e6750 need help to oc to 3.2 ghz - Page 2 - Overclock.net - An Overclocking Community
post #11 of 18 (permalink) Old 05-17-2018, 02:36 PM
9 Cans of Ravioli
The Pook's Avatar
Rep: 1260 (Unique: 687)
all easy fixes
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 32GB
Mushkin Pilot NVMe 1TB
HP EX950 NVMe 2TB
Samsung 860 Evo 1TB
Toshiba X300 5TB
Western Digital EZRZ 3TB
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Raijintek Morpheus II
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU 27" 1440p
LG 24UD58 24" 4K
Keyboard
CoolerMaster MasterKeys Pro S
Mouse
Logitech G502
Mouse
Glorious Model D
Audio
Klipsch PowerGate + FiiO E10K
Audio
Micca RB42
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston 8GB DDR4 2400
Dierka K1 120GB
ADATA SU800 128GB M.2
Operating System
Windows 10 Professional
Operating System
MX Linux
Keyboard
Dierya DK63-BT 60% (Outemu Blue)
Mouse
Logitech G603 Wireless
i7 860
Advantech AIMB 280 ITX
EVGA GTX 950 2GB
Kingston 2GB DDR3 1333
Seagate Momentus 2.5" 500GB
Western Digital Blue 2.5" 320GB
Silverstone SFX-L Gold 500w
Arctic Alpine 11 GT 2
Silverstone Milo Z ML07B
Operating System
Windows XP x86 SP3
Keyboard
Velocifire TKL01 Outemu Browns
Mouse
Logitech M512
The Pook is online now
post #12 of 18 (permalink) Old 05-17-2018, 03:01 PM
Senior Overclocker
Cryptedvick's Avatar
Rep: 266 (Unique: 235)
I needed 1.28v for 3.2Ghz back in the day for my E6750.
Add +0.2 on the NB over stock and increase the CPU VTT to 1.35v and see where that leads you.
You're also probably crashing because you're trying to run CAS 4 at 750Mhz, not to mention with different sticks.
Try 5.5.5.18. I bet you'll be able to get 400Mhz with a multi of 8 for 3.2Ghz and a nice round 800Mhz on the rams.
From there on, up the NB freq until it crashes, up the NB voltage and core voltage and if none help, up the VTT voltage as well and see where that gets you.
Don't go over 1.45v for the CPU, VTT or 1.5v for NB. Keep the case as ventilated as possible.
Name:	8800GT Max OC Vantage.jpg
C2D 6750 -> C2Q 6600 -> C2Q 9550 -> i7 2600k -> i7 8700k
8800GT -> 8800GTS 512 -> GTX285 -> GTX480 -> GTX580 -> GTX780ti -> GTX980ti -> GTX1080ti
R.I.P. Daniel Costin (Syrillian)
Animal Mother
(19 items)
i7 8700k 5Ghz/4.8Ghz uncore 1.39v delid
Asrock Z370 Taichi
MSI GTX 1080Ti GamingX @ 2063Mhz/6000Mhz
32GB Corsair Vengeance 3200Mhz CL16
Patriot Viper VPN100 NVMe 512GB OS drive
Western Digital Blue 2x1TB 3D NAND SSDs in Raid 0
Western Digital Blue 1TB
Western Digital Red 2TB
Western Digital Green 2x3TB
WD Elements 2TB
Corsair TX750W V2
Noctua NH-D15 w/MX4
Cooler Master 690 II Advanced + 7 case fans
Operating System
Windows 10 x64
LG 29UM69G 2560x1080 @ 75Hz
Keyboard
Redragon Yama
Mouse
Redragon Titanoboa 2
Audio
Asus Xonar DX / Plantronics Gamecom 777 / Logitech Z506
Other
Oculus Rift S + T500RS wheel and TH8RS shifter
Cryptedvick is offline
post #13 of 18 (permalink) Old 05-17-2018, 03:35 PM - Thread Starter
Rep: 0
Edit: Btw i also have the same graphic card. But i can't oc it.Sparkle editon.
My lowest cpu volt is 1.35 which goes min and max as 1,328-1,376 if i use that
Made VTT FSB volt 1.35
Made Cpu volt 1.40
Made NB volt 1.375
Made the rams 5 5 5 18 it crashed
Made the rams normal (auto) it crashed
It is not even fully stable at 3.0 ghz Always fails prime 95. But pc works normally.
But at 3.2 ghz it crashes or fails prime95 in seconds. I don't think my pc can run at 3.2ghz no matter what.
Now testing 2.8 ghz with 4 4 4 15 ram speeds to see if it fails prime95 even once.
Adding ram pictures since i don't think they are different inside. 2t one has a better cooling add-on.
Xentios is offline
post #14 of 18 (permalink) Old 05-17-2018, 04:09 PM - Thread Starter
Rep: 0
Well 30-60 minute of no error in prime 95 (I know you like 24 hour test but this is enough for me)
2.8 Ghz 7*400 mhz.
400*2 mhz 4 4 4 15 rams with 2t , 42 trfc
1.350 V Cpu
2.00 V Ram
Auto everything else
Max NB temp=78
Max Core temps=72 each (tjmax 95)
Motherboard Temp= 38-39
So my full stable stats are these.
Xentios is offline
post #15 of 18 (permalink) Old 05-19-2018, 05:20 AM
Senior Overclocker
2.8 Ghz 7*400 mhz.
1.350 V Cpu
2.00 V Ram
Max NB temp=78
This seems like a definite motherboard limitation. The E6750 should easily do 3.2Ghz no matter what.
What mobo are you running anyway?
The pic I posted was on a Gigabyte P35 DS3.
Animal Mother
(19 items)
Asrock Z370 Taichi
WD Elements 2TB
Corsair TX750W V2
Noctua NH-D15 w/MX4
Operating System
Windows 10 x64
Keyboard
Redragon Yama
Mouse
Audio
Other
post #16 of 18 (permalink) Old 05-19-2018, 10:39 AM - Thread Starter
Rep: 0
Msi p35 neo . Don't know why lowest Cpu core Volt is 1.35 V but if i wan't i can go to 2.5 V to burn my house . max Cpu core volt is over 2.5 V. I actually wonder what will happen if i give 2.5 v to my cpu : )
http://www.pc-specs.com/mobo/MSI/MSI...ompatible_GPUs
Xentios is offline
post #17 of 18 (permalink) Old 05-20-2018, 06:09 AM - Thread Starter
Rep: 0
Ok i think i found my problem which is bad news for me.
E6750 is 60 W cpu
Board is 4 pin cpu power connector supports max 95 W
http://www.coolermaster.com/power-supply-calculator/
Using TDP %100
All empty watts=113 W
e6750 with 1,2 V=179 W (Diff 66 that means cpu uses 66 W)
e6750 with 1,35 V=191 W
2800 MHZ 1,35 V =195 W
3000 MHZ 1,4 V =207 W (diff 94 W which pc works normal but prime 95 errors)
3200 MHZ 1,4 V=213 W (diff 100 W) which 4 pin connector or MB can't handle.
this will ruin my 771 mod plans too : (
Edit: this does not explain why this does not work though
3200 MHZ 1,35 V=206 W (diff 93)
Maybe not that accurate.
Xentios is offline
post #18 of 18 (permalink) Old 12-12-2019, 01:20 PM - Thread Starter
Rep: 0
Hello guys, i don't know people are still interested in old systems. Sorry if this is considered uping old posts.
I am using the same rams with a different motherboard now.
My problem is now Cpu-Z reads DC Mode as Asymmetric instead of symmetric.
New motherboard is
Asus P5K SE
BIOS: 0604
Cpu different for now. I will use a Xeon in future.
Also i set tRFC 42 at bios (which is max setting) but in windows CPU-Z reads as "54 clocks"
System is stable for now. I know nobody uses old pc anymore so this will be a self documentary post if it is allowed.
Xentios is offline
