9900K OC help (System Agent & VCCIO) - Overclock.net - An Overclocking Community
post #1 of 10 (permalink) Old 09-02-2019, 03:44 PM - Thread Starter
Melodist's Avatar
Rep: 1 (Unique: 1)
Hello there,
I've been overlocking my 9900K for a day now and got the following results:
4.8 GHz @ 1.225 volts stable with Prime 95 12k
4.9 GHz @ 1.29 volts stable with Prime 95 12k
I'm on a Gigabyte Designare Z390 with good VRM and run it in Turbo LLC.
Can I possibly get the 4.9 GHz at a lower voltage by decreasing System Agent and VCCIO, both currently at 1.3 and 1.2 volts?
Is it maybe better to run Prime with 1344k like der b8uer tests his samples which he sells on caseking? That'd make my overclock range less narrow than with 12k.
My cooler is a Noctua NH-U12A
Name:	49 GHz 12k FFT.jpg
Melodist is offline
post #2 of 10 (permalink) Old 09-02-2019, 04:35 PM
Falkentyne's Avatar
Rep: 383 (Unique: 274)
Quote: Originally Posted by Melodist View Post
Hello there,
VCCIO 1.10 and VCCSA 1.20 is good for RAM > 3200 mhz. These being too low can cause some stability problems.
Only other way to reduce the voltage is to lower your loadline calibration and raise the bios voltage.
Most stable voltages happen from using Normal/Standard Loadline calibration (or LLC1 or LLC2) and use Auto vcore, and reduce the "AC Loadline" value to lower the voltages (idle and load) that way.
[email protected] ghz, RX Vega 64, 32GB DDR4, Gigabyte Aorus Master, Seasonic Platinum 1000W, Corsair 760T
Alt: MSI GT73VR Throttlebook with 7820HK @ 4.7 ghz, GTX 1070 MXM TDP mod to 230W, 32 GB RAM
Falkentyne is online now
post #3 of 10 (permalink) Old 09-02-2019, 04:48 PM - Thread Starter
Melodist's Avatar
Rep: 1 (Unique: 1)
Does VCCIO 1.10 and VCCSA 1.20 affect my overclock and maybe allow me to run lower voltages with my CPU?
You're not recommending me auto vcore do you? That's horrible xD Dude, my CPU runs stock with 1.25 to 1.27 volts stock 4.7 GHz while I can get it manually to 4.8 GHz at 1.225 :> Who'd run it stock with a much higher voltage and temps if I can get it down.
Right now I'm trying to figure out how low I can get 4.9 GHz, my record has been 1.275 volts with 12k FFT. I've just been wondering if lowered VCCIO and VCCSA will allow me to go even lower.
Melodist is offline
post #4 of 10 (permalink) Old 09-02-2019, 04:53 PM
9 Cans of Ravioli
The Pook's Avatar
Rep: 1065 (Unique: 628)
if you're temp limited, maybe, but probably not at any meaningful amount.
but 1.3v VCCIO/SA is unneeded, you should lower it anyway. I only need 1.23v for 4133.
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 32GB
Mushkin Pilot NVMe 1TB
HP EX950 NVMe 2TB
Samsung 860 Evo 1TB
Sandisk Ultra II 480GB SSD
Toshiba X300 5TB
Western Digital EZRZ 3TB
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU
Dell E2311H
Keyboard
CoolerMaster MasterKeys Pro S
Mouse
Logitech G502
Audio
SMSL SA50 + FiiO E10K
Audio
Micca RB42
Audio
Polk Audio PSW111
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston 8GB DDR4 2400
Dierka K1 120GB
ADATA SU800 128GB M.2
Operating System
Windows 10 Professional
Operating System
MX Linux
Keyboard
Rii RKM709 Wireless
Mouse
Logitech M510
i7 860
Advantech AIMB 280 ITX
EVGA GTX 950 2GB
Kingston 2GB DDR3 1333
Seagate Momentus 2.5" 500GB
Western Digital Blue 2.5" 320GB
Silverstone SFX-L Gold 500w
Arctic Alpine 11 GT 2
Silverstone Milo Z ML07B
Operating System
Windows XP x86 SP3
Keyboard
Velocifire TKL01 Outemu Browns
Mouse
Logitech M512
The Pook is offline
post #5 of 10 (permalink) Old 09-02-2019, 05:02 PM - Thread Starter
Melodist's Avatar
Rep: 1 (Unique: 1)
Does lowering VCCIO/SA allow me to run lower vcores? My best value for 4.9 GHz currently is 1.28 volts and 1.225 for 4.8 GHz. I'm using trident z cl 14 3200 MHz b-die.
How will I know VCCIO/SA is stable? Same as vcore = crash?
Melodist is offline
post #6 of 10 (permalink) Old 09-02-2019, 05:11 PM
The last VRM burner
Rep: 22 (Unique: 13)
How about checking that empirically, it's be thousand times faster... SA/IO is 99% use case of RAM overclocking, not Core.
PC for all
(18 items)
i7 5775c @4.2GHz/3.8GHz
Gigabyte Z97X Gaming 5
Soon to be 2070 Super FE
KHX24C11T3K2/16X 11-12-12-32-1T-250
Corsair MP510
Samsung Evo 860
SeaSonic Focus Plus 750W
Raijintek Tisis lapped+ Thermal Grizzly Kryonaut
LianLi 330X
Operating System
Windows 10 64-bit Pro
Benq GL2250 80Hz
Keyboard
Corsair Strafe Red Silent
Mouse
SteelSeries Rival 310
Mousepad
Artisan FX Raiden
Audio
Audio in Motion SC808 + MUSES8820 + 2x 2xLME49990
Audio
AKG M220
Other
NZXT Hue+
Other
Mayflash F300 Arcade Stick
BroadPwns is offline
post #7 of 10 (permalink) Old 09-02-2019, 05:15 PM
9 Cans of Ravioli
The Pook's Avatar
SA specifically can limit your RAM OCs if it's too low but shouldn't have anything to do with your CPU voltage. VCCIO shouldn't either.
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
HP EX950 NVMe 2TB
Samsung 860 Evo 1TB
Toshiba X300 5TB
Corsair H115i Pro
Operating System
Acer XF270HU
Dell E2311H
Keyboard
Mouse
Logitech G502
Audio
Audio
Micca RB42
Audio
Polk Audio PSW111
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Dierka K1 120GB
Operating System
Operating System
MX Linux
Keyboard
Rii RKM709 Wireless
Mouse
Logitech M510
i7 860
EVGA GTX 950 2GB
Operating System
Windows XP x86 SP3
Keyboard
Mouse
Logitech M512
The Pook is offline
post #8 of 10 (permalink) Old 09-02-2019, 05:21 PM - Thread Starter
Melodist's Avatar
Rep: 1 (Unique: 1)
So lowering them will not affect my CPU OC?
Melodist is offline
post #9 of 10 (permalink) Old 09-02-2019, 05:35 PM - Thread Starter
Melodist's Avatar
Rep: 1 (Unique: 1)
I've lowered them now to 1.15 and 1.2 after having read your posts anyways
Okay so they do affect my OC capabilites, I was able to lower the vcore further after having lowered them.
Melodist is offline
post #10 of 10 (permalink) Old 09-05-2019, 02:00 AM - Thread Starter
Melodist's Avatar
Rep: 1 (Unique: 1)
What should I use for Trident Z Pc3200 CL14?
Melodist is offline
