OC Frame compatibility issues with EVGA Z390 Dark? - Overclock.net - An Overclocking Community
post #1 of 1 (permalink) Old 02-02-2019, 06:31 AM - Thread Starter
dante`afk's Avatar
Rep: 8 (Unique: 8)
So I installed this little tool here yesterday: http://www.performance-pcs.com/der8a...-oc-frame.html
But I cannot get my CPU to run with it, I'm always ending up in a bootloop with numerous Q-Codes showing. I've unmounted/remounted/readjusted the tool multiple times and went between stock frame and OC frame back and forth. My CPU runs with the stock frame, but not with the OC frame.
My waterblock is the Heatkiller IV, I've tried very light pressure (tightening the screws), light pressure, and no screws at all, makes on difference. I'm using LM between DIE and block.
Is the frame conductive, meaning if there is only a slight drop of LM on the frame it could cause issues?
i9 9900k 5.3ghz - evga z390 dark - corsair ax1200i
16 GB g.skill tridentZ 4500 CL 17 - 2080Ti RTX 2160/8000
960PRO 512GB NVMe - 960EVO 512GB NVMe - SanDisk Ultra II 960GB - WD caviar black 3x 4tb
Lian Li O11 - ASUS ROG PG279Q Gsync @ 165hz - 2x Qnix2710 @ 120hz - klipsch promedia 2.1
http://beta.speedtest.net/result/6850164303.png
dante`afk is offline
