PC Power Cycle 1x at startup - Overclock.net - An Overclocking Community
post #1 of 8 (permalink) Old 07-11-2019, 07:31 PM - Thread Starter
Ti
iLoveOC's Avatar
Rep: 0
My computer power cycles once before I get to bios or OS.
Started happening after I installed my h100i Pro and overclocked my CPU.
Only power cycles ONLY when I turn off my power supply or turn off my surge protector, which my PC is connected to. It does not power cycle normally, if I do not turn off PSY or surge protector.
The power cycle only lasts for about 0.5 or 1 second. Does not even get to bios, then starts up like normal as if nothing ever happened. No RAM OC, only CPU.
Anyone have any idea as to what is going on, if I should be worried, and how to fix this.
Its just kinda ok
(9 items)
i5 [email protected]@1.185v
ASUS Prime Z370-A
EVGA 1070Ti FTW
Corsair Vengeance RGB Pro
Samsung 960 Pro
EVGA 650GQ
Corsair H100i Pro 4xML120
CoolerMaster MasterCase H500
Operating System
Windows 10
iLoveOC is offline
post #2 of 8 (permalink) Old 07-11-2019, 08:55 PM
Linux Gamer
Almost Heathen's Avatar
Rep: 64 (Unique: 44)
It's (almost certainly) normal, nothing to worry about, and caused by your overclock.
A BIOS/UEFI is sometimes unable to apply certain changes (commonly: FSB, RAM speed, some voltage options) until it power cycles, so it (automatically) powers itself off then on. Which options require this depend on the BIOS/UEFI, the platform, etc. It was common (especially on older platforms) that if the BIOS/UEFI changes the user had made were very unstable, this rapid power off/on cycle would continue indefinitely ("boot loops") until the BIOS was reset by the user by clearing CMOS.
I assume when the system starts up from a totally powered off state (PSU has been unplugged or switch flipped), it again tries to use a baseline for certain settings, and may need to once again quickly power off then on (multiple times if necessary) to apply the users settings.
There may be mention of this in your manual; if you had included your system specs (or even better, create a rig in rigbuilder and add to your sig) it could shed more light on this, but I've seen this behavior repeatedly and the vast majority of the time it's completely normal.
NAS / HTPC
(21 items)
Intel Xeon W3680 @ 3.9GHz
Dell 0x501h (BIOS A16, not EFI capable)
EVGA GTX 1060 Gaming 6GB 06G-P4-6161-KR @ stock
30GB @ 1066MHz CL7 (3x8GB 2Rx8 1600MHz ECC UDIMMs, 3x2GB 2Rx8 1333MHz non-ECC)
ZFS mirror (media), ZFS JBOD (gaming etc.), ZFS OS
Seasonic SS-850HT
Scythe Ninja 4
Sunbeam Rheostat Extreme Fan Controller rev2
4 x San Ace 140x38mm @ ~800RPM starting speed
Prolimatech MK-26 GPU Cooler
CaseLabs Bullet BH8 (white)
Operating System
Antergos XFCE (Antergos repos removed)
Panasonic Viera X3 TV
Keyboard
CM Storm Quickfire Pro (Cherry Reds)
Mouse
Logitech M310
Mouse
Itac mouse-trak Industrial Trackball
Mousepad
Cloth
Audio
Creative Sound BlasterX H5 Tournament Edition Headset
Audio
Creative Sound BlasterX G1 USB Sound Card
Audio
Boston Acoustics HD5 x2
Audio
Old Kenwood Stereo Receiver
Almost Heathen is offline
post #3 of 8 (permalink) Old 07-11-2019, 09:29 PM - Thread Starter
Ti
iLoveOC's Avatar
Rep: 0
I see, this was the conclusion I was coming to searching online. Just was not sure cause it seemed like others were getting stuck in the boot loop, not just rebooting once when the PSU has been shut off.
So this is perfectly fine you say? Is there anything I can possibly change in BIOS to stop this?
Its just kinda ok
(9 items)
ASUS Prime Z370-A
EVGA 1070Ti FTW
Samsung 960 Pro
EVGA 650GQ
Operating System
Windows 10
iLoveOC is offline
post #4 of 8 (permalink) Old 07-11-2019, 10:04 PM
Linux Gamer
If it was going to boot loop, it generally does so right after unstable BIOS changes are applied, so it would have done it already.
Yes, perfectly fine and nothing to worry about.
It's not hurting anything and not indicative of an issue. It's normal and expected for certain BIOS settings to cause this behavior; it's behavior that's typically been programmed into the BIOS itself. As an example, my previous board would power cycle to switch voltage modes, LLC modes, voltage options, up to 4 times for memory training (which was documented in the manual), etc., so I could always count on a power cycle (or three) the first time I start the system after power loss. My current board will power cycle for memory training as well. I've observed it on many systems I've built as well.
Yes, one of your overclock settings is likely causing the need for it to powercycle. Many settings can cause it, depending on the board (changing vcore from auto/offset/static, PLL voltage, LLC, probably VRM power options on Asus boards); however what specifically is causing it in your case, I couldn't say. I see no mention of it in the manual, which is not unusual.
If you're concerned, it shouldn't be difficult to demonstrate that it's the overclock that's causing it. Write down all your settings, then load optimized defaults which will revert the BIOS/UEFI to stock and the CPU to stock clocks, shut down the system normally, then flip the psu switch. Next time you start it, the powercycle at bootup will likely be gone. If it's not gone, it's probably memory training, which is also normal, not hurting anything, and nothing to worry about.
But I wouldn't bother; in any event, it's nothing to worry about
NAS / HTPC
(21 items)
Seasonic SS-850HT
Scythe Ninja 4
Operating System
Keyboard
Mouse
Logitech M310
Mouse
Mousepad
Cloth
Audio
Audio
Audio
Audio
post #5 of 8 (permalink) Old 07-11-2019, 10:42 PM
Shawnb99's Avatar
Rep: 66 (Unique: 47)
It’s normal, mine does the same thing
My Baby
(23 items)
Delidded Direct Die I9 9900K
ASUS Maximus XI Apex
EVGA FTW3 Hydro Copper GeForce RTX 2080 Ti
G.SKILL TridentZ Series 16GB DDR4 3600 F4-3600C15D-16GTZ
2x Samsung 970 EVO Plus 1TB
Asus Hyper M.2 card
2 x Intel 660P 2TB
Seasonic PRIME Ultra 1000 Titanium
Optimus Signature V2
2x Swiftech MCP35X2 with MCP35X2 Heat Sink w/ 2x NB-BlackSilent Pro's
2x Hardware Labs Black Ice Nemesis 560GTX w/ 8x Arctic P14 PST PWM's
2x Hardware Labs Black Ice Nemesis 480GTX w/ 16x Noctua NF-A12x25 PWM
Aquacomputer aqualis XT 450 ml with nano coating
9x Noctua NF-S12A PWM
Hardware Labs Black Ice Nemesis 360GTS w/ 6 Arctic P12 PST PWM's
Case Labs Magnum TH10A with Pedestal
Asus PG278Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Light Harmonic Oscar XXI
Audio
Geek Pulse Inifnity DAC/AMP
Audio
Cavalii Audio Liquid Carbon HPA
Other
Aquacomputer Aquaero XT
Shawnb99 is offline
post #6 of 8 (permalink) Old 07-11-2019, 11:37 PM
Overclocker
JackCY's Avatar
Rep: 364 (Unique: 261)
Wonky RAM config, UEFI trying to guess settings because you didn't set them hard.
Cold RAM vs warm RAM is a difference too. So if your RAM is not set super stable even temperature differences such as opening a window at freezing winter at your computer for a while can make it not boot and cycle RAM etc.
Having power constantly on may help retain settings but then the mobo really should do that anyway but it may be trying to do a new guess each hard power on due to how it's written in UEFI.
It should never cycle, it should POST and boot ASAP. When it's cycling then it's doing something, often RAM or other peripheral issues.
Set whole RAM locked settings and disable training if that setting even ever has an effect.
JackCY is offline
post #7 of 8 (permalink) Old 07-11-2019, 11:44 PM
In VB's Basement
ENTERPRISE's Avatar
Normal, at least it is more so with AMD systems. They have a habit of doing that when memory training. My Threadripper system does it whether stock or Overclocked.
Need help with your account or something forum related ? Please use our Contact Us form
ENTERPRISE is offline
post #8 of 8 (permalink) Old 07-12-2019, 08:20 AM - Thread Starter
Ti
iLoveOC's Avatar
Rep: 0
Alright. Thank you all for the replies. I know it isn't RAM cause this was happening before I turned on XMP, and XMP I don't think should cause boot cycles. I think this has probably got to do with my CPU power draw being set to +130% or my manual voltage.
If its perfectly normal for OC systems to do this I'll just leave it alone. And tell everyone in my family to not flip the switch on my surge protector haha
Its just kinda ok
(9 items)
ASUS Prime Z370-A
EVGA 1070Ti FTW
Samsung 960 Pro
EVGA 650GQ
Operating System
Windows 10
iLoveOC is offline
