Haswell Overclocking Guide [With Statistics] - Page 1969 - Overclock.net - An Overclocking Community
post #19681 of 19692 (permalink) Old 09-09-2018, 07:36 AM
Linux Lobbyist
Rep: 0
hi before one year i did overlock my 4770k from the program asus suit 3 but i had some problems
can you help me to overclock my 4770k from the bios of asus z87 deluxe?
i have take fotos the pictures from my asus z87 deluxe for to help me to overclock my 4770k.
[​IMG]
can you help me which values to put in every field from these 2 fotos i have taken from asus z87 deluxe?
can you help me please in these 2 fotos>??> to put the values??
did you see the the 2 fotos please??
I HAVE http://www.coolermaster.com/cooling/...r/nepton-240m/
AND PSU http://www.coolermaster.com/powersup...tt-maker-1500/
dimitrios2030 is offline
post #19682 of 19692 (permalink) Old 09-09-2018, 08:01 AM
Linux Lobbyist
Rep: 0
i want to to overclock my 4770k to 4,,4 or 4,5
what values i will put for core ratio limit and min cpu cash ratio and max cpu cash ratio?/ ??
also
in cpu core voltaGE WHAT I WILL PUT?
AND ALSO IN CPU CPU CORE VOLTAGE OVERIDE WHAT I WILL PUT?>?
ALSO DO I NEED ANOTHER THINGS TO PLAY WITH IN ASUS Z87 DELUXE??
I MEAN FOR THE OVERCLOCKING I NEED ONLY
core ratio limit
min cpu cash ratio
max cpu cash ratio
cpu core voltaGE
CORE VOLTAGE OVERIDE ??
post #19683 of 19692 (permalink) Old 09-12-2018, 06:51 AM
SgtRotty's Avatar
Rep: 3 (Unique: 3)
Refer to page 1. There is a complete guide on what to do. Expect to do some testing back and forth with your settings. To make things easier, leave cache at auto multiplier and auto volts. Bump core multiplier and volts and test after each bump. Watch your temps, keep it within your safe limits! Takes alot of time
i7 [email protected]/4.8 - 1.424v
asus prime-a z370
3200c14 gskill ripjawsV @ 4000 16-16-16-37 1.45v
1x MSI 980ti
850w evga super nova G2
SgtRotty is offline
post #19684 of 19692 (permalink) Old 09-25-2018, 11:30 AM
Linux Lobbyist
Rep: 0
My 4790k overclocks but can't decide which overclock to go with.
5ghz 1.373 vid=1.403-vcore 2.05 Input voltage Temp 73c
4.9 1.325 vid=1.355-vcore 1.95 Input voltage Temp 70c
4.8 1.27 vid=1.3-vcore 1.85 Input voltage Temp 67c
Temperatures OCCT Linpack no avx
What clocks would ya use if it were your cpu?
Giggla_707 is offline
post #19685 of 19692 (permalink) Old 09-25-2018, 12:49 PM
1689 Federalist
lightsout's Avatar
Rep: 239 (Unique: 206)
5ghz if you want bragging rights.
I'd go with 4.8, much lower vcore, better temps, you'll never notice the difference in real usage anyways.
Black Box
(11 items)
R5 2600X
Asus Strix B450-I
EVGA RTX 2060 Ultra XC
GSkill 16gb 3200c14 Flare
500gb SSD
EVGA G1+ 850
Macho Rev B
NZXT H200 Black
LG 32GK650F-B 1440p 144hz
Mouse
Sensei Raw
Audio
Sony Core Bookshelves
lightsout is offline
post #19686 of 19692 (permalink) Old 09-25-2018, 01:59 PM
bond32's Avatar
Rep: 91 (Unique: 70)
That's almost identical to my 4790k... Been running at 4.8 1.3V for close to the time I took it out of the box at it's release. Mine will also bench at 5.0, but it's not stable.
If I remember, mine will also run at 4.6 at 1.2V, which is probably what I should have been doing...
bond32 is offline
post #19687 of 19692 (permalink) Old 12-06-2018, 11:00 AM
pininfarina575's Avatar
Rep: 0
Hi yall..
now that my 4770k is not in my main PC anymore, I felt comfortable trying to push it a bit more... and I'm cooling it with a spare H80i I had around....
But oh my mine seems to be total dud... I've read maybe the first 20 pages of this thread (not goona read through 1900+ pages haha) and my 4770k must be the worst one by far... here's how bad it is..
I just put multiplier to 4.1 to start. Ran IBT standard 10 and the moment IBT starts going, the package temps hit 100 celcius and starts thermal throttling. the cooler doesn't even have time to pick up any heat... CPU package temp just jumps from ~34 idle to 100 within a second or two... The vcore voltage was set to 1.2 (with .03or 0.04 offset) to start. So I tried lowering the multiplier to 39, which equates to the stock boost clock... same thing... CPU package temp shoots straight up to 100 degrees... I've tried re-seating the cooler a couple times already with different thermal compounds, so I'm sure it's not the issue. So on 39x multiplier, I lowered vcore voltage to 1.15+ 0.03 or 0.04 offset) and it still does the same thing... I keep lowering the vcore voltage lower and lower, and still shoots straight to 100degree / starts throttling...
I thought maybe there's a setting in my Asrock Z87 Fatal1ty Killer board that boosts vcore voltage automatically, but I verified with CPU-Z and HWmonitor that vcore voltage is around 1.1~2 the brief moments I let IBT run...
The computer never crashes though... I let IBT run with CPU getting throttled a few times, just to see if the comp crashes after getting tired of the temp going crazy even with stock speed / low voltage.. never crashes... that's the weird part...
Anyone have this bad of an example??
Main Gaming PC
(8 items)
Wife's Gaming PC
(7 items)
PLEX
(9 items)
Intel Core i9 9900k 5.0Ghz 1.290v AVX Offset 0
Gigabyte Z390 Aorus Master
EVGA GeForce RTX 2080 Ti FTW3 Ultra
Corsair Vengeance LPX 3200Mhz 16GB (2x8GB)
Samsung 970 Pro 512GB + Samsung 860 Evo 1TB
EVGA SuperNOVA G3 850W
Corsair H150i Pro
Fractal Design Define R6
Intel Core i5 9600k
Gigabyte Z390 Aorus Pro
Gigabyte GeForce RTX 2080 Gaming OC
Corsair Vegeance LPX 3000Mhz 16GB (2x8GB)
Samsung 860 Evo 500GB + Western Digital Blue 1TB 7200rpm HDD
SeaSonic 750W
Corsair H100i Pro
Intel Core i5 4670k
MSI CSM-H87M-G43
Gigabyte GeForce GTX770 2GB Windforce 3x
XPG 1600Mhz 32GB (4x8GB)
Samsung 860 Evo 500GB + 4x 4TB WD Red Pro in RAID 10 + 2x 1TB WD Blue 7200rpm in RAID 0
Rosewill Capstone 550W
Corsair H80i
Fractal Design Node 804
Other
StarTech RAID Controller (Marvell)
pininfarina575 is offline
post #19688 of 19692 (permalink) Old 12-06-2018, 12:34 PM
white owl's Avatar
Rep: 124 (Unique: 95)
It doesn't sound like a dud, sounds like it's hot. It has a tiny cooler plus I'm assuming it's not delidded. Plus you're using a test that's made to get the CPU as hot as possible but it's not really a strss test. What you've described is exactly what I'd expect.
Quote: Originally Posted by SpeedyVT
If you're not doing extreme things to parts for the sake of extreme things regardless of the part you're not a real overclocker.
Quote: Originally Posted by doyll View Post
The key is generally not which brands are good but which specific products are. Motherboards and GPUs are perfect examples of companies having everything from golden to garbage function/quality.
Hot n Bothered
(12 items)
4790k 4.7Ghz
Asus Sabertooth Z97 MkII 2
EVGA GTX 1080 SC
16gb G.Skill Sniper 2400Mhz
2x Kingston v300 120gb RAID 0
WD Blue
Seasonic 620w M12 II EVO
Cooler Master 212 Evo
Corsair 450D
Operating System
Windows 10
Nixeus EDG27
Other
I have pretty lights.
white owl is offline
post #19689 of 19692 (permalink) Old 12-29-2018, 03:05 PM
Rep: 0
This guide is still working great as a reference point. I've used it for my 4690k, G3258, and 4770k. However, I think it is time we move up to a x265 stress test for better stability. If whoever made the x264 stress test or can edit it to use the x265 that would be much appreciated.
I got my rigs running the x264 for 24 hours. However they all would crash in actual gaming (wow in this case), and on x265 encoding. I dropped all the multiplier on the rigs down by 1x, and voltage down correspondingly, and they've all been stable for gaming and x265 encoding since. They were on the high end of their max so voltage was up to around 1.4v on all those configs, but temps were not reaching tjmax. Dropping them down by 1x multipliler dropped the voltage levels back down closer to 1.3v which makes me more comfortable for their life span anyways. I've now resorted to just doing handbrake x265 as the benchmark.
I think x265 is more complex and hence a little more demanding than x264 and seems to be more realistic to the peak gaming loads I'm using, but not as extreme as prime95 which I'd never hit from just gaming.
*I'll be trying out this http://hwbot.org/benchmark/hwbot_x265_benchmark_-_4k/ (it also has option for 1080p)
same at any res.
**I guess this is pretty much what I was asking for http://wp.xin.at/archives/4519 but again the test is just so long, I wish it was in shorter loops. I might try to cut the video file down to make the loop smaller if it has a built in loop function.
Huy Tran is offline
post #19690 of 19692 (permalink) Old 12-29-2018, 03:54 PM
white owl's Avatar
I just use P95. It and other tests are mentioned in the guides.
Small FFT for 2 hours on the core
Small FFT for 2 hours on the cache
Once you enable XMP or start going past it you can run Blend for 2 hours
Once I'm done clocking everything I'll run Blend for around 6 hours to test the whole system.
If I set my vcore with any other stress test I'll get crashes in games.
Hot n Bothered
(12 items)
4790k 4.7Ghz
EVGA GTX 1080 SC
WD Blue
Corsair 450D
Operating System
Windows 10
Nixeus EDG27
Other
