8600k@4.8 with Asrock Extreme4, approved? - Overclock.net - An Overclocking Community
[email protected] with Asrock Extreme4, approved?
post #1 of 13 (permalink) Old 03-23-2019, 10:48 AM - Thread Starter
SydB12's Avatar
Rep: 0
Hi all, I have just overclocked my 8600k for gaming purposes with an Asrock z370 Extreme4 to 4.8 GHz and I would like to know what do you think about my oc settings/stability. I want a 24/7 oc and I don't want to risk cpu lifespan by oc'ing too much. Also, I live in a warm country and I don't want it to reach too high temperatures in summer.
I have set all cores to 4800 MHz and the CPU cache ratio at 4400 MHz. Long and short duration power limits to 120 and 150 respectively. Offset voltage of 20 mv and llc at level 1 (highest one).
I performed the following tests: 3 runs of Cinebench r20.0 without crashes or BSOD --> Prime95 v29.4 (AVX disabled) 1 hour small FFTs and 30 min blend test without warnings or errors --> RealBench v2.56 stress test 2 times during 15 min with hash match. Temperatures didn't exceed 80ºC during all those tests (iddle temperature remains around 40-50ºC). Voltage VID reached a max of 1.245v (min of 1.200v). No WHEA errors detected.
I've been playing The Division 2 for 2 hours, Overwatch for 1 hour and Metro Exodus for another hour without crashes and cpu temperature was always below 70ºC (1.245v max).
What do you think? Should I do something else? Thanks a lot for your time!!!!!!!!!!!!
PC: i5-8600k, Asrock z370 Extreme 4, 2x8gb ddr4 G.Skill Ripjaws VSeries 3200 cas16, PSU Corsair RM650x, Noctua nh-d14, 2xSamsung Evo 850 500gb ssd, case Corsair c70.
SydB12 is offline
post #2 of 13 (permalink) Old 03-23-2019, 11:10 AM
aayman_farzand's Avatar
Rep: 11 (Unique: 11)
It should be perfectly fine. I've been running my 8700K @5.2Ghz with no issues.
Did you happen to upgrade to the latest BIOS by any chance? And if so, do you notice any differences? I'm on 3.10 and 3.30 has been out for a while. I've had 0 issues so I don't have the urge to update.
aayman_farzand is offline
post #3 of 13 (permalink) Old 03-23-2019, 11:22 AM - Thread Starter
SydB12's Avatar
Rep: 0
That's actually a good question that I didn't consider before. I've just checked and my bios version is the 1.30 dating from 2017/11/30.
I have seen that there was a security update with version 1.60 (2018/3/2 Update CPU Microcode to revision 84. (For CPU security update)).
So far my system is running fine with the current bios. How important is this update? Would you update it? I thought bios updates followed this rule: If it ain't broke, don't fix it.
Cheers!
EDIT: it seems that the update 1.60 is for the Spectre-Meltdown flaws. Still not sure about what to do as I don't want to be unsafe, but I don't want t a decrease in performance.
EDIT 2: Well, answering my own question, after running InSpectre software I have checked that I am already protected against Spectre and Meltdown by Windows. Therefore, if the forum thinks the overclock is well done, then I won't update my bios. Everything seems to work fine as it is.
Thanks!!!
SydB12 is offline
post #4 of 13 (permalink) Old 03-23-2019, 11:46 AM
white owl's Avatar
Rep: 135 (Unique: 102)
The VID doesn't matter, the vcore is what the chip actually gets. If you're using less than 1.4v all that matters is stability. If it's stable it's good.
LLC doesn't need to be on it's highest setting and usually having it there is a bad idea because every time a load hits, the board is cramming extra voltage into the entire CPU. Try using the setting that's in the middle or one step below.
The microcode usually has a negligible impact on storage performance. Use it if you want, don't if you don't.
Quote: Originally Posted by SpeedyVT
If you're not doing extreme things to parts for the sake of extreme things regardless of the part you're not a real overclocker.
Quote: Originally Posted by doyll View Post
The key is generally not which brands are good but which specific products are. Motherboards and GPUs are perfect examples of companies having everything from golden to garbage function/quality.
Hot n Bothered
(12 items)
4790k 4.7Ghz
Asus Sabertooth Z97 MkII 2
EVGA GTX 1080 SC
16gb G.Skill Sniper 2400Mhz
2x Kingston v300 120gb RAID 0
WD Blue
Seasonic 620w M12 II EVO
Cooler Master 212 Evo
Corsair 450D
Operating System
Windows 10
Nixeus EDG27
Other
I have pretty lights.
white owl is online now
post #5 of 13 (permalink) Old 03-23-2019, 12:05 PM - Thread Starter
SydB12's Avatar
Rep: 0
Thanks, I was checking the wrong info then. In HWinfo64 there are several sections displaying info about my cpu:
"CPU [#0]: Intel Core i5-8600K", here is where I was reading the wrong voltage and where 6 different core VID appear.
"ASRock Z370 Extreme4 (Nuvoton NCT6791D)", here is where there's a reading for vcore. Is this the one I should take care about? If so, I will repeat all stress tests checking the proper vcore value and lowering the llc and then I will post the results again.
Cheers!
SydB12 is offline
post #6 of 13 (permalink) Old 03-23-2019, 12:16 PM
white owl's Avatar
It's obviously stable at whatever vcore it's using but it's important to know which to look at, especially when you're using Adaptive or Offset while stressing. VID is what the CPU is requesting but the board modifies this or ignores it depending on settings while vcore is what your cores will actually be getting.
Changing LLC shouldn't have a massive impact unless the board was using a really high value on that setting. Since you're only doing core and cache you can run Small FFT, you don't really need Blend here.
If you pull up HWinfo then run a stress test just look at your vcore, it should top out within a few seconds and now you know your core voltage. There may or may not be 6 of them. Changing LLC may not impact your vcore in a significant way, often what LLC does happens too fast for you to really see it in hardware. Intel has it's own load line setting and that's the one you want to use, usually this is in the middle. The board is just using that value and offsetting it to make it more or less aggressive and there's really no reason to use mare than Intel's spec on a daily OC.
Hot n Bothered
(12 items)
4790k 4.7Ghz
EVGA GTX 1080 SC
WD Blue
Corsair 450D
Operating System
Windows 10
Nixeus EDG27
Other
post #7 of 13 (permalink) Old 03-23-2019, 12:21 PM
9 Cans of Ravioli
The Pook's Avatar
Rep: 952 (Unique: 587)
vCore is inaccurate for a lot of Z390s. See if your board has a VR VOUT sensor somewhere in HWInfo and go by that.
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(7 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill 16GB DDR4 4133
Mushkin Pilot NVMe 1TB
Samsung 860 Evo 1TB
Sandisk Ultra II 480GB SSD
Toshiba X300 5TB
Western Digital EZRZ 3TB
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU
Dell E2311H
Keyboard
CoolerMaster MasterKeys Pro S
Mouse
Logitech G502
Mousepad
X-Ray XL 26" x 14"
Audio
SMSL SA50 + FiiO E10K
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
Audio
Monoprice Modern Retro
Audio
AudioSource LS100
Audio
Polk Audio PSW111
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston 8GB DDR4 2400
Dierka K1 120GB
Keyboard
Rii RKM709 Wireless
Mouse
Logitech M510
i7 860
Advantech AIMB 280 ITX
EVGA GTX 950 2GB
Kingston 2GB DDR3 1333
Seagate Momentus 2.5" 500GB
Western Digital Blue 2.5" 320GB
Silverstone SFX-L Gold 500w
Arctic Alpine 11 GT 2
Silverstone Milo Z ML07B
Operating System
Windows XP x86 SP3
Keyboard
Velocifire TKL01 Outemu Browns
Mouse
Logitech M512
The Pook is online now
post #8 of 13 (permalink) Old 03-23-2019, 12:48 PM - Thread Starter
SydB12's Avatar
Rep: 0
I have decreased llc to the second highest value (there are 5 llc values) and temperatures after 15min Prime95 smallFFT have decreased! I don't understand why, but hey, i'm not an expert. I will test now the middle llc value.
In HWinfo64: Vcore min= 1.152v, Vcore max= 1.232v, Vcore avg= 1.185v. VRout min= 1.132v, VRout max= 1.217v, VRout avg= 1.164v.
I think I have an stable and non-risky overclock, isn't it? Thanks!
SydB12 is offline
post #9 of 13 (permalink) Old 03-23-2019, 01:28 PM - Thread Starter
SydB12's Avatar
Rep: 0
Same results with llc in the middle value (i.e. 3). vcore don't exceed 1.232v and temperatures are in the 70ºC range. I think i'm happy with the result.
Thanks for your advice!
SydB12 is offline
post #10 of 13 (permalink) Old 03-23-2019, 01:55 PM - Thread Starter
SydB12's Avatar
Rep: 0
Sorry, I have another question. The minimum Vcore drops down to 0.610v. Is that ok? Ty!
SydB12 is offline
