Delidding: nail polish when using non-conductive paste? - Page 3 - Overclock.net - An Overclocking Community
post #21 of 38 (permalink) Old 02-14-2019, 09:04 PM - Thread Starter
Свет
XLifted's Avatar
Rep: 36 (Unique: 35)
Quote: Originally Posted by The Pook View Post
Delid, put conformal coating/nail polish on the SMDs if you're worried, liquid metal on the die, wipe the excess on the inside of the IHS or put none if you put enough, put the lid on, put a drop of super glue on each corner of the IHS. ez.
I put nail polish on my first CPU I delided and left the following dozen or so alone. I didn't put any liquid metal on the underside of the IHS outside the first. All are fine (at least that I know about, @mllrkllr88 has 3 of them now )
Okay
Got you, either way is fine if it makes a good contact, haha
I appreciate it. Might as well just flip a coin on my decision
So here is what I have bought to get ready for installation (for anyone that does it first too)
1. Sally Hansen Color Therapy Nail Polish Top Coat (is not electrically conductive and does not erode the metals like other nail polishes [according to GamersNexxus video and notes]
https://www.gamersnexus.net/guides/3...d-liquid-metal
Buy it here: https://www.target.com/p/sally-hanse...z/-/A-51068156
2. Rockit Delid Tool and Cooper IHS for about 4-5 degrees drop vs Intel's IHS
You can buy it here: https://rockitcool.myshopify.com/pro...s-for-lga-1150
How to use this kit: https://rockitcool.myshopify.com/blo...-new-rockit-88
3. Thermal Grizzly Conductonaut High Performance Thermal Grease - 1g (Liquid Metal)
Buy it here: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
4. Permatex 82180 Ultra Black Maximum Oil Resistance RTV Silicone Gasket Maker, 3.35 oz. Tube
For putting a tiny bit on the corners to seal the cpu back up.
5. Rubbing alcohol 91%, get this high, because it's a pain to remove thermal compound with 50% or even 70% alcohol solutions.
XLifted is offline
post #22 of 38 (permalink) Old 02-14-2019, 09:21 PM
The last VRM burner
Rep: 4 (Unique: 3)
I used a razor, Conductonaut, cheapest colourless nail polish, a cheapest thermal resistant silicone you'll find in any building market and a pair of tongs to squeeze the silicone (put it on the original path from Intel). These CPUs are not worthy spending this much money on them xD. Also, copper IHS is an overkill for 4 cores.
PC for all
(18 items)
i7 5775c @4.2GHz/3.8GHz
Gigabyte Z97X Gaming 5
EVGA GeForce GTX660 2048MB DDR5/192bit SuperClocked 1101MHz/1505MHz
2x KHX2400C11D3/8GX 11-12-12-32-1T-250
Samsung 850 Pro
Toshiba HDWD10 (P300)
Corsair CS650M
Raijintek Tisis + Arctic Cooling MX4
LianLi 330X
Operating System
Windows 10 64-bit Pro
Benq GL2250 80Hz
Keyboard
Corsair Strafe Red
Mouse
SteelSeries Rival 310
Mousepad
SteelSeries QCk Mini
Audio
Audio in Motion SC808
Audio
AKG K240 Studio 1st rev
Other
NZXT Hue+
Other
Mayflash F300
BroadPwns is offline
post #23 of 38 (permalink) Old 02-14-2019, 09:28 PM
white owl's Avatar
Rep: 126 (Unique: 96)
If you have a Haswell chip you don't need the tool. You can push the IHS off with a vise, I've done it to 3 CPUs now with no issues.
The only thing I'd buy is the LM, the nail polish my wife had already. The custom IHS has proven it's self to be not-worth it. If you want it flat, lap it. It's a $160 CPU these days, no sense in spending half it's value making it faster becasue you'll never get that money back unless you sell the tool.
There's nothing hard about removing paste with nothing other than a paper towel. Ripe off the bulk and use any alcohol to polish it off. I don't even do that much usually, just wipe it off lol.
Quote: Originally Posted by SpeedyVT
If you're not doing extreme things to parts for the sake of extreme things regardless of the part you're not a real overclocker.
Quote: Originally Posted by doyll View Post
The key is generally not which brands are good but which specific products are. Motherboards and GPUs are perfect examples of companies having everything from golden to garbage function/quality.
Hot n Bothered
(12 items)
4790k 4.7Ghz
Asus Sabertooth Z97 MkII 2
EVGA GTX 1080 SC
16gb G.Skill Sniper 2400Mhz
2x Kingston v300 120gb RAID 0
WD Blue
Seasonic 620w M12 II EVO
Cooler Master 212 Evo
Corsair 450D
Operating System
Windows 10
Nixeus EDG27
Other
I have pretty lights.
white owl is offline
post #24 of 38 (permalink) Old 02-14-2019, 10:56 PM - Thread Starter
Свет
XLifted's Avatar
https://www.youtube.com/watch?v=Fo1KzqCQurk
It's not big deal, it was 20 bucks for delid tool and copper IHS but I get you, I don't have 300+ bucks to spend, because I also would need new motherboard as well, and DDR4, while I have DDR3 32 gbs now
Do you suggest putting LM all over IHS, or just the center point at the size of the die below?
XLifted is offline
post #25 of 38 (permalink) Old 02-14-2019, 11:10 PM
white owl's Avatar
Only where the die is.
Hot n Bothered
(12 items)
4790k 4.7Ghz
EVGA GTX 1080 SC
WD Blue
Corsair 450D
Operating System
Windows 10
Nixeus EDG27
Other
post #26 of 38 (permalink) Old 02-15-2019, 07:59 AM
21Dante's Avatar
Rep: 0
I haven't even glued the ihs on the chip.
The socket holds it and there is no reason to remove it.So since it works,I'm not messing with it and I'll propably sell it like that too.
21Dante is offline
post #27 of 38 (permalink) Old 02-15-2019, 04:24 PM - Thread Starter
Свет
XLifted's Avatar
Got it! Thank you
:-D You are living on the edge bro
"probably sell it like that too." - that made me chuckle )
XLifted is offline
post #28 of 38 (permalink) Old 02-15-2019, 05:18 PM
white owl's Avatar
I don't glue mine. No reason to really unless you just like removing the CPU a lot. Mine is also being sold that way. Ships to Canada Monday.
Hot n Bothered
(12 items)
4790k 4.7Ghz
EVGA GTX 1080 SC
WD Blue
Corsair 450D
Operating System
Windows 10
Nixeus EDG27
Other
post #29 of 38 (permalink) Old 02-16-2019, 04:06 AM
21Dante's Avatar
Rep: 0
To know where to apply lm on the ihs,just apply lm at the die,and then put the ihs on.It will leave a mark and you'll have an idea as to where to apply lm there too.
21Dante is offline
post #30 of 38 (permalink) Old 02-19-2019, 12:17 AM - Thread Starter
Свет
XLifted's Avatar
XLifted is offline
