9900K on air - too hot? - Page 5 - Overclock.net - An Overclocking Community
Old 01-29-2019, 05:07 PM
marik123 Level 1
marik123's Avatar
I have a hard time cooling the 9900k 5.0ghz at 1.296v loaded with a bequiet dark rock pro 4 also. I think air cooling tops out at 4.9 - 5ghz depending on your chip on stock settings. If you are willing to delid your chip, sand down the IHS and cpu die, then that will reduce at least 10-15c. The way 9900k is being soldered and I still don't feel comfortable shaving the solder off the cpu die unlike my 8700k, which I can wipe it off with rubbing alcohol for the thermal paste Intel used.
marik123 is offline
Old 01-30-2019, 01:20 AM - Thread Starter
Luck100 Level 1
Luck100's Avatar
Thanks to all for the comments and suggestions. I've tried everything from thin layer to too much paste and as you can see from my screenshots in earlier posts there is NO measurable difference. I'm not really interested in the delid or lapping methods so I think I'm going to leave it at this.
I'm leaving my overclock at 4.9 GHz all cores and setting PL1=180, PL2=240, and tau=5 seconds to avoid thermal throttling. I only hit those power limits when running Prime95 small (which I don't really care about) and then the chip downclocks/downvolts nicely after 5 seconds of high load. Otherwise it runs at 4.9 all cores all the time.
Battlestation
(15 items)
TV Buddy
(15 items)
9900k
Asus ROG Maximus XI Hero (Wifi)
Gigabyte Aorus 1080ti
Corsair Vengeance LPX 2 x 8 GB
Samsung 970 EVO NVMe 1 TB
Seasonic PRIME Ultra Gold 1000 W
Thermalright Le Grand Macho RT
Cooler Master MasterCase H500M
Operating System
Windows 10 Pro
Acer Predator XB270HU
Keyboard
CM Quickfire TK
Mouse
Logitech G500s
Mousepad
Logitech G440
Audio
Logitech G533 Gaming Headset
Audio
StudioSpares Powered Studio Monitors
i5-4690
Asus Z97-A
EVGA GTX 670 FTW
Crucial Ballistix 4GB x 2
Western Digital Caviar Green 3 TB
Mushkin Chronos Deluxe 240 GB SSD
Optical Drive
Pioneer BDC-207DBK Blu-Ray Reader, DVD/CD Writer
SeaSonic G550
Noctua NH-L12
Scythe Gentle Typhoon 37.0 CFM 120mm x 2
Silverstone GD09B
Operating System
Windows 8.1 Pro
Keyboard
Logitech K400
Other
FLIRC USB Dongle for Media Centre
Other
Harmony 650 Remote
Luck100 is offline
Old 01-30-2019, 05:50 AM
Otherworlder
epic1337 has a spectacular aura about epic1337 has a spectacular aura about epic1337 has a spectacular aura about epic1337 has a spectacular aura about epic1337 has a spectacular aura about epic1337 has a spectacular aura about epic1337 has a spectacular aura about epic1337 has a spectacular aura about epic1337 has a spectacular aura about epic1337 has a spectacular aura about epic1337 has a spectacular aura about
epic1337's Avatar
thats more than enough, its very very rare for all cores to be heavily loaded at the same time for prolonged periods.
trolling an adult is very dangerous, don't try it at home nor at work. you don't want to play tag with a rabid man.
epic1337 is offline
Old 02-01-2019, 08:18 AM
Telstar Level 1
You need a better cooler, period. The paste was making good contact the first time, as you demonstrated after reapplying.
WIP 2019:
Intel 9900k >5ghz | Asus Maximus XI Gene | Eisbaer 360 LT (custom loop in progress) | bequiet! Dark Base 700 white edition | RAM: TBD | Gigabyte RTX 2070 OC white | Storage: Intel Optane 900p 280GB + HP EX950 1 TB | Corsair HX850i | Benq BL3200PT 1440p | 1Gbit ftth |
Telstar is offline
Old 02-01-2019, 08:21 AM
Telstar Level 1
If the hero allows (I know Extreme and Gene do), you could set two core at 50x rest at 48 or 49. Use it normally for a week or so with a temperature log and check maximums daily.
WIP 2019:
Telstar is offline
Old 02-08-2019, 06:27 AM
Yomny Level 1
Yomny's Avatar
I thought my Noctua u12s would do the trick as it did for my previous 5.1ghz 8700k (why i thought that, not sure). I was VERY wrong, mind you, i delidded the 9900k(stock IHS). Temps still touch, too often, mid 90's. Using vcore ranges 1.3-1.37 is a no go. I'm going with the bigger copper IHS from rockit cool and reapplying the liquid metal TIM in the next couple weeks but it all indicates i wasted my money on the air cooler.
Corsair
(9 items)
Core i9 9900k
Asrock Z390 Extreme4
RTX 2080 Ti
G.SKILL TridentZ Series 16GB 3000
Samsung 970 Evo m.2 1TB
EVGA SuperNOVA 850 G3
Noctua NH-U12S
Corsair 460x RGB
Operating System
Win 10
Yomny is offline
Old 02-08-2019, 02:14 PM
Kaltenbrunner Level 1
Kaltenbrunner's Avatar
And the results of prime95 is....one degree C lower. But I did remove sides and front. So I'm going to call it a wash.
What do you think of the scuffs on the thermal plate? Would that really matter? The worst scuff is off to the side, so I'm mainly thinking of the smaller marks toward the center. There's a few minor marks on the CPU IHS as well. It kind of looks like dust but a couple of passes with the microfiber shows it's not.
I have the 6-core 9600k, and also don't have panels on my case. And I'm also right at the 100C limit in P95. I had to turn off the heat and open the window in winter, and then I was maxxing at about 90C. I also seem to need a lot of volts to get near 5GHz working, I settled on 4.7GHz for now.
Maybe I just have regular chip, and not a golden sample chip.
Kaltenbrunner is offline
