Never Finished
Rep: 257
(Unique: 201)
What temps do you get with realbench stress test?
Also, it could be worth your time to take off the cooler and inspect the cold plate along with the mounting screws. If the base of the cooler is convex, then that could be a variable for high temps as it won't make as much contact as a flat one (fyi, mine is pretty flat). You also have the mounting hardware not being torqued in there good enough which can cause a loose fit. Paste tim does degrade over time, but not by much, and re-applying annually is fine.
1680 V2 4.5GHz 1.33v | G.Skill Trident X 4X4GB 2400MHz | R4BE | Titan Xp + Morpheus II
Wasabi Mango UHD550 | Rosewill Rise | Thermalright LGM RT
Logitech G600 | G440 | Tt Meka G-Unit Cherry MX Black+Double O-Rings
JBL LSR308s | Temblor T10 | Custom headphones | TEAC-UD501+Wyrd+Passive Preamp | Emotiva Mini-X A100
OCZ Vertex 4 256GB | Mediasonic ProBox 8: 7x SG 4TB 1x WD 3TB | SS Prime Ultra Titanium 1KW
