Delidding: nail polish when using non-conductive paste? - Overclock.net - An Overclocking Community
post #1 of 38 (permalink) Old 02-14-2019, 01:35 AM - Thread Starter
Свет
XLifted's Avatar
Rep: 37 (Unique: 36)
Do I need to nail polish the electrical points when delidding if I DO NOT use liquid metal, I will be using Noctua NT-H1 thermal paste. It states that it's not conductive.
Please let me know, this is my first delid on 4790k I had for about 4 years now. :-)
EDIT: So here is what I have bought to get ready for installation (for anyone that does it first too)
1. Sally Hansen Color Therapy Nail Polish Top Coat (is not electrically conductive and does not erode the metals like other nail polishes [according to GamersNexxus video and notes]
https://www.gamersnexus.net/guides/3...d-liquid-metal
Buy it here: https://www.target.com/p/sally-hanse...z/-/A-51068156
2. Rockit Delid Tool and Cooper IHS for about 4-5 degrees drop vs Intel's IHS
You can buy it here: https://rockitcool.myshopify.com/pro...s-for-lga-1150
How to use this kit: https://rockitcool.myshopify.com/blo...-new-rockit-88
3. Thermal Grizzly Conductonaut High Performance Thermal Grease - 1g (Liquid Metal)
Buy it here: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
4. Permatex 82180 Ultra Black Maximum Oil Resistance RTV Silicone Gasket Maker, 3.35 oz. Tube
For putting a tiny bit on the corners to seal the cpu back up.
5. Rubbing alcohol 91%, get this high, because it's a pain to remove thermal compound with 50% or even 70% alcohol solutions.
XLifted is offline
post #2 of 38 (permalink) Old 02-14-2019, 01:40 AM
white owl's Avatar
Rep: 136 (Unique: 103)
Not if it's normal paste. You can have good results with paste but you should spread it out yourself with a thin layer and remove all the black sealant used by Intel or you'll have small gaps under the IHS. If you use paste do not seal the CPU back up becasue it will dry out and you'll have to delid it again, we use LM becasue the thermal transfer is better but mainly becasue it never drys out under the IHS.
Quote: Originally Posted by SpeedyVT
If you're not doing extreme things to parts for the sake of extreme things regardless of the part you're not a real overclocker.
Quote: Originally Posted by doyll View Post
The key is generally not which brands are good but which specific products are. Motherboards and GPUs are perfect examples of companies having everything from golden to garbage function/quality.
Hot n Bothered
(12 items)
4790k 4.7Ghz
Asus Sabertooth Z97 MkII 2
EVGA GTX 1080 SC
16gb G.Skill Sniper 2400Mhz
2x Kingston v300 120gb RAID 0
WD Blue
Seasonic 620w M12 II EVO
Cooler Master 212 Evo
Corsair 450D
Operating System
Windows 10
Nixeus EDG27
Other
I have pretty lights.
white owl is offline
post #3 of 38 (permalink) Old 02-14-2019, 01:41 AM
ASUs fan
Rob w's Avatar
Rep: 3 (Unique: 3)
You only need to protect surrounding components if you are using electrically conductive Tim, so using NT-H1 there is no need
Rampage vi extreme
(14 items)
I7 6700k
Gskill
Samsung 850 evo m2 nvme
Samsung 850 evo ssd
Samsung 850evo ssd
Intel Optane 900 pcie
Be quiet dark power pro
Nzxt kraken x62
Corsair carbide 600D
Operating System
Win 10 home
I9-7980xe delided.
Rampage Vi extreme
Titan V
Gskill
Seagate hdd
Samsung 970 evo m2 nvme
Samsung 860 evo m2 nvme
Corsair hi 1200i
Ekwb
Ekwb
Hailea hc500a chiller.
Corsair obsidian 900d
Operating System
Win 10 home
Iama
Rob w is offline
post #4 of 38 (permalink) Old 02-14-2019, 02:38 AM
The last VRM burner
Rep: 41 (Unique: 24)
Keep in mind that the main reason behind delidding is replacing a TIM for something the most efficient and durable, paste will require changing after a "while". Reconsider using liquid metal.
PC for all
(21 items)
i7 5775c @4.2GHz/3.8GHz
Gigabyte Z97X Gaming 5
Iris Pro 6200
F3-2400C11D-16GAB Samsung Rev. Q
Corsair MP510
Samsung Evo 860
Seasonic Focus Plus 750W
Artcic Liquid Freezer II 360mm
Arctic P12 PWM x2
Arctic P14 x4
LianLi 330X
Operating System
Windows 10 64-bit Pro
Samsung C24FG73FQUX
Benq GL2250 80Hz
Keyboard
Corsair Strafe Red Silent + 1.6x6mm o-rings
Mouse
SteelSeries Rival 600
Mousepad
Artisan FX Raiden
Audio
Audio in Motion SC808 + MUSES8820 + 2x 2xLME49990
Audio
AKG M220
Other
NZXT Hue+
Other
Mayflash F300 Arcade Stick
BroadPwns is offline
post #5 of 38 (permalink) Old 02-14-2019, 03:50 AM
white owl's Avatar
I'd use LM too but I've seen results within a few C of LM with normal paste. As long as you know it won't last 5 years and you don't seal it up, there's really not a downside to just using paste.
It will still last a very long time.
Hot n Bothered
(12 items)
4790k 4.7Ghz
EVGA GTX 1080 SC
WD Blue
Corsair 450D
Operating System
Windows 10
Nixeus EDG27
Other
post #6 of 38 (permalink) Old 02-14-2019, 04:26 AM
21Dante's Avatar
Rep: 1 (Unique: 1)
It's very easy to do it,once you have removed the ihs.
So go for the liquid metal and just use polish at the vrms.
I delidded my 4690 2 years ago and temps are as good as they were then.
21Dante is offline
post #7 of 38 (permalink) Old 02-14-2019, 04:00 PM - Thread Starter
Свет
XLifted's Avatar
Just bought liquid metal because of your advice :-)
Would you suggest putting liquid metal on IHS too, or just the CPU die?
XLifted is offline
post #8 of 38 (permalink) Old 02-14-2019, 04:01 PM
The last VRM burner
CPU Die and inside part of IHS as well, I didn't do it once and had much worse effect in final performance.
PC for all
(21 items)
Iris Pro 6200
Corsair MP510
Samsung Evo 860
Arctic P12 PWM x2
Arctic P14 x4
LianLi 330X
Operating System
Samsung C24FG73FQUX
Benq GL2250 80Hz
Keyboard
Mouse
Mousepad
Artisan FX Raiden
Audio
Audio
AKG M220
Other
NZXT Hue+
Other
post #9 of 38 (permalink) Old 02-14-2019, 04:10 PM
white owl's Avatar
I've done it both ways with the same results but to be safe you might as well paint it on. The best thing I've found for spreading is those cheap paint brushes with nylon bristles. They don't absorb any at all.
Now you do need to clear over the caps. On Haswell the die is very close to the row of caps and the LM spreads out over time.
Hot n Bothered
(12 items)
4790k 4.7Ghz
EVGA GTX 1080 SC
WD Blue
Corsair 450D
Operating System
Windows 10
Nixeus EDG27
Other
post #10 of 38 (permalink) Old 02-14-2019, 04:19 PM
21Dante's Avatar
Rep: 1 (Unique: 1)
LM at both the ihs and the die.
But don't overdo it.
Also insualte carefully the vrms and you'll be ok.
I got minus 15C at my cpu.
At 4.6Ghz I hit 100C at 2 mins of prime.Now it won't pass 85C after hours of stressing.
21Dante is offline
