Haswell Overclocking Guide [With Statistics] - Page 1970 - Overclock.net - An Overclocking Community
post #19691 of 19696 (permalink) Old 12-29-2018, 04:54 PM
white owl's Avatar
Rep: 136 (Unique: 103)
I just use P95. It and other tests are mentioned in the guides.
Small FFT for 2 hours on the core
Small FFT for 2 hours on the cache
Once you enable XMP or start going past it you can run Blend for 2 hours
Once I'm done clocking everything I'll run Blend for around 6 hours to test the whole system.
If I set my vcore with any other stress test I'll get crashes in games.
Quote: Originally Posted by SpeedyVT
If you're not doing extreme things to parts for the sake of extreme things regardless of the part you're not a real overclocker.
Quote: Originally Posted by doyll View Post
The key is generally not which brands are good but which specific products are. Motherboards and GPUs are perfect examples of companies having everything from golden to garbage function/quality.
Hot n Bothered
(12 items)
4790k 4.7Ghz
Asus Sabertooth Z97 MkII 2
EVGA GTX 1080 SC
16gb G.Skill Sniper 2400Mhz
2x Kingston v300 120gb RAID 0
WD Blue
Seasonic 620w M12 II EVO
Cooler Master 212 Evo
Corsair 450D
Operating System
Windows 10
Nixeus EDG27
Other
I have pretty lights.
white owl is offline
post #19692 of 19696 (permalink) Old 03-19-2019, 06:48 AM
Rep: 0
i5-4670k 4.6OC
As I consider myself an overclock beginner, I tested my setup with prime 95 (with AVX off) for 8h and it was completely stable, but running CSGO low setting (only CPU demanded) BSOD me during gameplay quite early, in first maybe 20min or even earlier. And I was not even using fps_max 0 which pushes processor to run as hard as possible, but locked myself at 320 fps. Any clue why?
onynem is offline
post #19693 of 19696 (permalink) Old 03-20-2019, 09:35 AM
Overclocker
JackCY's Avatar
Rep: 345 (Unique: 244)
Yeah, Prime95 is useless for testing stability. It's too simple. It's a heat generator nothing more.
JackCY is offline
post #19694 of 19696 (permalink) Old 08-09-2019, 03:58 PM
Castaa's Avatar
Rep: 165 (Unique: 137)
Sorry to necro this thread. But I cannot get even 4.2Ghz stable. It'll boot but I'll get random crashes just using the computer at the desktop without even stress testing CPU. All I'm doing is upping the voltage to as high as 1.3V. Aside from increasing the voltage everything else is stock settings aside using with an 212 EVO cooler with 2 fans. Mobo is a Gigabyte GA-Z97-D3H, with the newest firmware installed.
My best stable is 4.1 GHz. Am I just a big silicon lottery loser or is there something else to try?
Intel Core i5-4670K
Gigabyte GA-Z97-D3H
PowerColor Radeon HD7870 Myst (Tahiti LE)
Samsung MV-3V4G3 4×4 GB DDR3-1600
Crucial M4 SSD 256 GB
WD Green WD15EARS 1.5 TB
Cooler Master Real Power Pro 550W
Cooler Master Hyper 212 EVO
NZXT LEXA
Operating System
Windows 10 Pro
Viewsonic VX2268WM 120Hz
Keyboard
Redragon K552-N KUMARA
Mouse
HP VoodooDNA Gaming Mouse
Audio
Samson SR850 Headphones
Castaa is offline
post #19695 of 19696 (permalink) Old 08-09-2019, 05:23 PM
JimmyMo's Avatar
Rep: 6 (Unique: 6)
mispost
JimmyMo is offline
post #19696 of 19696 (permalink) Old 08-16-2019, 02:25 PM
Technodox's Avatar
Rep: 5 (Unique: 4)
uneven temperatures
In cinebench benchmark, i have upgraded the paste to noctua nh-1 and now the cores are uneven, you can see core 1 is 75c and core 4 is 61c, not sure whats going on.
Technodox is offline
