen shot of all voltages and overclock settings?
Sent from my HTC 10 using Tapatalk
Edit: just saw the screenshot. 101 error is cpu related, try more vcore, input, sa, vuncore.
Youtube
Retired: Unlock older bios , USB 2.0 @ 1000hz , [Dell M6400] Nvidia Quadro FX2700M / Intel QX9300
Gaming
(17 items)
SM-G960W
(12 items)
Ryzen 5 2600X @ 4100Mhz
Asus ROG Strix B450-F Gaming
06G-P4-1996-KR
F4-3200C16-8GVKB @ 3266Mhz
Samsung MZVLV128HCGR-00000
ADATA SU650
ST2000DM001-1ER164
ST1000LM024 HN-M101MBB
CP-9020056
RR-212E-20PK-R2
CC-9011035-WW
Operating System
Win 10 190318-1202
Samsung LU28E590DS/ZA
LG 22MP48HQ
Keyboard
Xtreme Gaming 8048064
Mouse
CH-9301011-NA
Audio
Fiio K5 Pro
Kryo 385
Adreno 630
4x 32-bit LPDDR4X
Samsung
SDSQUAR-128G-GN6MA
Li-Ion 3000 mAh (11.55 Wh)
Operating System
Android 9.0
Super AMOLED @ 1440 x 2960
Audio
WCD9341
Other
Spectra 280 ISP
Other
Hexagon 685 DSP
Other
X20 modem & Wi-Fi
Unknownm is offline
post #19660 of 19696 (permalink) Old 04-13-2018, 01:21 AM
zerophase's Avatar
Rep: 1 (Unique: 1)
Just saw a voltage spike on vccio to 1.491 when I started aida64 with the fpu, cpu and cache test turned on. I have vccio set to 1.15. I have 128gb installed at 2666. Is that reading most likely a glitch in software? Are there any power management settings or features on the cpu I should disable?
zerophase is offline
