Intel Management Engine Interface not installed - Overclock.net - An Overclocking Community
post #1 of 23 (permalink) Old 07-22-2019, 02:17 PM - Thread Starter
duceduc's Avatar
Rep: 0
I have OC to 4.2 and passed a stress test running prime95 for 12hrs without crash. However, the pc would crash at idle. After searching what may be the cause, some suggest to update or use the motherboard recommended version of Intel Management Engine Interface. When I search for this interface under device manager, I do not see it installed. From what I read, this driver communicates between the pc and the motherboard?
Where can I download this interface and what verison? A search comes up with 2 different version and I do not know which one I need.
https://downloadcenter.intel.com/dow...and-Windows-10
https://downloadcenter.intel.com/dow...-for-Intel-NUC
Hardware:
Asus P8Z77-v Pro
i7 2600k
Windows 10
duceduc is offline
post #2 of 23 (permalink) Old 07-22-2019, 02:41 PM
Overclocker in training
ThrashZone's Avatar
Rep: 64 (Unique: 50)
Hi,
There's little to interface with and it doesn't come from Intel it comes from asus
You need to install
Chipset driver
Sata driver
USB driver
https://www.asus.com/us/Motherboards...Desk_Download/
i9-9940x With Heatkiller IV Pro Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is offline
post #3 of 23 (permalink) Old 07-22-2019, 02:47 PM - Thread Starter
duceduc's Avatar
Rep: 0
Hello. In that link above under firmware & bios tab, firmware section, the instructions states 'Before using the tool, make sure the Intel Management Engine Interface Driver is installed and follow the simple instruction.'
https://www.asus.com/us/Motherboards...HelpDesk_BIOS/
Intel Management Engine Firmware upgrade program
For better Windows® 8 compatibility, this tool will update the Intel® Management Engine(ME) firmware to 8.1.
1.Download and extract the file to a folder
2.Double click the MEtool execution file to run the updating tool
3.Follow the tool instruction to complete updating
*During updating, DO NOT shut down or restart system to prevent an incomplete update.
Update: My adblocker had blocked some contain under Drivers & Tools. I see what you are stating now.
duceduc is offline
post #4 of 23 (permalink) Old 07-22-2019, 03:18 PM - Thread Starter
duceduc's Avatar
Rep: 0
I tried to install the chipset driver, but it seems my platform isn't support.
duceduc is offline
post #5 of 23 (permalink) Old 07-22-2019, 03:29 PM
sudo apt install sl
WannaBeOCer's Avatar
Rep: 176 (Unique: 123)
Read: https://www.win-raid.com/t596f39-Int...tem-Tools.html
Drivers are located on part A named About Intel MEI Drivers
Silent
(20 items)
Core i9 9900K... CoffeeTime! @ 4.2Ghz w/ 1v
Maximus VIII Formula
Radeon VII @ 1900Mhz/1250Mhz w/ 1v
TeamGroup Xtreem 16GB 3866Mhz CL15
Samsung 850 Evo 1TB
Samsung 850 Evo 1TB
Samsung 850 Evo 500GB
EVGA SuperNova 1200w P2
EK Supremacy Full Copper Clean
XSPC D5 Photon v2
Black Ice Gen 2 GTX360 x2
EK-Vector Radeon VII - Copper + Plexi
Thermaltake Core X5 Tempered Glass Edition
Operating System
Clear Linux
Acer XF270HUA
Keyboard
Cherry MX Board 6.0
Mouse
Logitech G600
Mouse
Alugraphics GamerArt
Audio
Definitive Technology Incline
Audio
SMSL M8A
WannaBeOCer is online now
post #6 of 23 (permalink) Old 07-22-2019, 03:47 PM - Thread Starter
duceduc's Avatar
Rep: 0
I still get platform not compatible using this link when installing.
I chose 'Intel MEI Installer v11.0.6.1194'
duceduc is offline
post #7 of 23 (permalink) Old 07-22-2019, 03:59 PM
ThrashZone's Avatar
Hi,
Did you install the other two usb and sata ?
Chipset was beta try another lower chipset first dated about when your current bios is.
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
Mouse
Audio
eLeaf MELO-3 4ml
Operating System
post #8 of 23 (permalink) Old 07-22-2019, 04:13 PM - Thread Starter
duceduc's Avatar
Rep: 0
Yes, I have installed the usb and sata ones.
This link doesn't have any older chipset other than one given.
With this link, I should try 'Intel MEI Driver v6.2.50.1050 (ME 6)' under 'D4. Old Intel MEI Driver Only' section?
duceduc is offline
post #9 of 23 (permalink) Old 07-22-2019, 04:27 PM
ssateneth's Avatar
Rep: 43 (Unique: 38)
The latest driver compatible with Z77 is 11.0.5.1189. It may be listed as a version as late as 11.0.11.1193, but the driver itself is 11.0.5.1189. Drivers that are 11.1.*.* or later are not compatible with Z77.
I'm curious as to why your device is not showing. It might be showing under "Other Devices", but knowing Windows 10, it might be running it's own driver. Intel Chipset driver package also has it's own NULL driver it will use for ME if installed.
If you want, I can look at it through teamviewer as I am genuinely curious.
Intel Core i9-9900k (Silicon Lottery 5.1GHz @ 5.3GHz 1.36 VCore)
ASUS ROG MAXIMUS XI APEX
G.SKILL F4-4000C19D-32GTZSW (2x16GiB 4000MHz 19-19-19-39 2T, tuned to 4133MHz 14-17-17-31 2T)
EVGA NVIDIA GeForce GTX 1080 Ti FTW3
Seasonic PRIME 1300W 80+ Platinum
ssateneth is offline
post #10 of 23 (permalink) Old 07-22-2019, 04:38 PM - Thread Starter
duceduc's Avatar
Rep: 0
The only reason why I am trying to install this interface in the first place because a search lead me to believe the cause of my OC to 4.2 freezes only at idle. While underload using prime95 it runs without issues. I also have other issues with the motherboard where if the pc freezes, bsod, reset, etc, the bios seems to reset the voltage to a default settings. Any changes in voltage in bios will not have any affect. The only why to fix it is to short the cmos pins whenever the pc freezes. I am hoping this missing imei is the answer to my resetting of cmos and freezes at idle. Prior to the oc, the pc runs with no glitches at stock settings.
Under other device, there is a only device and it has a question mark. It is for a Marvell 91xx which I may have the driver for it, but haven't installed it.
duceduc is offline
