The GIGABYTE Z97X Overclocking Guide - Page 4 - Overclock.net - An Overclocking Community
post #31 of 286 (permalink) Old 05-30-2014, 07:25 AM
MaKe OuT's Avatar
Rep: 7 (Unique: 7)
Ran x264 overnight set to 20 loops. Woke up to a fail. This was my first evening stability testing on this z97 board. all previous testing done on a z87 board. Same chip. Interestingly, I always bsod when failing stability test on z87. typically code 101. But, on this z97 board there is no bsod. I think it just reboots and has a window that states that Windows has recovered from some failure. Not a big deal, but does anyone know why this is?
So I need to look over my notes on my previous z87 stability search as I thought for sure I found stability at the x44 cpu multi. I frickin failed to be stable on this z97 board with a x43 multi at 1.34 Vcore setting which goes to 1.35 something volts under load. The uncore was locked at x35 multi and 1.203V. The VRIN was set to 2.2 volts and increased the same as Vcore did under load. Temps were good around 72C hottest core. I am just bummed that I cannot easily pass x264 overnight at x43 yet.
Any ideas?
MaKe OuT is offline
post #32 of 286 (permalink) Old 05-30-2014, 07:32 AM - Thread Starter
Sin0822's Avatar
Rep: 2037 (Unique: 1171)
Any ideas?
just copy the settings over from the Z87, was your Z87 a GBT? if it was just copy them over.
Sin0822 is offline
post #33 of 286 (permalink) Old 05-30-2014, 07:36 AM
MaKe OuT's Avatar
Rep: 7 (Unique: 7)
that's the problem. it was an Asus M6 Hero. I am trying to get used to the GB bios still as I am still familiar with Asus only. So far (very limited time on the board) I have failed to match the stability I had on the Hero. I am confident that it is simply that I need to change some settings. I just need to figure out what those are.biggrin.gif
MaKe OuT is offline
post #34 of 286 (permalink) Old 05-30-2014, 03:00 PM
marrawi's Avatar
Rep: 2 (Unique: 2)
You are awesome, Sin! Thank you! let's see if I can overcome the 4.6 wall on my 4770K!
marrawi is offline
post #35 of 286 (permalink) Old 05-30-2014, 08:50 PM
marrawi's Avatar
Rep: 2 (Unique: 2)
That's a negative, couldn't go beyond 4.6Ghz. Here are the settings I tried:
CPU Clock Ratio: 47x
XMP: Enable and Disabled
Uncore Ratio: Auto and 40x
C1E: Disable
C6/C7: Disable
CPU Thermal Monitor: Disable
C3: Disable
EIST: Disable
Voltage:
CPU VRIN Loadline Calibration: Extreme
CPU Phase Control: Extreme Performance
VRIN Override: 2.0 - 2.2v
VCore: 1.375v - 1.43v
Ring Voltage: 1.115v - 1.2v
Went back to stable 4.6 settings:
CPU Clock Ratio: 46x
XMP: Enable @ 2400Mhz
Uncore Ratio: 40x
C1E: Disable
C6/C7: Disable
CPU Thermal Monitor: Auto
C3: Disable
EIST: Disable
Voltage:
CPU Phase Control: Auto
VRIN Override: 1.9v
VCore: 1.375v
marrawi is offline
post #36 of 286 (permalink) Old 05-30-2014, 09:24 PM
Cyro999's Avatar
Rep: 537 (Unique: 329)
C1E: Disable
C6/C7: Disable
C3: Disable
EIST: Disable
Voltage:
Uncore Ratio: 40x
C1E: Disable
C6/C7: Disable
C3: Disable
EIST: Disable
Voltage:
VRIN Override: 1.9v
VCore: 1.375v
You might just need more vcore. I have to go from like 1.245 bios to 1.375 bios for 4.5 to 4.7. That's adding like 0.06 then 0.07 for 100mhz. If you tried 1.43 in bios already though - that's already [email protected], so i wouldn't suggest going to like 1.47 for 24/7. Probably best staying @46
Triple check vcore vs vrin (that you have turbo/extreme llc on vrin, and a good number for it) then add 0.01 vcore
i think some of these haswell boards even vary slightly in the amount of vcore that they give over what you set in the bios - giga seems to be +0.02, but i've seen volts on asus suggesting +0.03 for example (it reads as IA voltage or something in hwinfo)
You might have a bluescreen code recorded that didn't get shown to you, bluescreenview (the program) can show you that. Restart = typically very close to stability
I don't believe in "good enough"~!!
240hz / gsync / low persistence is AWESOME
Cyro999 is offline
post #37 of 286 (permalink) Old 05-31-2014, 12:37 PM
MaKe OuT's Avatar
Rep: 7 (Unique: 7)
Yes, the recommended settings at extreme were done per the guide. I have disabled thermal monitor, cstates, eist...for now.
x264 UNstable (bsod 101) at:
cpu: 43
uncore: 35
vcore: 1.34
vrin: 2.20
vring: 1.20
x264 stable at:
cpu: 43
uncore: 35
vcore: 1.36 (only difference vs the above is this parameter)
vrin: 2.20
vring: 1.20
decided to have it fold and see if it crashes. All I am doing on this machine right now is gaming and folding so as long as I am stable there then that is good for me. x264 was good to get me in the ballpark. currently folding and every so many hours I'll drop the voltages to see how low I can get them. Once I find a good number then I'll try to increase the uncore multi.
currently at:
cpu: 43
uncore: 35
vcore: 1.35
vrin: 2.00
vring: 1.20
MaKe OuT is offline
post #38 of 286 (permalink) Old 06-01-2014, 07:55 AM
mandrix's Avatar
Rep: 170 (Unique: 116)
nice haha! Why not try the RAM out now?
OK got the RAM back to 2400. cpu-z still showing low bus speed though, should read just over 100 which would give a full 5 gigglehertz.
Only ran short testing with x264 as this was more to confirm VCCIN of 2.3 was needed.
Maximus VIII Hero/6700K delidded w/CLP @ 4.8/Corsair LPX 4x4GB 2666 OC'd @ 3200/PCS 390X w/EK blockMain Rig specs (Click to show)
White Case Labs SM8 w/dual pedestals-Custom top extension
Rigid acrylic tubing/Dual D5's-MCP35x2
3x480mm-1x240mm Radiators
All psu wiring & sleeving by myself
2xAquaero 5 Pro's w/c - 1xFC8 for light panel & various led's
PowerColor PCS 390X w/EK block
6700K/Maximus VIII Hero/Corsair 4x4GB RAM
Build Logs (Click to show)Validations (Click to show)
mandrix is offline
post #39 of 286 (permalink) Old 06-10-2014, 07:56 PM
sabishiihito's Avatar
Rep: 67 (Unique: 36)
Testing some BBSE, couldn't tighten the tertiary timings as much as I wanted to (had to set 5s instead of 4s) but only needed 1.8v as a result to pass 32M at 2400 8-10-7 1T.
sabishiihito is offline
post #40 of 286 (permalink) Old 06-10-2014, 08:31 PM - Thread Starter
Sin0822's Avatar
yea the tertiary thing is being worked on
sorry let me look over the thread guys, I have been gone for the past week and just moved smile.gif
Sin0822 is offline
