Intel i9-9900KF, BSODs, voltage and fans working overtime - Page 2 - Overclock.net - An Overclocking Community
post #11 of 19 (permalink) Old 01-26-2020, 02:03 PM
Falkentyne's Avatar
Rep: 425 (Unique: 296)
Quote: Originally Posted by PeteJUK View Post
Quick update on this --
The CPU was replaced and the problem still exists.
The only remaining suspect component is the motherboard so will be contacting Asus.
Have you determined that defective RAM or PSU isn't the cause?
I checked your posts and I may have missed something but I didn't see if you tested the memory.
Also, the power supply could be at fault as well, since the PSU is what is supplying the 12v for the vcore.
If the replacement motherboard does not fix the issue, I would look at the PSU first, as well as making sure the the issue persists when testing different RAM or one stick at a time. Good luck.
[email protected] ghz, RX Vega 64, 32GB DDR4, Gigabyte Aorus Master, Seasonic Platinum 1000W, Corsair 760T
Alt: MSI GT73VR Throttlebook with 7820HK @ 4.7 ghz, GTX 1070 MXM TDP mod to 230W, 32 GB RAM
Falkentyne is offline
post #12 of 19 (permalink) Old 01-26-2020, 02:35 PM - Thread Starter
Rep: 0
Hi,
The PSU was the first thing I swapped out as I did wonder if 850W was enough with the 2080Ti. Even with a known working 1000W PSU and a lower spec graphics card I was still crashing. With regards to the RAM sticks I tried all 4 singularly and the still had the hangs and BSODs. I strongly do suspect it's something to do with the voltage regulator on the motherboard. I'll take some screenshots of the bios values in case there is something obvious I've missed.
PeteJUK is offline
post #13 of 19 (permalink) Old 01-26-2020, 02:42 PM
Falkentyne's Avatar
Hi,
Sounds like you did your homework. Please let us know if the new board fixes the problem.
post #14 of 19 (permalink) Old 01-26-2020, 03:26 PM - Thread Starter
Rep: 0
I've also taken some screenshots of the bios settings. If I've missed any particular settings that may be of interest then please let me know.
PeteJUK is offline
post #15 of 19 (permalink) Old 01-29-2020, 10:33 AM
Rep: 51 (Unique: 47)
This may be a dumb question but I'm just doing guess work. Is your DRAM voltage at 1.2V ?? Have you enabled XMP at any point and made sure it was set to 1.35V which is what I find when googling that RAM.
batman900 is offline
post #16 of 19 (permalink) Old 01-29-2020, 10:41 AM
9 Cans of Ravioli
The Pook's Avatar
Rep: 1268 (Unique: 689)
he's not using XMP going by his screenshot, and 1.2v at 2133 is the JEDEC spec for DDR4. it should be fine.
wouldn't hurt to bump up voltage and try but I wouldn't expect it to actually help, and going by OP's post a few up from yours I'm pretty sure he already tried that.
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 32GB
Mushkin Pilot NVMe 1TB
HP EX950 NVMe 2TB
Samsung 860 Evo 1TB
Toshiba X300 5TB
Western Digital EZRZ 3TB
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Raijintek Morpheus II
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU 27" 1440p
LG 24UD58 24" 4K
Keyboard
CoolerMaster MasterKeys Pro S
Mouse
Logitech G502
Mouse
Glorious Model D
Audio
Klipsch PowerGate + FiiO E10K
Audio
Micca RB42
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston 8GB DDR4 2400
Dierka K1 120GB
ADATA SU800 128GB M.2
Operating System
Windows 10 Professional
Operating System
MX Linux
Keyboard
Dierya DK63-BT 60% (Outemu Blue)
Mouse
Logitech G603 Wireless
i7 860
Advantech AIMB 280 ITX
EVGA GTX 950 2GB
Kingston 2GB DDR3 1333
Seagate Momentus 2.5" 500GB
Western Digital Blue 2.5" 320GB
Silverstone SFX-L Gold 500w
Arctic Alpine 11 GT 2
Silverstone Milo Z ML07B
Operating System
Windows XP x86 SP3
Keyboard
Velocifire TKL01 Outemu Browns
Mouse
Logitech M512
The Pook is offline
post #17 of 19 (permalink) Old 01-29-2020, 10:55 AM
Bad5ector's Avatar
Rep: 13 (Unique: 10)
Sorry at work and quickly skimmed so apologies if already mentioned. But I would look at the RAM myself. Have done your troubleshooting steps with the RAM yet? like try single stick in slot A for a bit and then slowly start to add. If it comes back right away try another slot. If the problem still exists try a different chip. And so on. Divide and conquer!!
GOod luck
ShadowMoses
(21 items)
i7 7700K
ASUS ROG Maximus IX Formula LGA1151
EVGA GeForce GTX 1080 Ti Founders Edition
Corsair Vengenace Lpx 32GB DDR4 3200MHZ
Seagate ST1000DX001 SSHD 1TB 3.5in SATA3 64MB Cache Internal Solid State Hybrid Drive
Kingston HyperX Predator 240GB
EVGA SuperNOVA 1000 G1 80 Plus Gold Certified 1000W Fully Modular
RAD - EK-CoolStream XE 360
CPU Block - EK-Supremacy EVO - Nickel
GPU Block - EK-FC Titan X Pascal - Nickel
Pump / Res - EK-XRES 140 Revo D5 PWM (incl. sleeved pump)
Fans - 3 x EK-Vardar F4-120ER (2200rpm)
Coolant - EK-Ekoolant Pastel BLUE (concentrate 250mL)
Tubing - EK-DuraClear 11,1/15,9mm
Thermaltake Core P3 SE Snow Edition
Operating System
Microsoft Windows 10 Pro 64Bit
BenQ XL2720Z 27in LED 144HZ 1ms GTG FPS Gaming Monitor
42" LG TV
Keyboard
Corsair Gaming K65 Lux RGB Compact Mechanical Keyboard
Mouse
Corsair Gaming M65 Pro RGB Optical Gaming Mouse
Mouse
Corsair Gaming MM300
Bad5ector is offline
post #18 of 19 (permalink) Old 01-29-2020, 10:57 AM
Gotcha, my Asus board set my RAM to similar voltage and MHz when I first booted it up with a new 9900kf and I had a couple bsod until I changed it. Could have been some other timings it was changing until I enabled XMP also.
post #19 of 19 (permalink) Old 01-31-2020, 02:37 PM - Thread Starter
Rep: 0
Update --
I contacted Asus support who suggested doing a CMOS reset. I disconnected the power from the PSU, pulled out the CMOS battery for a good 15 minutes and held the power button for a minute to completely discharge the system. After placing the CMOS battery back in and plugging in the PSU I was then advised to change the following settings in the BIOS:
- BIOS > Advanced Menu > APM Configuration > ERP Ready: Enabled S4 + S5
- Restore AC Power Loss: Last State
After booting the system was stable. I ran the stress test from the Extreme Tuning Utility, Passmark BurnIn Test (with 100% load on CPU and RAM), and Prime 95's torture test. Albeit I let the tests run for about 15-20 minutes, but the system didn't crash; previously just being idle would just crash/BSOD. During the tests the ASUS AI Suite reported a CPU frequency of about 4.3GHz and the voltage fluctuated between 0.8 and 1.252 with an average CPU temperature of ~65c.
Feeling brave and confident (and perhaps a bit optimistic) I cranked up the CPU ratio to 50 (x100BC) on all cores. Again, I was stable running the same tests for about 15-20 minutes. The voltage was between 1.1225 and 1.341 and average CPU temperature was ~70c (Peak 80c). Again the system was stable.
I've also now enabled XMP for 3733MHz speeds from the memory to go with the 5GHz CPU speed and I'm stable. CPU temperatures are reasonable, ~70c, (peak 82c) during the same stress tests.
So it seems the reset of the CMOS seems to have done the trick. I can only presume the stock BIOS version screwed things up and a later fixed BIOS was unable to detect/rectify the problems in CMOS from a previous version.
The other settings (ERP and Restore AC Power Loss) feel innocuous.
Just wondering if anyone has any further thoughts?
PeteJUK is offline
