Overclocking i7-9700k Results and Questions - Page 12 - Overclock.net - An Overclocking Community
post #111 of 121 (permalink) Old 11-10-2019, 11:10 AM
wingman99's Avatar
Rep: 63 (Unique: 46)
Quote: Originally Posted by 8051 View Post
Why is my 9700K throttling? I have it at 5.1 Ghz., 1.38V Vcore, VCCSA = VCCIO = 1.15V. When running orthos on all cores in blend (stress CPU and RAM) on the "high performance" power profile it inevitably throttles down to 4.9 Ghz. even though the core temps don't exceed 73 degrees C. I'm running it on a z390 Asrock Taichi w/4 sticks of DDR4 at 3216 Mhz (because I'm running my BCLK at 100.5 Mhz.).
You may need to adjust your power limits and max current limits.
i5 8600K OC 5.0GHz
Noctua NH-U14S
Motherboard Gigabyte Z370-HD3
G.SKILL Ripjaws v 16GB F4-3200C14D-16GVK XMP Speed 3200 14-14-14-34
EVGA GeForce RTX 2070 XC ULTRA GAMING
ASUS VG279Q 27" 1920x1080p 144Hz IPS panel G-Sync compatible
wingman99 is offline
post #112 of 121 (permalink) Old 11-11-2019, 04:33 PM
Rep: 0
Hi,
Im pretty new to this forum, to overclocking, and english isnt my first lengague so beer with me.🍻
I got a new system and after a little research i decided to overclock it and these are my results:
9700k 5ghz @1.28v(override) / LLC set to TURBO / vccio = vccsa = 1.11 (i can lower those) / AVX offset = 0 / Temps on blender benchmark stay on the high 70s peaking on the mid 80s.
On Hwinfo64 my voltage drop a little under load (idle @1.273v -> load @1.24v) on the VR Vout reading, but go up and down slightly on the Vcore reading (they go from 1.284v to 1.308v and keep jumping around with quick random spikes of 1.32v, these spikes are quite rare). These voltages where taken after an entire loop of Blender benchmark.
My question is if its safe to let LLC on turbo(there are 2 more aggressive LLC options above turbo) i assume it is if the VR Vout is accurate.
System:
Mobo- Gigabyte z390 UD
Cpu- i7 9700k
Cooler- Scythe Fuma 2
Psu- xfx Xtr2 650w
Ty in advance.
Edit: Photo of Hwinfo voltages and added some more info
Daniel Erbe is offline
post #113 of 121 (permalink) Old 12-11-2019, 03:44 AM
qefir's Avatar
Rep: 0
9900k R0 [email protected] but 5600 not stable. Watercool , water 25C. need colder water required
Full stable [email protected] in gaming
qefir is offline
post #114 of 121 (permalink) Old 12-15-2019, 02:17 AM
8051's Avatar
Rep: 27 (Unique: 21)
Are there any gotchas associated w/BCLK overclocking of the 9700k in the 107 Mhz. range? I'm using BCLK primarily to overclock my RAM.
8051 is offline
post #115 of 121 (permalink) Old 12-15-2019, 10:29 AM
ForNever's Avatar
Rep: 109 (Unique: 99)
Quote: Originally Posted by jfriend00 View Post
There seems to be no specific general thread about overclocking the i7-9700k so I thought I'd create a master thread where people can post their experiences and their questions about overclocking this specific processor.
If you have a successful overclock, please post the following:
  • Motherboard
  • Clock speed
  • Type of cooler
  • AVX offset
  • CPU voltage setting (either manual or adaptive)
  • VCCIO and VCCSA voltages (which seem to effect CPU temps)
  • Observed CPU Voltage from HWInfo64 (VR Vout or VCore if no VR Vout) when stress testing
  • What stress test you did
  • Max core temperature during stress test
  • Uncore/cache speed
If you have a question about your system, please include as many of the above as you have in your question.
Gigabyte Z390 Aorus Elite
5 ghz
Heatkiller waterblock with peltier 2 stage chiller
AVX offset - 0
1.3 vdc - manual
VCCIO/VCCSA - untouched
1.3 volts measured via cpuz during p95 small fft's
163F/72C max temp after 4 hours p95
uncore - 47
Heat is higher than I'd like, but manageable. Huge upgrade from 3770k, jesus.
If it's not hot enough to hurt when you touch it, then it's very cool. - TwoCables
ForNever is offline
post #116 of 121 (permalink) Old 12-22-2019, 06:54 AM
gecko991's Avatar
Rep: 1 (Unique: 1)
Fresh 9700k build on liquid, not a bad chip so far.
Name:	Cinebench R15 at 5353mhz.png
gecko991 is offline
post #117 of 121 (permalink) Old 12-23-2019, 05:50 PM
shredzy's Avatar
Rep: 39 (Unique: 32)
Got my 9700K to 5GHz with 1.285V adaptive and LLC at 5 (ASUS Strix Z390-F), ran OCCT for over 6 hours with no errors. Required abit of tweaking with vcore but its looking good so far, played some games on it the past few nights.
Only thing I got concerned about was when I left my VCCSA/VCCIO on auto with my XMP profile turned on (3600mhz, C18, 1.35V)....this jumped the voltages to 1.40V on VCCIO, 1.45V on VCCSA, only ran these for about 10mins of stress testing and my 9700k was hitting 90c with linpack (vcore at 1.30V). After some research, these voltages are apparently very dangerous so I've put them manually to stock and its been fine so far.
Only weird thing that happened with these voltages was my USB on boot wasn't working till I replugged everything....not sure if it was because I was manually shutting the PC down at times, hope I haven't messed anything up with those voltages that high.....damn auto voltage values.
shredzy is offline
post #118 of 121 (permalink) Old 12-23-2019, 08:06 PM
gecko991's Avatar
Rep: 1 (Unique: 1)
What board are you running. I am on liquid in one of my torture racks so temps are not a problem. I am currently using An Asus Prime A Z390 with Gskill F4 3600 at 3800 and still trimming.
gecko991 is offline
post #119 of 121 (permalink) Old 12-24-2019, 01:56 AM
shredzy's Avatar
ASUS Strix Z390-F
Only using a Kraken x62 here with noctua fans, temps are much better when I lowered the vccsa/vccio to stock volts, still have my memory running at 3600mhz CL18 1.35v
shredzy is offline
post #120 of 121 (permalink) Old 01-17-2020, 08:08 PM
Rep: 0
Can you overclock a 9700k with a cheap motherboard?
can you overclock a 9700k or 9700f with a b360 motherboard or do you need a z390 board?
ThorOdin is offline
