9900K on air - too hot? - Page 3 - Overclock.net - An Overclocking Community
post #21 of 47 (permalink) Old 01-26-2019, 01:30 PM
Falkentyne's Avatar
Rep: 357 (Unique: 256)
Quote: Originally Posted by Luck100 View Post
I'm trying to overclock a 9900k on air (Grand Macho RT). The case has great airflow and fans are maxed during testing. My chip seems to need a big voltage jump to get all cores to 5 GHz, so I'm just shooting for 4.9 all cores. I'm getting into the high 90s max core temps after 6-7 minutes of Prime 95 small FFT (no AVX, and AVX offset 0 in bios). Snapshot of HWinfo during my Prime95 run below.
Bottom line, I'm pulling 190W package power and hitting high 90's temps. Does that seem bad for Grand Macho RT + grizzly kryonaut? Maybe I need to re-paste? That cooler is a pain to mount but I'd do it again if I thought it would help.
Try repasting with an "X" paste layout method (two diagonal lines to each corner). This may help a bit.
[email protected] ghz, RX Vega 64, 32GB DDR4, Gigabyte Aorus Master, Seasonic Platinum 1000W, Corsair 760T
Alt: MSI GT73VR Throttlebook with 7820HK @ 4.7 ghz, GTX 1070 MXM TDP mod to 230W, 32 GB RAM
Falkentyne is offline
post #22 of 47 (permalink) Old 01-26-2019, 03:28 PM - Thread Starter
Luck100's Avatar
Rep: 18 (Unique: 14)
Quote: Originally Posted by airisom2 View Post
What temps do you get with realbench stress test?
Ran into thermal throttling after 15 minutes of realbench.
Name:	Realbench 13 minutes total OVERTEMP.jpg
Battlestation
(15 items)
TV Buddy
(15 items)
9900k
Asus ROG Maximus XI Hero (Wifi)
Gigabyte Aorus 1080ti
Corsair Vengeance LPX 2 x 8 GB
Samsung 970 EVO NVMe 1 TB
Seasonic PRIME Ultra Gold 1000 W
Thermalright Le Grand Macho RT
Cooler Master MasterCase H500M
Operating System
Windows 10 Pro
Acer Predator XB270HU
Keyboard
CM Quickfire TK
Mouse
Logitech G500s
Mousepad
Logitech G440
Audio
Logitech G533 Gaming Headset
Audio
StudioSpares Powered Studio Monitors
i5-4690
Asus Z97-A
EVGA GTX 670 FTW
Crucial Ballistix 4GB x 2
Western Digital Caviar Green 3 TB
Mushkin Chronos Deluxe 240 GB SSD
Optical Drive
Pioneer BDC-207DBK Blu-Ray Reader, DVD/CD Writer
SeaSonic G550
Noctua NH-L12
Scythe Gentle Typhoon 37.0 CFM 120mm x 2
Silverstone GD09B
Operating System
Windows 8.1 Pro
Keyboard
Logitech K400
Other
FLIRC USB Dongle for Media Centre
Other
Harmony 650 Remote
Luck100 is offline
post #23 of 47 (permalink) Old 01-26-2019, 03:53 PM
Falkentyne's Avatar
Did you do the repaste with the method I said just 2 posts ago?
With 1.335v bios setting, 5.1 ghz (ring x47) and LLC=Turbo (equal to level 6 on a Maximus XI), I don't exceed 92C in realbench after 30 minutes. That gives a VR Vout (equal to your real vcore) higher than yours. Noctua NH-D15 with 2 fans here.
post #24 of 47 (permalink) Old 01-26-2019, 04:35 PM
Otherworlder
epic1337's Avatar
Rep: 213 (Unique: 121)
i noticed the temps on each of his cores, apparently cores #2,3,4,5 are a notch higher than the rest, 97°C~99°C as opposed to 92°C~94°C.
in this case, cores #0,1,6,7 should be whats normal, so cores #2,3,4,5 are possibly leaky cores.
trolling an adult is very dangerous, don't try it at home nor at work. you don't want to play tag with a rabid man.
epic1337 is offline
post #25 of 47 (permalink) Old 01-26-2019, 04:35 PM - Thread Starter
Luck100's Avatar
Yeah, I think I'm going to try a repaste tomorrow. I used the thin uniform layer method last time (the applicator on the grizzly kryonaut makes it easy). It's nearly impossible to sit the heatsink down in the right spot on the first try so I probably rubbed off some spots sliding it to line up the screw holes. Hopefully I've got enough left in the tube (this will be the third shot...the first was a disaster).
Battlestation
(15 items)
TV Buddy
(15 items)
9900k
Operating System
Windows 10 Pro
Keyboard
CM Quickfire TK
Mouse
Logitech G500s
Mousepad
Logitech G440
Audio
Audio
i5-4690
Asus Z97-A
EVGA GTX 670 FTW
Optical Drive
SeaSonic G550
Noctua NH-L12
Silverstone GD09B
Operating System
Windows 8.1 Pro
Keyboard
Logitech K400
Other
Other
Harmony 650 Remote
Luck100 is offline
post #26 of 47 (permalink) Old 01-27-2019, 06:27 AM - Thread Starter
Luck100's Avatar
Popped it open to repaste. Here's the old paste job just before cleaning.
Battlestation
(15 items)
TV Buddy
(15 items)
9900k
Operating System
Windows 10 Pro
Keyboard
CM Quickfire TK
Mouse
Logitech G500s
Mousepad
Logitech G440
Audio
Audio
i5-4690
Asus Z97-A
EVGA GTX 670 FTW
Optical Drive
SeaSonic G550
Noctua NH-L12
Silverstone GD09B
Operating System
Windows 8.1 Pro
Keyboard
Logitech K400
Other
Other
Harmony 650 Remote
Luck100 is offline
post #27 of 47 (permalink) Old 01-27-2019, 06:32 AM - Thread Starter
Luck100's Avatar
Cleaned and ready for repaste. There's a bit of scuffing on the heat sink plate, I think that happened on the first mounting attempt when I couldn't get it to sit right and there was a lot of sliding around.
Battlestation
(15 items)
TV Buddy
(15 items)
9900k
Operating System
Windows 10 Pro
Keyboard
CM Quickfire TK
Mouse
Logitech G500s
Mousepad
Logitech G440
Audio
Audio
i5-4690
Asus Z97-A
EVGA GTX 670 FTW
Optical Drive
SeaSonic G550
Noctua NH-L12
Silverstone GD09B
Operating System
Windows 8.1 Pro
Keyboard
Logitech K400
Other
Other
Harmony 650 Remote
Luck100 is offline
post #28 of 47 (permalink) Old 01-27-2019, 07:27 AM - Thread Starter
Luck100's Avatar
New paste job and re-assembled.
Battlestation
(15 items)
TV Buddy
(15 items)
9900k
Operating System
Windows 10 Pro
Keyboard
CM Quickfire TK
Mouse
Logitech G500s
Mousepad
Logitech G440
Audio
Audio
i5-4690
Asus Z97-A
EVGA GTX 670 FTW
Optical Drive
SeaSonic G550
Noctua NH-L12
Silverstone GD09B
Operating System
Windows 8.1 Pro
Keyboard
Logitech K400
Other
Other
Harmony 650 Remote
Luck100 is offline
post #29 of 47 (permalink) Old 01-27-2019, 07:31 AM - Thread Starter
Luck100's Avatar
Re-running prime95 with top, side, and front removed.
Battlestation
(15 items)
TV Buddy
(15 items)
9900k
Operating System
Windows 10 Pro
Keyboard
CM Quickfire TK
Mouse
Logitech G500s
Mousepad
Logitech G440
Audio
Audio
i5-4690
Asus Z97-A
EVGA GTX 670 FTW
Optical Drive
SeaSonic G550
Noctua NH-L12
Silverstone GD09B
Operating System
Windows 8.1 Pro
Keyboard
Logitech K400
Other
Other
Harmony 650 Remote
Luck100 is offline
post #30 of 47 (permalink) Old 01-27-2019, 07:38 AM - Thread Starter
Luck100's Avatar
And the results of prime95 is....one degree C lower. But I did remove sides and front. So I'm going to call it a wash.
What do you think of the scuffs on the thermal plate? Would that really matter? The worst scuff is off to the side, so I'm mainly thinking of the smaller marks toward the center. There's a few minor marks on the CPU IHS as well. It kind of looks like dust but a couple of passes with the microfiber shows it's not.
Name:	Prime95 small NO AVX new paste.jpg
Battlestation
(15 items)
TV Buddy
(15 items)
9900k
Operating System
Windows 10 Pro
Keyboard
CM Quickfire TK
Mouse
Logitech G500s
Mousepad
Logitech G440
Audio
Audio
i5-4690
Asus Z97-A
EVGA GTX 670 FTW
Optical Drive
SeaSonic G550
Noctua NH-L12
Silverstone GD09B
Operating System
Windows 8.1 Pro
Keyboard
Logitech K400
Other
Other
Harmony 650 Remote
Luck100 is offline
