Classic Intel Q9650 Project (4.0Ghz +) - Page 3 - Overclock.net - An Overclocking Community
post #21 of 35 (permalink) Old 01-20-2019, 01:34 PM - Thread Starter
Twin Turbski
storm-chaser's Avatar
Rep: 0
Quote: Originally Posted by TwilightRavens View Post
170F (76C) is a tad on the high side for a Core 2 Quad, not by a huge amount but I generally heard its best to keep it below 75C (70C really if you care about longevity) though if that's just stress test temps then your real world temps probably won't hit that and I wouldn't worry too much about it. Those idle temps are nice though, my QX stays mostly in the upper 40C range except one core that is just odd and stays at like 27C, but load temps in CB R15 hottest core I saw hit 71C and the rest were upper 60C range.
Thanks for the info... Yes that temp reading was from an AIDA64 stress test, so I am not too worried about it because I will never hit those temps in day to day operations. Running the Thermalright Ultra 120 extreme CPU cooler and calculated a TDP of 135W in this overclock configuration.
I've done some more testing and tweaking and here is where we're at:
-Switched from the 400Mhz strap to the 266Mhz strap(also gets rid of that annoying speed bug when you run the 3:5 divider on P45 chipset
-Adjusted the TRAS from 13 up to 15 for stability
-Set common performance level to 07 (I was initially running at 09) - Shaved ~2-3ns off my latency
Phenom II Zosma 970 unlocked to X6 4.020Ghz
Phenom II 960T unlocked to X6 3.8Ghz
Phenom II 960T @ 4.2Ghz
Intel Q9650 @ 4.3Ghz
Intel E8600 @ 4.7Ghz
Intel Q9450S HTPC build @ 2.7Ghz
storm-chaser is offline
post #22 of 35 (permalink) Old 01-20-2019, 02:07 PM
Hardware Princess
Hydroplane's Avatar
Rep: 38 (Unique: 30)
4.3 is excellent, the later core 2 quad steppings from 2009 or so seem to OC the best. I bought my Q9550 in 10/2008 so it was probably one of the earlier ones (C1 stepping I think). Never could get 4 GHZ 100% stable.
CHILLER DESTRUCTION
Build Log - White Voodoo
basic linux pc
(15 items)
Z390 Station
(11 items)
7980XE @ 4.3 GHz 1.10v
Asus Rampage VI Apex
2 x Aorus Waterforce WB 1080 Ti @ 2037/6318
Trident Z 16gb 3200c14 @ 3800c16 1.50V (the other two sticks were sacrificed)
960 Evo 1TB
EVGA 1600 T2
HWLabs GTR 420+280 Rads
7 x Noctua Industrial 140mm 3000 RPM Fans
EK D5 Pump/Res (with RGB!)
LD Cooling PC-V7
Operating System
Linux Mint 19.6
NEC PA271W
Keyboard
Razer Blackwidow Chroma V2
Mouse
Logitech M510
Mousepad
anime tiddy mousepad
9900K @ 5.4 1.50v
EVGA Z390 Dark
Titan RTX 2085/8500
Trident Z 3200c14 @ 4600c20 1.5v
970 Evo Plus 250gb
silverstone 1200 from 2008 (other one exploded)
HWLabs GTX 360 Rad (in RED)
3x EK Vader 120mm 2200rpm Fans
Dimastech Test Bench
AOC Agon AG251FZ 240Hz
Audio
Built-in Monitor Speakers (3 watt)
Dual Intel Xeon L5520 2.26 GHz
48 GB Samsung DDR3-1066
120 GB Samsung 750 Evo SSD
2 TB Western Digital Green
2 TB Hitachi 7200 RPM
650W Delta PSU
1U Rackmount
Operating System
Ubuntu Server 16.04
Hydroplane is offline
post #23 of 35 (permalink) Old 01-20-2019, 02:39 PM
Overclocker in training
ThrashZone's Avatar
Rep: 150 (Unique: 92)
Hi,
Yeah I still have a q9550 too
No decent board just a crappy acer aspire lol never could oc it besides a pin mod which I never did
i9-9940x With Optimus Foundation copper-plexi and Heatkiller VRM Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
MO-RA3 360 PRO stainless steel (25022)
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
Other
5.0/https://valid.x86.fr/ez2ifr
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is offline
post #24 of 35 (permalink) Old 01-20-2019, 02:44 PM
Hardware Princess
Hydroplane's Avatar
As far as the temps go, my Q9550 survived 9 years overclocked with temps in the 80-90c range... lol the first few months I had it one of the pins broke off the stock cooler so it idled at like 75C and 100C gaming Finally got around to picking up a Zalman 9700 in April 09 and it was overclocked ever since. Still runs today, think it degraded a little though, was stable at like 3.8 1.40v.
CHILLER DESTRUCTION
basic linux pc
(15 items)
Z390 Station
(11 items)
960 Evo 1TB
EVGA 1600 T2
LD Cooling PC-V7
Operating System
Linux Mint 19.6
NEC PA271W
Keyboard
Mouse
Logitech M510
Mousepad
9900K @ 5.4 1.50v
EVGA Z390 Dark
Titan RTX 2085/8500
970 Evo Plus 250gb
Audio
650W Delta PSU
1U Rackmount
Operating System
Ubuntu Server 16.04
post #25 of 35 (permalink) Old 01-20-2019, 02:49 PM
ThrashZone's Avatar
Hi,
Yeah though briefly about reliving the system but didn't see much point without another board that a ram it would be more than it would worth messing with
The pin mod wouldn't be much to do though beside another case to do it on
I do have an old gateway xp case
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
Other
X99 Sabertooth
EVGA 1000-P2
Operating System
Mouse
Audio
eLeaf MELO-3 4ml
Operating System
post #26 of 35 (permalink) Old 01-20-2019, 08:51 PM
Are you sure about that?
TwilightRavens's Avatar
Rep: 21 (Unique: 13)
Yeah on my QX9650 it didn’t like 4.0 as it was a pretty big voltage wall to get it, but I was willing to run whatever it took to hit 4GHz. Its set to 1.43625v in bios but in Windows it reads as 1.38v or something so its not terrible. Its being cooled by a Hyper 212 Evo (not the lga 775 bracket) fun fact though, the LGA 115X bracket works if you fiddle around with it and angle the screws to get them started and then screw em in the right way.
CPU’s I’ve owned: P4 630, P4 631, C2D E6320, C2D E6700, X3230, QX9650, X5470, i5 655K, i7 3770K ES, Pentium 2020M, i5 4690K, i7 5775C, Athlon XP 3200+, E2-1800, Athlon 64 X2 1.8GHz, A10 4600M, Ryzen 5 2600X, Ryzen 9 3900X
GPU’s I‘ve owned: GeForce2 MX400, 8800GTX, GTX 660 SLI, GTX 1070, GTX 1080, GTX 1080 ti, x1300, R9 380, R9 290X, Iris Pro 6200.
Project: Overkill
(16 items)
The Linux Box
(14 items)
AM4 (Wife's Rig)
(14 items)
Ryzen 9 3900X (stock) (fclk 1900MHz)
ASRock X570 Taichi
MSI NVIDIA GeForce GTX 1080 Ti Armor OC 11G (2088MHz)
G.Skill TridentZ Neo RGB 3800MHz 2 x 16GB (16-16-16-36)
Samsung 970 Evo M.2 SSD 250GB
Seagate IronWolf 4TB NAS 7200RPM HDD
Optical Drive
LG WH14NS40 Blu-Ray/DVD/CD Writer
EVGA Supernova 750W PQ (Semi modular)
AMD Wraith Prism
Phanteks Enthoo Pro Tempered Glass ATX Full Tower
Operating System
Windows 10 Pro x64 1909
Sceptre 27" Curved 144Hz Gaming LED Monitor Edge-Less AMD FreeSync DisplayPort HDMI, Metal Black 2019 (C275B-144RN)
Acer SB220Q bi 21.5 inches Full HD (1920 x 1080) IPS Ultra-Thin Zero Frame Monitor
Keyboard
Logitech G213 Prodigy
Mouse
Logitech G502 Hero Gaming Mouse
Other
Thermaltake Commander FT Touch Screen 5.25 inch fan controller
Intel i7-5775C @ 3.3GHz 1.065v
ASUS Z97-E/USB 3.1
EVGA GTX 1070 SC
G.Skill RipjawsX 2 x 4GB DDR3 1600MHz
Kingston SSD 120GB (OS)
Seagate Barracuda 7200RPM HDD 2TB
Corsair RM850 850W 80+ Gold
Thermaltake 7-bladed 92mm 4-Pins PWM Aluminum Extrusion CPU Cooling Fan for Intel Core i7/i5/i3 CLP0556-B
Fractal Design Focus G
Operating System
Ubuntu 18.04.4 (Bionic Beaver) LTS 64-bit
Keyboard
Dell USB Slim Wired Keyboard KB113P P/N 0N8WF8 - Black
Mouse
Manhattan MH3 Wired Mouse, Black/Grey, 1000dpi, USB, Optical, Sturdy, Three Button with Scroll Wheel, Box - USB Optical Mouse
Other
ASUS PCE-AC56 PCI-E Wireless Express Adapter
Ryzen 5 2600X (stock with PBO enabled)
GIGABYTE X470 AORUS Ultra Gaming AM4
EVGA GTX 1080 Superclocked
G.Skill TridentZ RGB DDR4 (b-die) 3200MHz (16GB) (14-14-14-34)
Crucial MX300 SSD
HGST 1TB 2.5"
Optical Drive
ASUS CD/DVD Drive
Corsair CX650
Wraith Spire AM4 Cooler
DEEPCOOL ATX Case Kendomen TI
Operating System
Windows 10 Pro x64
Samsung 24" 1080p curved
Keyboard
Mouse
Logitech Mini Wireless Mouse
TwilightRavens is offline
post #27 of 35 (permalink) Old 01-21-2019, 09:29 AM - Thread Starter
Twin Turbski
Rep: 0
Well I tried for DDR3 @ 1916Mhz and she was a no go. Kinda figured that with this memory kit those speeds were gonna be hard to hit anyway. Since the spec is CL7 1600, but it's really just a juiced up 1333 CL9 piece, I figured it would be tough to hit those kind of numbers.
But, for the record, it did post and I even got to the logon prompt. Just crashed when logging into windows. I was running timings of 8-9-9-30 with this attempt at 1916Mhz.
post #28 of 35 (permalink) Old 01-26-2019, 02:35 PM
prescotter's Avatar
Rep: 82 (Unique: 67)
I have to say this topic was an interesting read. I miss the days of OCing on s775, somehow the fight between FSB and multiplier was more interesting to me then simple only touch the multiplier on newer platforms.
I will never forget my Q9650, after running a Q6600 @ 3.4Ghz on 1.456v for years i bought a second hand Q9650 and it was looking back a semi golden chip. My friend who had bought a QX9650 needed over 1.45v to reach 3.9+Ghz and my Q9650 hit 3925Mhz on 1.18v load voltage.
(Set voltage was 1.28v, dropped to 1.18v on p5p43TD motherboard)
Sadly i sold the CPU on a second hand website again by phone so i have no records to contact the guy, but almost every week i think about what the CPU could have done if i had proper cooling and a motherboard capable of 500/600Mhz FSB. If i had the chance it would surely buy the CPU back and see what its real limits would have been.
After that CPU i never had any luck with the silicon lottery and mostly end up with an average or below average CPU. I have added a P95 and IBT screenshot from over 8 years ago for those who interested.
Name:	Q9650 3.9ghz--9x435--Prime95 60m.jpg
Name:	Q9650 3.9ghz--9x435--Gflops.jpg
Blazer
(8 items)
Intel i7 4790K
Asrock Fatal1ty Z97X Killer
EVGA GTX1070 SC GAMING ACX 3.0 8GB
Adata XPG 2x8GB DDR3-2600 C11
Crucial M500 120GB SSD
Cruscial MX200 250GB SSD
WD 1TB HDD
Seasonic M12II Evo 750W
prescotter is offline
post #29 of 35 (permalink) Old 01-26-2019, 10:33 PM
Kinda sounds like my luck when it comes to silicon lottery, I had an old Athlon XP that didn't really do much more than 2.8GHz, a E6700 that did 3GHz and not a drop higher, my QX9650 won't even go a hair over 4GHz (though that's not that bad), an i5 4690K that topped out at 4.4GHz at 1.4v and of course the chip I win the lottery with is a chip that is not known for clocking well the i7-5775C which usually tops out at 4.2-4.3GHz at 1.4v-1.45v and mine will do 4.5GHz at 1.485v but I run it at 4.4GHz and 1.4v because cooling can't keep up with higher than that. Though I did have an ES 3770K that clocked to 5.4GHz but hyperthreading didn't work, even at stock so that doesn't count.
Project: Overkill
(16 items)
The Linux Box
(14 items)
AM4 (Wife's Rig)
(14 items)
ASRock X570 Taichi
Optical Drive
AMD Wraith Prism
Operating System
Keyboard
Mouse
Other
ASUS Z97-E/USB 3.1
EVGA GTX 1070 SC
Operating System
Keyboard
Mouse
Other
Crucial MX300 SSD
HGST 1TB 2.5"
Optical Drive
ASUS CD/DVD Drive
Corsair CX650
Operating System
Windows 10 Pro x64
Keyboard
Mouse
post #30 of 35 (permalink) Old 06-14-2019, 02:14 AM
Rep: 0
Overclock Q9650
Hi man. i love youre works on youre cpu. and im amazed to see how you Overclocked Q9650 to 4Ghz and more.
can you teach me how can i Overclock My cpu q9650
my spec is:
Motherboard DFI P75 T2Rs Dark Elite
8 Gig DDR2 RAMs
Vram GALAX GTX950oc 2 Gig
PSU Corsair vs650
F3RALi is offline
