Help my cool 9900k/RTX 2080 Ti (cooled) - Page 3 - Overclock.net - An Overclocking Community
post #21 of 71 (permalink) Old 02-16-2019, 10:10 PM
postem's Avatar
Rep: 17 (Unique: 12)
Quote: Originally Posted by Yomny View Post
Using Realbench. I max out at 90C but its usually anywhere from 70-85C considering a 23C ambient, not sure its too bad. I'll wait for the thermal past and liuid metal to settle in and give it another go. Right now i could only get 4.9ghz with no avx offset, cache 48 get pretty decent bench results. 5ghz with this boards seems to not be possible. Tried all sorts of vcore, cache speeds, AVX offset...no luck. I could post and run benchmarks, play games but cant pas realbench.
I was considering 9900K, but, besides the extra cost, i am worried about those temps.
With 8700K @ 5ghz 1.34v, its dellided, but on noctua dH15 i managed to max 75c on realbench on a day with 32c ambient on my room, so 43c delta. 8700k rocks like a champion, on colder days like today i run it around 65c its really awesome.
I know the thing is you want to run it fully under 5ghz, but there are options:
a) Use some 360mm AIO, but with loudy fans
b) Consider lowering it to 4.8ghz. As far as i checked around, its a sweet spot between frequency x voltage x temps
c) direct mount
d) lapping the die
AFAIK, part of the issues are due to the bigger diffusion barrier that intel increased to deal with the solder.
postem is offline
post #22 of 71 (permalink) Old 02-17-2019, 06:50 AM - Thread Starter
Yomny's Avatar
Rep: 20 (Unique: 16)
c) direct mount
d) lapping the die
The 360 is prob the way ill end up going. I also have it running at 4.9ghz with no avx offset and 46 cache and its really happy there, using 1.27vcore under stress. The thing that bugs me is the difference in vcore in various loads. For example, under gaming i get 1.32vcore, Realbench 1.27
Ive also delidded the bastard and used a bigger cooper IHS which im assuming is helping temps. I'd just hate to spend nearly $200 for a new cooler and have it be worse than what i have lol. All this for the same of overlcocking because the 9900k at stock frequencies is great, it's already pushing 47 on all cores and touches 50 on a few cores while loaded. Mind you, some people get 5.1 at 1.32vcore without issues, not many but 5.0 under 1.3vcore also without hiccups. Ive just never had much luck with that or my testing methods are too strenuous.
I do appreciate your input.
Corsair
(9 items)
Core i9 9900k 4.9ghz @1.3
Asrock Z390 Extreme4
RTX 2080 Ti EVGA HC Waterblock
G.SKILL TridentZ Series F4-3000C15D-16GTZ
Samsung 970 Evo m.2 1TB
EVGA SuperNOVA 850 G3
HWL 280-120mm CPU/GPU
Corsair 460x RGB
Operating System
Win 10
Yomny is offline
post #23 of 71 (permalink) Old 02-18-2019, 02:38 AM
Knowledge is Success
Knoxx29's Avatar
Rep: 2 (Unique: 2)
I was considering getting a 9900K myself but i refuse to give up to my 8086K which is a damn good overclockable one.
BlackWidow
(16 items)
SR 2 Prototype
(11 items)
Intel i7 8086K
Asus Rog Maximus XI Extreme
EVGA GeForce GTX 1080 Ti FTW3 GAMING
G.skill F4-3866C18Q-32GTZ
Samsung 970 Evo
Samsung 960 Evo
Samsung 850 Evo
Samsung 840 Evo
Western Digital Black
Western Digital Blue
Enermax platimax
Waterchiller
Lian Li V3000
Operating System
Windows 10 pro
Asus rog swift pg278q
Xeon X5677
Evga SR 2
Geforce Gtx 1080 classified
G.Skill RipjawsX
Samsung 850 Evo
Western Digital blue
Enermax Platimax 80Plus Platinum OC Edition
ARCTIC Freezer XTREME Rev. 2
Lian Li PC-A75WX
Operating System
Windows 7 Ultimate
Asus ROG SWIFT PG278Q
Knoxx29 is offline
post #24 of 71 (permalink) Old 02-18-2019, 05:23 AM - Thread Starter
Yomny's Avatar
I think that's a good choice lol specially with the cost of the 9900k.
Corsair
(9 items)
Corsair 460x RGB
Operating System
Win 10
Yomny is offline
post #25 of 71 (permalink) Old 02-18-2019, 05:43 AM
Overclocked
scracy's Avatar
Rep: 116 (Unique: 83)
Unfortunately Intel started messing up things since they launched the 7700K ( temp spikes )after that they wanted to offer CPUs with more cores and high clock speed which leaded to high temps and from now on who wants to buy an Intel CPU needs to buy/build a Watercooling System, well done Intel
Sadly this is the case the amount of power a 9900K draws during a decent stress test requires a custom loop, the only way around this would be to get a very low voltage 9900K sample. Even with my custom loop [email protected] 1.344V (load) my temps spike at 80 degrees C with a 23 degrees C ambient running OCCT large data sets which doesn't produce as much heat as AIDA64 with FPU option ticked which topped out at 91 degrees C with a 30 degree ambient. Bottom line depending on the custom loop your basically limited to a Vcore of around 1.35V under load.
ROG Maximus X Formula, Intel Core [email protected]/4.8Ghz Cache 1.344V (OCCT Load) (OCCT Stable), Corsair Dominator Platinum ROG Edition [email protected], EVGA GTX1070 SLI, Samsung 960 Pro x2 (Raid 0) (O/S), Samsung 850 Pro x4 (Raid 0) (Data)
ROG THOR 850W PSU, EK Custom Loop 2x PE-360 Radiators, Corsair ML120 Pro Fans, Phanteks Evolv X, Creative Soundblaster Z, Woo Audio WA7D, Sennheiser HD660S, ROG PG279Q 2560x1440 165Hz IPS Monitor, Windows 10 Pro Build 1809.
scracy is offline
post #26 of 71 (permalink) Old 02-18-2019, 06:39 AM
Shawnb99's Avatar
Rep: 45 (Unique: 31)
91c for the CPU would scare the hell out of me
I just upgraded to a 9900k myself and seeing all these high temps has me concerned. Glad I have a custom loop cause i could never accept temps that high. I’d worry it would burn itself out that high
My Baby
(23 items)
Delidded Direct Die I9 9900K
ASUS Maximus XI Apex
EVGA FTW3 Hydro Copper GeForce RTX 2080 Ti
G.SKILL TridentZ Series 16GB DDR4 3600 F4-3600C15D-16GTZ
2x Samsung 970 EVO Plus 1TB
Asus Hyper M.2 card
2 x Intel 660P 2TB
Seasonic PRIME Ultra 1000 Titanium
Optimus Signature V2
2x Swiftech MCP35X2 with MCP35X2 Heat Sink w/ 2x NB-BlackSilent Pro's
2x Hardware Labs Black Ice Nemesis 560GTX w/ 8x Arctic P14 PST PWM's
2x Hardware Labs Black Ice Nemesis 480GTX w/ 16x Noctua NF-A12x25 PWM
Aquacomputer aqualis XT 450 ml with nano coating
9x Noctua NF-S12A PWM
Hardware Labs Black Ice Nemesis 360GTS w/ 6 Arctic P12 PST PWM's
Case Labs Magnum TH10A with Pedestal
Asus PG278Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Light Harmonic Oscar XXI
Audio
Geek Pulse Inifnity DAC/AMP
Audio
Cavalii Audio Liquid Carbon HPA
Other
Aquacomputer Aquaero XT
Shawnb99 is online now
post #27 of 71 (permalink) Old 02-18-2019, 06:49 AM
Overclocked
scracy's Avatar
Keep in mind though that's worst case scenario with relatively high ambient temperature. Real world it wouldn't get that high in day to day use in most cases.
scracy is offline
post #28 of 71 (permalink) Old 02-18-2019, 06:58 AM
Knoxx29's Avatar
Rep: 2 (Unique: 2)
At least for me heat wouldn't be problem my Watercooling System could handle the hotter 9900K out there.
It's not because the price, i paid more for the 8086K than what a 9900K cost.
BlackWidow
(16 items)
SR 2 Prototype
(11 items)
Intel i7 8086K
Samsung 970 Evo
Samsung 960 Evo
Samsung 850 Evo
Samsung 840 Evo
Enermax platimax
Waterchiller
Lian Li V3000
Operating System
Windows 10 pro
Xeon X5677
Evga SR 2
G.Skill RipjawsX
Samsung 850 Evo
Lian Li PC-A75WX
Operating System
Windows 7 Ultimate
Knoxx29 is offline
post #29 of 71 (permalink) Old 02-25-2019, 11:50 AM - Thread Starter
Yomny's Avatar
So i'm really close to pulling the trigger on a water loop. Sadly, contradicting my initial post, i see this cpu isn't working nicely with air coolers, not mine at least as i need over 1.3vcore for 5ghz. Now the concern, my GPU temps. The only way i could fit a nice 280mm rad is up front(360's don't fit) and that would really require me to use the fans as intake for optimal cooling. The only way to get rid of the hot air coming into the PC and helping rid the GPU of the hot air its generating is having two or three fans sucking all that air out, so negative pressure, hence dust. I dont think using two top fans as intakes will help as the cold air from the top will be pushed by the hot air the GPU is pushing up.
Opinions?
Corsair
(9 items)
Corsair 460x RGB
Operating System
Win 10
Yomny is offline
post #30 of 71 (permalink) Old 03-03-2019, 06:07 PM
Telstar's Avatar
Rep: 24 (Unique: 20)
If you haven't bought anything yet, I would consider the Alphacool eisbaer 360 normal or LT version (cheaper no lights). I'm pretty sure it can cool your chip at 5.0 at the required voltage. Less than 150 bucks and it IS better than the noctua "12" and all asetek-based AIOs.
Unfortunately your cpu doesn't look particularly lucky, the upper 30% require only 1.2v for 5ghz all core. But since you delidded it and put a nice copper HS, you should push it!
new rig 2019:
Intel 9900k >5ghz | Asus Maximus XI Gene | Eisbaer 360 LT (custom loop in progress) | bequiet! Dark Base 700 white edition | Team group Nighthawk 16GB 4000mhz | MSI RTX 2070 Armor | Storage: Intel Optane 900p 280GB + Samsung 970 evo plus 1TB + WD Red 3TB | Corsair HX850i | Benq BL3200PT 1440p | 1Gbit ftth |
Telstar is offline
