Overclocking i7-9700k Results and Questions - Page 16 - Overclock.net - An Overclocking Community
post #151 of 159 (permalink) Old 05-14-2020, 07:20 PM
EarlZ's Avatar
Rep: 27 (Unique: 25)
Quote: Originally Posted by Darkz0r View Post
You said "I tried setting Vcore to 1.340 and I end up getting 1.352 via VRout reading and I still get a BSOD but it took a while".
What I meant was: set 1.35 in BIOS and see if it's stable (also check the new VRout that should be a little bit higher than 1.352 but within OK ranges). If you are just checking what voltage you need to be able its not a problem going to 1.4 if your cooling can handle it.
That would mean around 1.367v, Not gonna go there as of now as I do not know the safe voltages for these chips.
This on 5ghz? "Adaptive voltage at +0.020 sits around 1.340 on my end so using -0.5 is extremely low". If yes seems better than going 1.35+ fixed!
I am not even stable at 1.356, I dont see the point in lowering it to under 1v, -0.5 offset is around 0.775v on my end.
Try turning off XPM and using auto RAM settings to stress test CPU OC (AFAIK on auto it sets to some crap default low speeds which is very stable). Then after you stress your CPU OC you can go manual RAM settings and see what works.
At the moment, I am not interested in doing any RAM OC. so XMP profile is fine with me.
9700K / Gigabyte Z390 Master / Gigabyte 2080TI Gaming OC / 32GB G.Skill Trident Z RGB 3200Mhz CL16 / Samsung Evo 860 & 850 500GB / Creative Sound Blaster Z / Acer Predator X34P
EarlZ is offline
post #152 of 159 (permalink) Old 05-18-2020, 07:17 PM
Rep: 0
Here is my contribution,
Started with a clock of 4.8 whch did well at 1.35V but would fail some tests. using OCCT 1hr no AVX, so it was getting hot...
Switched to an offset voltage of -75 mHz and it was stable no failures.
Went back in BIOS and set -100mHz (maximum) & turned up clock to 49
Average core temps are around 75-85C, VCore ~1.31 to 1.33
It pretty damn stable. But i am wondering why the offset was so much more stable. I guess it dealt well with fluctuationg VCore and the static VCore was too hot.
9700k
ASrock Phantom Gaming 4
VCCIO and VCCSA are on auto since they seem low compared to the readouts others gave in this thread. About 0.95 and 1.15 respectively
I'm going back in for the RAM now
Dan4451 is offline
post #153 of 159 (permalink) Old 05-20-2020, 09:21 AM
Darkz0r's Avatar
Rep: 0
9700k
Very nice! I see people having success with offsets and adaptive voltages on these new chips.
I don't have any scientific knowledge to support this but to me, as a regular gamer/OCer, it seems older chips worked better with fixed voltages/clocks and newer chips are working better with variable volts/variable core per clocks/sometimes even power-saving settings on, etc....
The RAM OC guide I posted helped me a lot. I'm pretty stable atm but will lower timings a bit more and test!
Darkz0r is offline
post #154 of 159 (permalink) Old 05-20-2020, 06:37 PM
EarlZ's Avatar
Can you link me to this RAM OC guide ?
EarlZ is offline
post #155 of 159 (permalink) Old 05-20-2020, 08:24 PM
munternet's Avatar
Rep: 31 (Unique: 13)
There are two ram guides linked in my sig. One is older and fairly simple and the other is a little more advanced
Github Memory Overclocking Tutorial
GSAT in Windows 10 https://www.overclock.net/forum/1805...l#post28448038
Maximus XI Gene Overclocking Results Thread https://www.overclock.net/forum/5-in...k-results.html
9900ks
Asus Maximus XI Gene
EVGA 1080 Ti Superclock 2 Black
F4-4400C19D-16GTZSW
Samsung M.2 1TB 970 EVO Plus
Corsair HX1200i
EK 140D5 Pump, waterblocked CPU, Ram, GPU with 1 x 360mm and 1 x 420mm Radiators and Vardar Furious Fans
ThermalTake V51
Operating System
Windows 10 Pro
Asus PG349Q 34.1 inches 3440 x 1440 pixels @ 120 Hz
Keyboard
Corsair K95 RGB Platinum
Mouse
Logitech Gaming Pro Wireless
Mousepad
1000x500x3
Audio
Steelseries Siberia800 wireless Headset
8700k @ 5.2ghZ
Maximus X Hero
32GB 1xF4-4400C19D-16GTZSW & 1xF4-4400C19D-16GTZKK
Corsair HX1200i
ThermalTake V51
Operating System
Windows 10 Lite
Keyboard
Mouse
Asus Spatha Wireless Gaming
Mouse
Ligitech G602 wireless
Mousepad
1000mm x 500mm
Audio
i7-4770k
Asus Maximus VII Ranger
Gigabyte NVIDIA GeForce GTX980
G.SKILL Trident X 16GB 2 x 8GB 2400 Memory F3-2400C10D-16GTX
Seagate Barracuda 2TB
Optical Drive
LG DVD Rom
PSU Coolermaster V1000W
Custom Loop
Case Thermaltake V51 Full Window
Operating System
Windows 7
Shimian 2650x1440
Keyboard
Thermaltake Poseidon Z
Mouse
Logitech G602
munternet is offline
post #156 of 159 (permalink) Old 05-20-2020, 10:25 PM
EarlZ's Avatar
Now I remember why I never bothered to deal with memory overclocking haha! Too many values to tweak. I might just do a clock speed OC as I have the 16-18-18-36 3200Mhz G.Skill Trident. maybe a quick 3866 will do ?
EarlZ is offline
post #157 of 159 (permalink) Old 05-21-2020, 01:34 PM
Darkz0r's Avatar
Rep: 0
LOL, yeah, tell me about it!
I don't have much patience to keep changing settings, restarting and stress testing but it's so worth it. I got quite a bit more performance with this guide versus default setting. If XMP works for you that might do it but for me the default XMP profile didn't work, even with higher volts.
Try to follow it, despite it being uber LONG you can skip all the first pages and go straight to the "steps" it suggests. It shouldn't take such a long time.
Basically you go for the highest Mhz possible on the first step (like I have a 4000mhz chip but it's only stable at 3800mhz), then you go to tertiary timings (until you get unstable, lowering a bit then testing) then secondaries (or something like that...).
The way I did it as to not get annoyed with all the testing /restarting is: whenever I'm playing single player games (like bannerlord currently) I'd do "one step" of the guide and at the next restart I'd go lower and lower until crash / instability. Then I'd move to the next step. Since bannerlord uses 100% cpu/GPU frequency I think it's enough of a test.
Since I AFK due to kids/wife I also let mem test run whenever I change settings. I'm still not done with my RAM but each day it gets a little better and I don't burn myself only doing OC all day lol
Darkz0r is offline
post #158 of 159 (permalink) Old 05-21-2020, 04:25 PM
EarlZ's Avatar
I am not sure which overclocking guide you are following, is this it = https://github.com/integralfx/MemTes...OC%20Guide.md/
EarlZ is offline
post #159 of 159 (permalink) Old 05-22-2020, 02:19 PM
Darkz0r's Avatar
Rep: 0
Yup! That guide is quite awesome!
Darkz0r is offline
