Hot Temp while OC i7 2600K - Overclock.net - An Overclocking Community
post #1 of 7 (permalink) Old 07-07-2019, 02:18 PM - Thread Starter
duceduc's Avatar
Rep: 0
I am in the process of OC an Intel i7 2600K and am getting hot temp while under load. I suspect my cpu cooler isn't the best, but I want to avoid buying any hardware if I can. Is there any settings in bios I can tweak to get the temp down? What cpu cooler do you recommend under budget?
Attempt:
Under load [Used Intel Burn Test @ Standard testing] - Temp is at 89c, 1.288v, OC at 4.3MHz.
My cores temp read as follow: 83c - 89c - 89c - 84c
Specs:
Intel i7 2600K
Asus P8Z77-V PRO
AMD Radeon HD6850
Corsair Vengence DDR3 32GB
Corsair H60 Cooler
Thermaltake 80 Plus Gold 850W
Settings in BIOS:
Ai Tweaker > Ai Overclock Tuner: Manual
Ai Tweaker > BCLK/PCIE Frequency: 100.0
Ai Tweaker > Turbo Ratio: By All Cores
Ai Tweaker > By All Cores (Can Adjust in OS): 43
Ai Tweaker > Internal PLL Overvoltage: Disabled
Ai Tweaker > Memory Frequency: DDR3 2133MHz
Ai Tweaker > EPU Power Saving Mode: Disabled
Ai Tweaker > DRAM Timing Control: 11,13,13,31,2
Ai Tweaker > CPU Power Management > CPU Ratio: Auto
Ai Tweaker > CPU Power Management > Enhanced Intel SpeedStep Technology: Enabled
Ai Tweaker > CPU Power Management > Turbo Mode: Enabled
Ai Tweaker > CPU Power Management > everything else on Auto
Ai Tweaker > Load-Line Calibration: Ultra High
Ai Tweaker > VRM Frequency: Auto
Ai Tweaker > Phase Control: Extreme
Ai Tweaker > Duty Control: Extreme
Ai Tweaker > CPU Current Capability: 100%
Ai Tweaker > CPU Voltage: Offset Mode
Ai Tweaker > Offset Mode Sign: +
Ai Tweaker > CPU Offset Voltage: 0.005
Ai Tweaker > DRAM Voltage: 1.56V
Ai Tweaker > VCCIO Voltage: Auto
Ai Tweaker > CPU PLL Voltage: Auto
Ai Tweaker > PCH Voltage: Auto
Ai Tweaker > CPU Spread Spectrum: Disabled
Advanced > CPU Configuration > CPU Ratio: Auto
Advanced > CPU Configuration > Intel Adaptive Thermal Monitor: Enabled
Advanced > CPU Configuration > Hyper-threading: Disabled
Advanced > CPU Configuration > Active Processor Cores: All
Advanced > CPU Configuration > Limit CPUID Maximum: Disabled
Advanced > CPU Configuration > Execute Disable Bit: Enabled
Advanced > CPU Configuration > Intel Virtualization Technology: Disabled
Advanced > CPU Configuration > Enhanced Intel SpeedStep Technology: Enabled
Advanced > CPU Configuration > Turbo Mode: Enabled
Advanced > CPU Configuration > CPU C1E: Enabled
Advanced > CPU Configuration > CPU C3 Report: Disabled
Advanced > CPU Configuration > CPU C6 Report: Disabled
duceduc is offline
post #2 of 7 (permalink) Old 07-07-2019, 02:25 PM
Senior OCN Member
shilka's Avatar
Rep: 2808 (Unique: 1658)
Sory but the CPU cooler you have is terrible and if you want to OC you should get a better cooler or dont OC the CPU
Dreissen
(27 items)
Seravee
(18 items)
Ryzen 3700x
Asrock x570 Taichi
MSI RTX 2070 Super Gaming X Trio
G Skill TridentZ
Corsair Force MP510 1,92 TB
Seagate IronWolf Pro ST14000NE0008
Seagate Ironwolf ST12000VN0007
Seagate IronWolf Pro ST12000NE0007
WD Ultrastar DC HC530 14 TB
Seagate IronWolf Pro ST16000NE000
Seasonic Prime Ultra Titanium 750 watt
Noctua NH-U12S Chromax
Phanteks Luxe 2
Operating System
Windows 10 Home 64 bit
Asus PG279Q
LG 55C8
Keyboard
Corsair Strafe RGB MK.2 with Cherry MX Silent
Mouse
Roccat Kone EMP
Mousepad
HyperX Fury S XL
Audio
Onkyo TX NR646
Audio
RHA L1 Dacamp
Audio
Sennheiser HD 599
Audio
Dali E 12 F
Audio
2x Dali Opticon 1
Audio
2x Dali Opticon 2
Audio
Dali Opticon Vokal
Other
Vegas MBA 60cm LED Strip
Intel Core I7 6850K
Gigabyte X99 Ultra Gaming
GTX 1060 3 GB wth blower style cooler
Kingston HyperX DDR4 Savage 3000 MHz
Samsung 840 Evo 500 GB
Samsung 860 Evo 1 TB
Optical Drive
LG CH12NS30
Seasonic Focus GX 650 watt
Noctua NH-D15S
Phanteks Enthoo Luxe Tempered Glass
Operating System
Windows 7 Ultimate 64 bit
Operating System
AOC 24G2U
Keyboard
Corsair Gaming STRAFE RGB Mechanical
Mouse
Roccat Kone EMP
Mousepad
Roccat Sense Metor
Audio
Sennheiser HD 598
Other
CableMod 30 CM Magnetic Red LED strip
LG 24MP59G-P
Mouse
Logitech MX518 Hero
Other
Delock PCI-E to M.2 NVME Adaptor Card
shilka is offline
post #3 of 7 (permalink) Old 07-08-2019, 10:10 AM
Belial's Avatar
Rep: 166 (Unique: 142)
Belial is offline
post #4 of 7 (permalink) Old 07-08-2019, 10:43 AM
Imprezzion's Avatar
Rep: 111 (Unique: 96)
1.288v should be enough for 4.5-4.6Ghz so I'd try to put offset mode sign to - and start at 1.2v which is -0.080 see if it'll do 4.3 on that voltage.
Cars:
-Crashed: (not my fault ) '94 Nissan 100NX GA16DE (a.k.a. NX1600). Renault Laguna Phase I facelift '99 1.6 K4M. (Broke a strut and smacked a tree).
-Sold: '00 Nissan Primera P11-144 QG18DE, '97 Honda Prelude F20A4, 03 Ignis Sport.
-Current daily: '07 Ford Focus 1.6 Futura.
-Current funcars: '03 Peugeot 206CC 2.0 RFN fully riced and tuned (Turbo coming soon)
Looking for: Gen 4 or 5 Honda Prelude, >92 Toyota Celica or >90 MR2.
Full-On Rainbowbarf
(16 items)
P45 power!
(9 items)
i9 9900K @ 5.1Ghz 1.248v (VR VOut)
MSI MEG Z390 ACE
RTX 2080 Ti Phoenix GS + G12 & Kraken X52 @ 2130/8100 1.093v (EVGA FTW3 BIOS)
Corsair Vengeance RGB B-Die @ 4200 16-17-17-34-320-2T 1.54v
Samsung 850 EVO 500GB x2
Samsung 970 Evo 1TB
Seasonic Prime Ultra Gold 1000w
EK MLC-Phoenix 280 Kit
Phanteks Enthoo Evolv X
Operating System
Windows 10 Pro X64
Samsung S27B350H @ 1080p 75Hz OC
Iiyama GB2788HS @ 144Hz
Keyboard
Logitech G710+
Mouse
Trust GXT31
Mousepad
Corsair MM300 Large
Audio
Steelseries Siberia V2
Intel Core 2 Quad Q6600 G0 @ 3Ghz (333x9)
MSI P45 Neo2-FR
MSI GTX760 Gaming X
6GB completely random 1 and 2GB sticks. All 4 different ones.
A-Data 120GB SSD
AOpen 350w
Some huge aluminum Xeon heatsink
Cartboard box.
Operating System
W10 Pro x64
Intel Xeon E3-1270v1 @ 3.8Ghz
ASUS P8H61-i R2.0
Sapphire R9 280X Vapor-X @ 1230Mhz core.
16GB Kingston HyperX Savage 2400CL11 @ 1333CL6
Kingston 240GB SSD
Corsair CX600
Corsair H110i GTX
Custom open test bench made from a cut-up CM690 v1
Operating System
W10 Pro X64
Samsung 23" cheap thing
Keyboard
Cheapest one Aldi had
Mouse
Mousepad
The desk...
Imprezzion is offline
post #5 of 7 (permalink) Old 07-09-2019, 06:17 AM
black06g85's Avatar
Rep: 11 (Unique: 11)
that's pretty high, definitely need a new cooler.
I just put one together for my buddy running 4.98 @1.45v temps never get above mid 70s
black06g85 is offline
post #6 of 7 (permalink) Old 07-12-2019, 05:52 AM - Thread Starter
duceduc's Avatar
Rep: 0
I have replaced my cpu cooler to a Cooler Master 212 Evo. I have ran Prime95 v26.6 and it crashes (freeze) right at 3 hrs, twice. Any other settings I can change besides upping the voltage? My ram is rated at 1.65v and I have set it to 1.566v in bios. Should I set it to 1.65v instead?
OC @:
4.2MHz @ 1.256v. Temp 71C.
duceduc is offline
post #7 of 7 (permalink) Old 07-12-2019, 06:12 AM
Senior OCN Member
shilka's Avatar
OC @:
The CPU cooler you bought is not better in fact its rubbish and unless you spend more money than $20-30 for an air cooler your temps wont be much better
Return the 212 Evo its not worth buying its ancient outdated overrated overhyped and overpriced when you consider how many budget air coolers that are newer better more quiet and sometimes cheaper
Edit: something like a Noctua NH-U12S / NH-U14S or the new NH-U12A are light years better than the old 212 Evo rubbish
Phanteks / Be Quiet / Cryorig and Thermalright also have a number of good coolers that are much better
Dreissen
(27 items)
Seravee
(18 items)
Ryzen 3700x
Asrock x570 Taichi
G Skill TridentZ
Phanteks Luxe 2
Operating System
Asus PG279Q
LG 55C8
Keyboard
Mouse
Roccat Kone EMP
Mousepad
HyperX Fury S XL
Audio
Onkyo TX NR646
Audio
RHA L1 Dacamp
Audio
Sennheiser HD 599
Audio
Dali E 12 F
Audio
2x Dali Opticon 1
Audio
2x Dali Opticon 2
Audio
Dali Opticon Vokal
Other
Intel Core I7 6850K
Optical Drive
LG CH12NS30
Noctua NH-D15S
Operating System
Operating System
AOC 24G2U
Keyboard
Mouse
Roccat Kone EMP
Mousepad
Roccat Sense Metor
Audio
Sennheiser HD 598
Other
LG 24MP59G-P
Mouse
Logitech MX518 Hero
Other
shilka is offline
