OC I7-5820K Gone Wrong.. Not sure why :s - Overclock.net - An Overclocking Community
Old 01-27-2019, 05:15 AM - Thread Starter
Insr33 Level 1
Insr33's Avatar
Hey All
My X99 (Asus Sabretooth) I7-5820K build began to suffer a bit performance wise and I thought to OC my CPU. I mostly play iRacing and unfortunately this game is very CPU heavy (especially in VR).
I have a Corsair WC set so I thought I would be fine fiddling with CPU voltage and multiplier. I started out with multiplier 42 and 1,3v. I let it benchmark for 4 hours straight and attempted to go for 44 with same voltage. I got immediately got a voltage error during post and decided to revert to my "safe" OC of 4.2. Then I found out on a forum that 96% of the Haswell E's should be able to get to 4,40ghz @ 1,296V. So attempted to change the voltage to 1,296. My motherboard changed it to 1,2985 so I thought his would be fine. Rebooted and got a undervoltage warning again. After this warning my pc just turned off. The next boot I didn't get any video feed at all and the pc would just turn off again after 10 seconds. Next I attempted following steps:
* Clear cmos -> same problem
* Remove battery -> same problem
* attempted offline bios update using flashback -> bios flash succeeded but same problem after reboot
* swapped PSU -> same problem
* remove all usb cables, ram sticks, graphics card to make sure nothing else could cause the problem -> same problem
* checked the cpu for physical damage -> nothing found
* reseated cpu -> same problem
So I think I can be sure that its either my motherboard or my CPU. But can I be sure I should I order replacement motherboard and CPU? Also not really sure what I did wrong? Could it be possible that AI tweaker did not correctly alter my voltage or bursted 12v into the board in stead of 1,2? I think it would be safest to install my current CPU in another board to make sure what's broken? I don't want my possibly broken board kill another CPU
Insr33 is offline
Old 01-27-2019, 05:28 AM
Overclocker in training
ThrashZone will become famous soon enough ThrashZone will become famous soon enough ThrashZone will become famous soon enough ThrashZone will become famous soon enough ThrashZone will become famous soon enough ThrashZone will become famous soon enough ThrashZone will become famous soon enough
ThrashZone's Avatar
Hi,
Mostly considered a good sample with 1.3v for 4.5 on 5930k
5820k is supposed to do better
Newer bios mostly for broadwell-e jolts vccio cpu 1.05 voltage to 1.25v which might of fried the chip and possibly taken out the board too seeing everything I've read says don't exceed 1.2v ever.
Also said to jolt vccsa well over 1.2v
Lastly ai suite is pure crapware never install it.
Do all oc edits in bios.
i9-7900x With evo and koolance vrm water blocks
ASUS Prime X299 Deluxe
Trident Z 3600C16 4x8gb's
Samsung 850 Pro 256gb for os and 500gb evo for favorite games plus other wd hdd's for data and backup's
Optical Drive
LG Blu-Ray WH16NS40
evga 1200P2
corsair 450D
Operating System
win-7 pro & 10 pro
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
redragon
i7-5930k with evo and koolance vrm water blocks
X99 Sabertooth
Trident-Z 3200C14 4x8gb's
EVGA 1000w P2
Corsair 450D
Operating System
win-7 and 10 pro
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon
eLeaf MELO-3 4ml
SMOK Alien 220w
Operating System
VapeWild RazzleBerry 50-50-3mg
ThrashZone is online now
Old 01-28-2019, 07:05 AM - Thread Starter
Insr33 Level 1
Insr33's Avatar
Quote: Originally Posted by ThrashZone View Post
Hi,
Hi, I have changed all in BIOS which happens to call "AI Tweakers zone" There I setup manual mode for multiplier and CPU voltage..
Insr33 is offline
Old 01-28-2019, 07:38 AM
ThrashZone's Avatar
Hi,
Good I was just saying ai suite shouldn't be used just incase you did have it installed.
Do you remember what memory frequency was being used ?
Someone else also showed just raising it will cause vccio cpu 1.05 voltage to spike to 1.25v as well if left on auto :/
ASUS didn't do any of use haswell-e users any favors on broadwell-e bios so which bios were you on ?
2101 is what I'm on it's the last bios that didn't spike vccio cpu 1.05v to 1.25v by leaving it on auto :/
Optical Drive
LG Blu-Ray WH16NS40
evga 1200P2
corsair 450D
Operating System
win-7 pro & 10 pro
Keyboard
Mouse
redragon
X99 Sabertooth
EVGA 1000w P2
Corsair 450D
Operating System
win-7 and 10 pro
Mouse
Red Dragon
eLeaf MELO-3 4ml
SMOK Alien 220w
Operating System
