Massive Hitching - CPU Problem? - Overclock.net - An Overclocking Community
post #1 of 9 (permalink) Old 03-18-2019, 01:35 PM - Thread Starter
edgeofblade's Avatar
Rep: 20 (Unique: 18)
Just finished a build on an i9-9900k in a AsRock Phantom Gaming 9 and I'm having massive hitching issues on the desktop. Sometimes it captures the mouse and sometimes it just freezes in the middle of a window animation and holds there for about 10-20 seconds. Do you think that's a CPU problem?
I just finished installing AsRock's driver list, the latest GPU drivers, and Windows updates. It's a very fresh install.
I'm not much of an overclocker yet, but I did throw on the Multi Core Enhancement. Was that a mistake? CPU idling at 39C with Alphacool's Eisbaer 280mm stuffed in an CM HAF XB.
edgeofblade is offline
post #2 of 9 (permalink) Old 03-18-2019, 02:06 PM
skupples's Avatar
Rep: 630 (Unique: 342)
did you happen to install extra sata drivers outside of Intels?
These days, thanks to win10, all you really gotta do is push the NIC driver. Windows is smart enough to find the best driver for everything else in 99% of instances. Often times, you'll push a less optimal driver from the mobo install package.
skupples is offline
post #3 of 9 (permalink) Old 03-18-2019, 02:37 PM - Thread Starter
Thank you for being the first person on the internet to offer anything. :-)
Indeed, I did. This thing installs Win10 quickly, so I might just wipe out the install and start from the beginning.
Outside of the very custom NIC, even the chipset drivers will be installed by the updater? The onboard Wifi? The onboard bluetooth?
I am using a NVMe SSD. Any steps I should take to optimize for that storage?
post #4 of 9 (permalink) Old 03-18-2019, 02:56 PM
skupples's Avatar
Correct.
that super speed NIC is still an intel nic. like 99% of NIC in the world.
That's all I typically install, outside of GPU drivers.
Everything else should pull, unless its truly obscure, then you can go to the newest driver provided by the manufacturer website. The included disk is only good for NIC & Chrome
also, after the fresh install - make sure the bios is 100% bone stock auto.
skupples is offline
post #5 of 9 (permalink) Old 03-18-2019, 03:15 PM
Rep: 455 (Unique: 387)
I agree with Skupples but I'd check the logs as well (event viewer, critical and warnings) Windows can be telling it's self what's wrong and not tell you.
Darren9 is offline
post #6 of 9 (permalink) Old 03-18-2019, 04:05 PM
I Love this Hobby!
Gunderman456's Avatar
Rep: 610 (Unique: 503)
First thing I would do is check Device Manager and see if something is wrong there.
Second go to AsRock's website and download the latest chipset drivers for your mobo and install those.
-Guide to 1st Case Modding for Better GPU(s) Performance/Cooling-
https://www.overclock.net/case-mod-wo...ing-guide
-Guide to 2nd Case Modding for Better GPU(s) Performance/Cooling-
https://www.overclock.net/case-mod-wo...e-fan-mod
Fast n' Cheap
(17 items)
Bit'O'Heaven
(16 items)
RYZEN 7 3700X
ASUS TUF GAMING X570-PLUS
MSI Radeon RX 5700 XT
G.SKILL Ripjaws V Series 32GB (2x16GB) DDR4 3600 16-19-19-39 CL 16 1.35V
Corsair Force Series Gen.4 PCIe MP600 500GB NVMe M.2 SSD
Seagate BarraCuda ST3000DM008 3TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" HDD
Optical Drive
LG 16X SATA Blu-Ray Internal Rewriter with 3D Playback and M-DISC Support BH16NS40
Fractal Design Ion+ 860P 80 PLUS Platinum Certified 860W Full Modular
Noctua NH-D15
Veddha GriderCase alpha V1
Operating System
Win 10 Pro 64bit
Nixeus EDG 27" IPS Freesync 1440p 144Hz
Keyboard
Redragon K589 SHRAPNEL RGB Mechanical Keyboard
Mouse
Logitech G502 Hero
Mousepad
ALLSOP Redmond Mouse Pad
Audio
Cambridge Soundworks 5.1
Other
PulseLabz Challenger Gaming Chair
Intel i7 4770k @ 4.5GHz
Asus Maximus VI Rog Gene
Gigabyte AMD R9 290 @ Core 1160MHz & Memory 1350MHz
G.SKILL Trident X DDR3 16GB 2400MHz
Samsung 840 PRO 256GB
Seagate Barracuda 7200.14 3TB
Optical Drive
Pioneer Black Blu-ray 16X BD-R 2X BD-RE
EVGA SuperNOVA G2 1300W 80PLUS Gold Fully Modular
Corsair H60 Push/Pull
Fractal Design Arc Midi R2
Operating System
Win 7 Pro 64bit
Samsung 245BW 24" 1200p 60Hz
Keyboard
Logitech G15
Mouse
Logitech MX518
Mousepad
Corsair Vengeance MM200
Audio
Yamaha HTR-5830 Polk Audio 3.0
Intel Core i5-3570K @ 4.6GHz
ASRock Z77E-ITX mITX
Sapphire AMD HD 7990 @ Clock 900MHz & Memory 1100MHz
G.SKILL Ripjaws X DDR3 8GB 1600MHz @ 1866MHz
Crucial SSD CT128M4SSD3 128GB mSATA SATA III 6GB
Seagate Barracuda HDD 1TB
Optical Drive
LG DVD R/W
Corsair Professional Series Gold AX850 Fully Modular
Corsair Cooling Hydro Series H100
BitFenix Prodigy Mini-ATX Black Case
Operating System
Win 7 Pro 64bit
Samsung TV 52"
Keyboard
Logitech K330 Wireless
Mouse
Logitech M215 Wireless
Mousepad
Audio
Yamaha RX-V681 PSB/PolkAudio 5.1
Gunderman456 is online now
post #7 of 9 (permalink) Old 03-18-2019, 04:44 PM
PWn3R's Avatar
Rep: 0
Try disabling turboboost max from the icon in the windows tray. I'm not trolling.
Sent from my Mi MIX 3 using Tapatalk
PWn3R is offline
post #8 of 9 (permalink) Old 03-19-2019, 01:02 AM
Rep: 7 (Unique: 5)
Check clock speeds and temperatures for the cpu and ram when in windows. Use a program called latencymon to see what program or driver is causing all of the lag on your system.
Core I9-9900k @ 5.1
Asus Maximus XI Gene
EVGA 2080TI XC Black Edition
CMK16GX4M2K4700C19
Samsung 970 Evo m.2 nvme
Silverstone SFX-L 800W
280mm Slim + 360MM Thick
Fractal Design Meshify S2
Operating System
Windows 10 64bit
Acer XB271HU
Audio
Sennheiser HD 800s + Questyle CMA600i
xSneak is offline
post #9 of 9 (permalink) Old 03-19-2019, 06:05 AM
Not New to Overclock.net
fragamemnon's Avatar
Rep: 249 (Unique: 187)
My first suggestion would be chipset drivers. Most importantly, the SATA/AHCI driver.
MEGATRON
(17 items)
GIGATRON
(10 items)
Ryzen 7 1700
Crosshair VI Hero
Gigabyte RX 580
2x8 G.Skill Trident 3200 CAS14 @ 3466 CAS14
2x1TB WD Black RAID 0
3TB WD Red
Samsung 840 Evo 250GB
FSP Aurum PT 1200W
Stock... hue hue
Thermaltake Core X9
Benq XL2411Z
Dell U2412M
Dell U2412M
Keyboard
KBC Poker II MX Clears
Mouse
Zowie ZA11
Mouse
old school Razer Goliathus
Audio
Aune T1 -> Yamaha A-720 -> Sennheiser HD650 | Sony MDR-XB500
Intel Xeon E5-2650 v4 @ 2.00GHz
SuperMicro X10DAL-i
nay
2x8GB (for now) Kingston DDR4 @ 2133MHz/C16
Samsung 840 120GB
SeaSonic SS850-AM
EK-Vardar F4 on an Arctic Freezer i11
overrated
Operating System
Ubuntu Server 16.04
fragamemnon is offline
