5820k, overclocking DDR4, need help - Overclock.net - An Overclocking Community
post #1 of 4 (permalink) Old 03-12-2019, 03:59 AM - Thread Starter
8051's Avatar
Rep: 25 (Unique: 19)
I have an old 5820k and some Corsair Vegneance LPX 2666Mhz. 16GiB 4x4GiB, CMK16GX4M4A2666C that I'm having real trouble overclocking. Anything over 3000 Mhz. results in a no-boot condition that requires a dozen resets to get back into the BIOS to fix. I've tried cranking the Vdimm to 1.45V and it didn't help.
The primary timings for this set are not good: 16-18-18-18-35 @ 2666Mhz./1.2V (the primary set of XMP setting) and 16-18-18-37 @ 2800 Mhz./1.35V(the second set of XMP settings). So far I've been working off the second set of XMP timings with command rate 2T for my attempts at overclocking at speeds >= 3000Mhz. Do the secondary and tertiary memory timings also have to be adjusted? Should I try increasing the primary timings?
8051 is offline
post #2 of 4 (permalink) Old 03-12-2019, 06:04 AM
Overclocker in training
ThrashZone's Avatar
Rep: 91 (Unique: 66)
Hi,
Frankly if you got above 2800 you should be happy with I suppose is micron memory chips with loose timings 2666C16 I assume.
If you want better get better memory
https://benzhaomin.github.io/bdiefinder/
3200C14 is the bomb on my 5930k
i9-9940x With Heatkiller IV Pro and VRM Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is offline
post #3 of 4 (permalink) Old 03-12-2019, 06:18 AM
Volt addicted OC fanatic
PloniAlmoni's Avatar
Rep: 17 (Unique: 15)
I have similar memory, CAS16, 2666, Corsair LPX, except for its 4x8gb modules. I couldn't get it to over 2666 on Ryzen, in fact, it wouldn't even do 2666 without extra voltage on that platform. It is at 2666 on x99 as well here, but with the profile's voltage. (I had to set some other settings manually, to *lower* than what XMP did on auto... my motherboard was overvoltaging my IMC.) Be glad you can get it to 2800 at all since it's "low quality" (i.e. cheap) RAM with those timing specs and fab.
AMD RGB
(16 items)
AMD FX-8320E
970 PRO GAMING/AURA
NVIDIA GeForce GTX 1070
Kingston Value RAM DDR3-1600 8GB
Western DIgital Caviar Blue
OCZ Vector 180 SSD
Plextor M8e
Optical Drive
Lite-ON DVD+-RW burner
Cooler Master Hyper 212 Evo
Cooler Master HAF 912 USB 3
Operating System
Windows 10 x64 Pro
ASUS VG248QE
Keyboard
Logitech G910
Mouse
Logitech G900
Mouse
Corsair mouse pad
PloniAlmoni is offline
post #4 of 4 (permalink) Old 03-12-2019, 12:06 PM
cloppy007's Avatar
Rep: 77 (Unique: 53)
I've also got a 5820k, Asus X99-S and LPX 3000MHz. It's impossible to run them higher than 2666 for me. First of all, you need to use the 125MHz strap, which was hard for me. On top of that, your CPU memory controller might not simple like running faster memory. Finally, not all memory can be overclocked, and certainly, this corsair modules are not renowned for its oc-ability.
Depending on your motherboard, it might set the system agent voltage higher depending on the chosen DRAM speed, you might want to play with that too.
Honestly, I would advise against wasting more time on this.
Current
Holiday rig
(8 items)
3Dfx
Intel Core i7 5820k
Asus X99-S
MSI Radeon R9 280X Gaming
Avexir DDR4-2400 C16 16GB(4x4) Platinum
Samsun SSD 850 EVO
Hitach HDT721010
Antec TP 550 New
EK Supremacy Clear CSQ
Alphacool XT45 360+240
EK-VGA Supreme HF
Swiftech MCP655-PWM
NZXT Switch 810
Dell S2340L
Intel Core i5 2500k
Gigabyte GA-Z68AP
Sapphire Radeon HD 6850
8GiB Samsung DDR3 green
Seagate 7200.11 1TB
Corsair 550W
Themalright ultra 120 eXtreme
CM Haf 912
Athlon XP 1900+
MSI KT3 Ultra ARU
3Dfx VooDoo 5 5500 AGP
512 MiB
Samsung 80GB
Optical Drive
(no name)
Enermax 350W
(no name)
Operating System
(no name)
(no name)
Keyboard
(no name)
Mouse
(no name)
Mouse
(no name)
cloppy007 is offline
