[HELP] Attempting OC on 9700k with aorus z390 ultra - Overclock.net - An Overclocking Community
post #1 of 5 (permalink) Old 04-27-2019, 02:12 AM - Thread Starter
Rep: 0
Hello, I'm trying to overclock my new pc but since I'm new to OC I would like to have some feedback about results and if what I'm doing is wright.
Intel 9700k with aorus z390 ultra
That's the complete build: https://it.pcpartpicker.com/b/T4V6Mp
I read some guides and I started with a slight overclock (4.7-4.8 GHz); anyway I don't want to push it at much more higher values in order to keep temperature and noise lower.
-Test1:
cpu Vcore 1.25V, cpu clock ratio 47, AVX offset AUTO, core current mimit 255, XMP active, undercore ratio 45, cpu Vcore loadline calibration TURBO, cpu internal loadline AUTO,
I DISABLED: Enhanced multi-core performance, Intel Turbo boost technology, cpu flex ratio override, intel speed shift technology, C1-C3-C6/7-C8-C10 state support, SVID offset
(pased 30 min with prime95, maxT 66°C)
(in the following tests, all settings are the one of test1 excepts what listed below)
Test2: cpu Vcore 1.23V (passed 1h of realbench)
Test3: cpu Vcore 1.215V (passed 1h of realbench)
Test4: cpu Vcore 1.215V, cpu Vcore loadline calibration HIGH, cpu clock ratio 48 (passed 1h of realbench)
Test5: cpu Vcore 1.205V, cpu clock ratio 48 (passed 45min of realbench)
Test6: cpu Vcore 1.215V, cpu clock ratio 48, AVX 0 (passed 2h of realbench)
Test7: cpu Vcore 1.210V, cpu clock ratio 48, AVX auto (passed 90min prime95)
Test8: cpu Vcore 1.200V, cpu clock ratio 48, AVX auto (passed 1h prime95)
I started having freezes during the bench if I set AVX to values different from 0 or auto with prime95 after approximatively 15min. I increase uncore to 46 the system crashes with both prime and realbench.
Even if at 1.200V the system seemed stable, during 3DMark bench it started crashing; increasing Vcore to 1.205 allowed to pass the bench.
In the latter cases temps are close to 57°C with realbench and 60-61°C with prime95.
Rusults are in the dropbox link. (I will update it after furter tests)
https://www.dropbox.com/sh/4guar25fn...kY9vSLRBa?dl=0
Any advices? temperatures are ok? there's something I should modify in BIOS settings?
intel speed shift technology, C1-C3-C6/7-C8-C10 state support should be kept deactivated?
For now I started with a lower OC, maybe further on I will increase it.
Thanks for the help
tommy2911 is offline
post #2 of 5 (permalink) Old 04-27-2019, 04:17 AM
Go Again!
Wirerat's Avatar
Rep: 330 (Unique: 209)
There is little reason to raise the cache clocks. Just leave it at 45. It adds less than memory overclocking even.
You have a lot of thermal headroom left. You should be able to do 5 ghz 1.3v ish with that chip. Thats were mine is at I can do 4.8 at 1.215v.
Its ok for temps to get close to 90c during synthetic stress testing. I aim for 85c or less but these cpu can get really hot.
You dont have to disable the cstates individually. I disabled intel turbo boost and Eist and then none of the cstates do anything.
i9 9900k
Gigabyte z390 Aorus Pro
Msi 1080ti gaming x
Corsair DDR4 3000mhz cl 15
Crucial MX500 500 gb
Crucial MX500 1tb
2tb WD 5400 rpm
Seasonic G-750
EK XRES 140 DDC Top
swiftech MCP-35X
Gentle typhoon AP-15 X 3
Be quite 140mm
Nocuta 120mm Redux 1700rpm
Bitspower DDC Heatsink Black
Hardware Labs 240mm GTS
EK Supremecy MX
Ek 360mm pe rad
Ek msi 1080ti gaming x waterblock
Fractal Design R5
Operating System
WIN 10
Acer XF250Q 240hz
Keyboard
G410 atlas
Mouse
G502
Wirerat is offline
post #3 of 5 (permalink) Old 04-27-2019, 08:05 AM - Thread Starter
Rep: 0
Thanks, I will definitely try to go up to 5GHz.
Does it worth to disable all those energy saving features? I mean, when I'm not gaming I don't really need to have all working at max; enabling them it helps to keep the cpu cooler and so to reduce the noise?
Should I touch other settings in the BIOS or it's enough to reach a stable OC?
EDIT: I just tried to go up to 5GHz at 1.300V; I left the other settings same as the last test at 4.8GHz.
The sytem seems quite stable; passed almost 1h of prime95 with temps ranging between 69 to 73 °C and VR VOUT oscillating from 1.243V to 1.252V (most of the time close to 1.243V)
I added the screenshot to the dropbox folder (test9)
Probably I can reduce a bit the Vcore
post #4 of 5 (permalink) Old 05-06-2019, 05:14 PM
insektmute's Avatar
Rep: 2 (Unique: 2)
I’d try setting VCore up a hair more, maybe 1.31. I had 1 worker failing at 1.3, but stabilized for me after that slight bump. 1.2 ranges are likely too low, or at least were on my setup (same combo).
Edit: Sorry, missed that you got it stable at lower voltage!
insektmute is offline
post #5 of 5 (permalink) Old 05-07-2019, 05:14 PM
wingman99's Avatar
Rep: 58 (Unique: 43)
I have all power saving features enabled for 5.0GHz overclock and I save 19 watts at idle.
i5 8600K OC 5.0GHz
Noctua NH-U14S
Motherboard Gigabyte Z370-HD3
G.SKILL Ripjaws v 16GB F4-3200C14D-16GVK XMP Speed 3200 14-14-14-34
EVGA GeForce RTX 2070 XC ULTRA GAMING
wingman99 is offline
