i7 8700k overclock results and settings - Page 2 - Overclock.net - An Overclocking Community
post #11 of 4256 (permalink) Old 10-14-2017, 03:01 PM
Overclocker
JackCY's Avatar
Rep: 358 (Unique: 255)
My 9 series is running over 9000MHz wheee.gif But that 8 series looks like people get worse results.
JackCY is online now
post #12 of 4256 (permalink) Old 10-14-2017, 06:41 PM
Rep: 60 (Unique: 49)
Originally Posted by Chrisch View Post
my daily setting on my 8600K
ucode is offline
post #13 of 4256 (permalink) Old 10-15-2017, 09:05 AM
Leijido's Avatar
Rep: 0
This is off topic but any 8700k owners here have 2 gtx 1080 TIs in sli? I really need to see 8700k sli supported gaming benchmarks at 4k resolution or above before I get one. Stock frequency benchmarks are fine as long as it's for actual games and not Timespy 3d Mark Firestrike etc. Thanks so much and sorry for the trouble
Leijido is offline
post #14 of 4256 (permalink) Old 10-16-2017, 08:59 AM
pluke the 2's Avatar
Rep: 12 (Unique: 12)
Originally Posted by Asrock Extreme7 View Post
first try 5.0Ghz 2.6v
https://valid.x86.fr/jwv3vv
did you try benching or stress testing????? your pictures show you running prime 95 for less than 1 minute. did you also refresh the low/high ?? i'm confused
pluke the 2 is offline
post #15 of 4256 (permalink) Old 10-16-2017, 09:04 AM
I'll contribute.
NOT STABLE bench conditions using intel extreme tuning utlility: (crashes at 4.8/4.9/5.0 at any voltage below 1.4)
my gaming profile (HASNT CRASHED YET):
delidded 8700k, 4.9ghz, 1.3 vcore, 80c highest temp. kraken x62 cooler on full fan/pump.
MCE OFF. sync all cores, xmp on ddr4 @ 3200 cl16, system voltages and agent are at 1.15. uncore is at 4.7ghz.
i'm using an asus 370 board.
post #16 of 4256 (permalink) Old 10-16-2017, 11:06 AM - Thread Starter
Asrock Extreme7's Avatar
Rep: 4 (Unique: 4)
delidded 8700k, 5.0ghz manual , 1..28 vcore, 65c highest temp. 2x 240 rad gpu in loop
MCE OFF. sync all cores, xmp on ddr4 @ 3200 cl14, system voltages and agent are at auto. uncore is at 4400ghz. not touched yet
i'm using an asus hero 370 board.
just tryed Adaptive Mode but not stable @ 1.31v temp 72 c Load-line Calibration 4
is it best to use manual or Adaptiv
Asrock Extreme7 is offline
post #17 of 4256 (permalink) Old 10-16-2017, 04:41 PM
lolngoway007's Avatar
Rep: 0
Hello i got my 8700k recently and here are my results so far
Corsair 115i. Maximus x hero mobo.
8700k at 4.9ghz 1.28 voltage (manual). Load line calibration at level 6.
Cache untested.
2x8gb ram at 3733hz 16 17 17 39 2N
1.35v 1.225 vccio 1.2375 vccsa
I haven't run aida64 long enough to know if it is stable. But while playing bf1 for about 2 hours i haven't crashed yet.
Temps in aida64 is like 85 degress max.
lolngoway007 is offline
post #18 of 4256 (permalink) Old 10-16-2017, 04:43 PM
Rep: 0
Careful on auto settings for vccsa and vccio. Mine were were originally 1.37v on auto. Even setting it at a fixed 1.2375 vccsa my AI suite (asus) shows it actually running at 1.272v...
post #19 of 4256 (permalink) Old 10-16-2017, 05:01 PM - Thread Starter
Rep: 4 (Unique: 4)
ok sorted overclock try for yourself
asus rog hero
my settings are for 5ghz oc voltage and speed step
x50 multi Sync all cores
Adaptive Mode voltage 1.315 Offset 0.05
Set IA AC Load Line to 0.01
Set IA DC Load Line to 0.01
LLC level 5
cpu c states enabled
windows power plan balanced
prime 95 2 hour
bf1 3 hour
all good
just set cpu vccio to 1.2375
cpu syatem agent to1.15
so far so good
post #20 of 4256 (permalink) Old 10-16-2017, 05:36 PM - Thread Starter
Rep: 4 (Unique: 4)
new bios out Version
0505
2017/10/168.28 MBytes
ROG MAXIMUS X HERO BIOS 0505
First Release BIOS
