Overclocking i7-9700k Results and Questions - Page 4 - Overclock.net - An Overclocking Community
post #31 of 164 (permalink) Old 02-14-2019, 02:21 PM - Thread Starter
Memory Overclocker
Rep: 24 (Unique: 10)
Quote: Originally Posted by Kaltenbrunner View Post
Can u still use the which ever setting down clocks the CPU ? I would like to try offset voltage OC, but what voltage level is the base or reference ? Is it what ever the CPU would get at stock clocks, if u set auto?
When specifying an offset voltage, it is applied to what the auto voltage would have been so you can make it go either higher or lower than the auto voltage by specifying a positive or negative offset.
Remember, the auto voltage comes from the VID which is the processor continually telling the motherboard how much voltage it wants at any instantaneous moment for the speed, load and types of instructions that is happening then. This allows the motherboard to more accurately track what the CPU thinks it needs.
An advantage of using "offset" (which is called "adaptive" in some other motherboards) instead of "fixed" voltage is that when the load is lighter and the CPU doesn't need as much voltage, the motherboard can down voltage and use less power and create less heat.
[email protected] (-1 AVX offset) on ASRock Z390 Taichi with Noctua NH-D15 air cooler
CPU offset voltage of -25mv, runs VRVout 1.240-1.313V on full AVX load, 1.225-1.275V on non-AVX load
2x8GB [email protected] at 1.45V, G.Skill F4-3733C17Q-32GTZKK (XMP rated [email protected])
EVGA GTX 1060 6GB OC with Corsair RMx 750W power supply
Samsung 970 EVO 500GB NVMe boot SSD and four other drives all in a Fractal Design R6 Case
jfriend00 is offline
post #32 of 164 (permalink) Old 02-19-2019, 03:07 PM
wingman99's Avatar
Rep: 63 (Unique: 46)
Quote: Originally Posted by jfriend00 View Post
There seems to be no specific general thread about overclocking the i7-9700k so I thought I'd create a master thread where people can post their experiences and their questions about overclocking this specific processor.
If you have a successful overclock, please post the following:
  • Motherboard
  • Clock speed
  • Type of cooler
  • AVX offset
  • CPU voltage setting (either manual or adaptive)
  • VCCIO and VCCSA voltages (which seem to effect CPU temps)
  • Observed CPU Voltage from HWInfo64 (VR Vout or VCore if no VR Vout) when stress testing
  • What stress test you did
  • Max core temperature during stress test
  • Uncore/cache speed
If you have a question about your system, please include as many of the above as you have in your question.
I would change the thread title to "Overclocking i7-9700k Results and Questions" for more hits on this thread.
i5 8600K
Noctua NH-U14S
Motherboard Gigabyte Z370-HD3
G.SKILL Ripjaws v 16GB
EVGA GeForce RTX 2070 XC ULTRA GAMING
ASUS VG279Q 27" 1920x1080p 144Hz IPS panel G-Sync compatible
wingman99 is offline
post #33 of 164 (permalink) Old 02-19-2019, 04:10 PM - Thread Starter
Memory Overclocker
Done.
post #34 of 164 (permalink) Old 02-19-2019, 04:33 PM
wingman99's Avatar
Done.
Thanks I want to see more folks here.
i5 8600K
Noctua NH-U14S
post #35 of 164 (permalink) Old 02-19-2019, 04:35 PM - Thread Starter
Memory Overclocker
Did you get a replacement i7-9700k from Silicon Lottery yet (or am I confusing you with someone else)? If so, how's it going?
post #36 of 164 (permalink) Old 02-19-2019, 05:09 PM
wingman99's Avatar
I returned my i7 9700k to silicon lottery, now I'm going to try retail waiting for a sale on the i7 9700k the prices are to high. MSRP is $374.00
i5 8600K
Noctua NH-U14S
post #37 of 164 (permalink) Old 02-19-2019, 05:21 PM - Thread Starter
Memory Overclocker
Yeah, prices have ticked up a bit. I paid $409.99 from B&H in early Dec. They are now $434.99. From the discussion here on overclock.net, I would have thought that more people were going for the i9-9900K and that few were buying the i7-9700K, but apparently there aren't lots of i7-9700K's sitting around or the price wouldn't be up. Perhaps Intel underestimated demand and didn't make enough?
Maybe the i7-9700KF will affect things somehow when it hits the market? Unless it is somehow demonstrated to be better at overclocking, it has to cost less even though list price is supposedly the same.
post #38 of 164 (permalink) Old 02-19-2019, 05:38 PM
wingman99's Avatar
Yes the demand for the i7 9700k is high or supply is low, the pricing shows that since Intel MSRP $374.00. Hopefully I can see more examples in this thread on how well the new batches are overclocking.
i5 8600K
Noctua NH-U14S
post #39 of 164 (permalink) Old 03-02-2019, 06:30 AM
dricks's Avatar
Rep: 12 (Unique: 12)
z390 Aorus Master Gigabyte
5.0G/4.9AVX
h115i RGB ¨Platinum (280 AiO)
Avx -1
1.365 vcore in bios with LLC Turbo
VCCIO/VCCS Auto
4.3G Uncore
Using 4*8 GB GSkill Trident Z RGB (rated 4266) @4000Mhz 1.4v 19/19/19/39
Idle:38°
Cinebench : 72°
Prime 95 With AVX and SmallFFT 99°
Seems to be an average quality from silicon lottery
A bit disappointed that i can't reach 5.1 or 5.2 without stability issues, but 100% stable with 5.0/4.9avx
dricks is offline
post #40 of 164 (permalink) Old 03-02-2019, 08:30 AM - Thread Starter
Memory Overclocker
5.0G/4.9AVX
Avx -1
VCCIO/VCCS Auto
4.3G Uncore
Idle:38°
Cinebench : 72°
Maybe this sounds counterintuitive, but I only got 5.1 stable on my 9700k when I went to adaptive mode (with an offset voltage) instead of fixed voltage. I don't know if I just wasn't trying a high enough fixed voltage or if there is something else in play. I always wanted to end up in adaptive voltage anyway so this worked out nicely for me.
What timings was your DRAM set originally rated for?
What led you to lower the uncore speed?
