Help to analyze OCCT graph results - Overclock.net - An Overclocking Community
post #1 of 11 (permalink) Old 05-28-2017, 03:42 AM - Thread Starter
anonymousse37's Avatar
Rep: 0
Sorry wrong section, can someone delete it plz =)
Hi,
I'm kinda new to overclocking.
I'm using OCCT to validate current OC.
I'm running a 4790K into an Asus Maximus Formula VII with 8 GB of Kingston HyperX Beast series XMP DDR3 2400MHz CL11.
Actually the voltage applied to the cpu is 1.22V. I started from 1.25V and now i'm going down 0.01V by 0.01V to find the critical voltage.
The CPU is OC at 4.5Ghz (BLCK ratio is 45).
OCCT say that the current clock during the test is 4597Mhz and i dont understand why i have this 97MHZ delta.
May someone tell me what are the other parameters i could change too in order to improve this OC except the VID applied to the CPU ?
I've noticed something weird to me. Before i tried to OC, i was running the standard conf with turbo boost stuff.
And i'm getting better results on 3Dmarks with it than the current OC. How this could be explained ?
Thanks for the help !
Here are the graphs from OCCT bellow.
anonymousse37 is offline
post #2 of 11 (permalink) Old 05-28-2017, 03:50 AM
Not new to Overclock.net
TwoCables's Avatar
Rep: 6211 (Unique: 3519)
What does this have to do with Folding?  You posted in Overclockers Care > Overclock.net [email protected] Team.
OCN Classic 2.0
Semi-Classic Firefox Add-ons Manager (CSS script)
The virtuous spirit has no need for thankful approval, owning a certain conviction that what has been done is right.
i5-2500K @ 4.5GHz (1.368-1.384V fixed voltage)
ASUS P8P67 EVO B3 (UEFI ver. 1850)
MSI GTX 1070 Ti Gaming Titanium 8G
G.SKILL Ripjaws X 8GB (2 x 4GB) 1866MHz, CL9
250 GB Samsung 840 EVO (OS)
3 TB Toshiba P300 (storage)
Optical Drive
Samsung SH-S243N 24x DVD Burner
Optical Drive
Samsung SH-S203N 20X DVD Burner
Corsair RM550x
Thermaltake Frio
CM 690
Operating System
Windows 10 Home
AOC G2460PG (24" 1920 x 1080 144Hz G-SYNC)
Keyboard
Filco Majestouch 104-key Cherry MX Blues w/NKRO
Mouse
Intellimouse Optical (1.1A) 1000Hz polling rate
Mousepad
It's just a mousepad
Audio
X-Fi Titanium HD
Audio
Klipsch ProMedia 2.1 (with 16 AWG Monster Cable speaker wires)
TwoCables is online now
post #3 of 11 (permalink) Old 05-28-2017, 03:51 AM - Thread Starter
Rep: 0
My bad, im gonna delete it.
post #4 of 11 (permalink) Old 05-28-2017, 04:01 AM
TwoCables's Avatar
 I think sometimes inferior performance after overclocking can mean it's not actually stable.
OCN Classic 2.0
Optical Drive
Optical Drive
Corsair RM550x
Thermaltake Frio
CM 690
Operating System
Windows 10 Home
Keyboard
Mouse
Mousepad
Audio
X-Fi Titanium HD
Audio
post #5 of 11 (permalink) Old 05-30-2017, 07:31 AM - Thread Starter
Rep: 0
Anyone please ?
post #6 of 11 (permalink) Old 05-30-2017, 07:39 AM
xenkw0n's Avatar
Rep: 21 (Unique: 15)
Originally Posted by anonymousse37 View Post
Anyone please ?
Originally Posted by TwoCables View Post
Anyway, I think sometimes inferior performance after overclocking can mean it's not actually stable.
xenkw0n is offline
post #7 of 11 (permalink) Old 05-30-2017, 09:26 AM - Thread Starter
Rep: 0
My car doesn't start. Your car is probably broken. Helpfull.
post #8 of 11 (permalink) Old 05-30-2017, 09:33 AM
xenkw0n's Avatar
I like that one. Lower your frequencies or increase the voltages. If you're getting better results with the built in overclocking profiles then run one of them with a stress test and monitor the voltages with HWiNFO or something. The big ones here are CPU VCore, CPU Cache Voltage, VCCSA (system agent) and DRAM voltage. Use that as a baseline and gradually lower them to find your sweet spot. You could also have some other settings that are changed with the auto "turbo boost" setup, like CPU Cache frequency if you're not playing with that with your manual overclock.
Your car is not broken, it can just be tweaked to perform a little better.
xenkw0n is offline
post #9 of 11 (permalink) Old 05-30-2017, 09:43 AM - Thread Starter
Rep: 0
Didnt mean to be rude, but i have no clue. I already know there is a problem ^^ If i knew how to fix it, i would not ask ^^
I did run the OCCT for one hour and had no crash.
I played GTAV like 4 hours in a row and no crash.
I started the voltage at 1.25V and was lowering it with a step of 0.01v.
Still had no crash at 1.22V.
Just getting a fewer points in benchs.
Everything which was related to the turbo boost has been deactivated in the bios.
Do the graphs are pointing you something weird cuz i got no error i think even if i know it doesnt mean that there is no problem.
I'll try to keep lowering the voltage to reach the most efficient one for this frequency and then i'll try to change other settings.
post #10 of 11 (permalink) Old 05-30-2017, 09:49 AM
xenkw0n's Avatar
Then your overclock is probably stable and the auto-overclock features you were using before were also increasing more frequencies than just your CPU + DRAM speeds. Lowering voltages won't increase your score. Your OCCT graphs look fine. Figure out what also is being increased - My guess is the CPU Cache.
xenkw0n is offline
