I7-6700K OC Custom Waterloop Heat Problems - Page 2 - Overclock.net - An Overclocking Community
post #11 of 19 (permalink) Old 02-07-2020, 10:59 AM
Not a Linux Lobbyist
Sedril's Avatar
Rep: 2 (Unique: 2)
It's really too bad Intel doesn't sell a version of the CPU that doesn't have an IHS installed... For enthusiasts that either want direct die or custom IHS..... The 7700k was easy, but I don't want to risk my 9900k with the solder...
Apex
(14 items)
i9 9900k
ASUS ROG Maximus XI Apex
EVGA RTX 2080 Super FTW3 HydroCopper
G.Skill TridentZ DDR4 16gb 4133
Samsung 970 Pro m.2 512GB
Samsung M.2 960 Evo 1tb
Western Digital Black
EVGA 1200 P2
Custom water
Thermaltake Core X9
Operating System
Windows 10 Pro X64
LG 27" Ultra HD 4k
Keyboard
Microsoft Natural Ergonomic
Mouse
Logitech G900
Sedril is offline
post #12 of 19 (permalink) Old 02-07-2020, 01:50 PM
hazed is lazed
eminded1's Avatar
Rep: 4 (Unique: 4)
that's all you need is the tool but you gota make sure its made for 9th gen intel, you can also use that compound it sinks into the solder and you can wipe it away and polish it with flitz polish it will come out shiny silicon every time, the PCB is a lot thicker on the 9900k then previous it makes it less of a risk of damaging the pcb on past cpus. its about 3 times as thick. you couldn't direct die with older cpus because there so small the die wouldn't reach the waterblock.
haze is lazed
eminded1 is offline
post #13 of 19 (permalink) Old 02-10-2020, 06:42 PM - Thread Starter
Rep: 0
i was able to get to 4.9Ghz at 1.465V set to adaptive+offset voltage
Temps stay under 70C most of the time using prime 95, aida 64, etc
I feel pretty good at leaving it at that, i tried 5Ghz but even 1.51V wasnt enough to keep it stable, so i stopped trying, even though heat wasnt an issue.
I got my GTX 1080TI Founders edition OC +175 on core and +685 on the Memory(might push it a bit higher)
I think if i use the method where you adjust the frequency with the gpu voltage i could squeeze a bit more out of it.
Im testing the system for a few days before overclocking my memory!
Enterprise12 is offline
post #14 of 19 (permalink) Old 02-10-2020, 06:46 PM
9 Cans of Ravioli
The Pook's Avatar
Rep: 1268 (Unique: 689)
your CPU isn't going to last at that voltage.
remind me not to buy any PC parts from you, lol.
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 32GB
Mushkin Pilot NVMe 1TB
HP EX950 NVMe 2TB
Samsung 860 Evo 1TB
Toshiba X300 5TB
Western Digital EZRZ 3TB
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Raijintek Morpheus II
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU 27" 1440p
LG 24UD58 24" 4K
Keyboard
CoolerMaster MasterKeys Pro S
Mouse
Logitech G502
Mouse
Glorious Model D
Audio
Klipsch PowerGate + FiiO E10K
Audio
Micca RB42
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston 8GB DDR4 2400
Dierka K1 120GB
ADATA SU800 128GB M.2
Operating System
Windows 10 Professional
Operating System
MX Linux
Keyboard
Dierya DK63-BT 60% (Outemu Blue)
Mouse
Logitech G603 Wireless
i7 860
Advantech AIMB 280 ITX
EVGA GTX 950 2GB
Kingston 2GB DDR3 1333
Seagate Momentus 2.5" 500GB
Western Digital Blue 2.5" 320GB
Silverstone SFX-L Gold 500w
Arctic Alpine 11 GT 2
Silverstone Milo Z ML07B
Operating System
Windows XP x86 SP3
Keyboard
Velocifire TKL01 Outemu Browns
Mouse
Logitech M512
The Pook is offline
post #15 of 19 (permalink) Old 02-10-2020, 07:01 PM - Thread Starter
Rep: 0
What voltage would you recommend? i know higher voltage degrades the cpu over time, but i heard 1.45 is pretty safe, this voltage isnt much higher as it sits at 1.46 on load and during low load it clocks down the cpu and voltage
post #16 of 19 (permalink) Old 02-10-2020, 07:12 PM
9 Cans of Ravioli
The Pook's Avatar
the same voltage I said in post #5
if you would be upset if your CPU degrades any amount, cap it at 1.4v. Short suicide runs where you open CPU-Z save a validation and don't put a load on it is fine at 1.45v but you likely already did some damage if you booted at 1.51v and tried to run Prime95 lol.
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
HP EX950 NVMe 2TB
Samsung 860 Evo 1TB
Toshiba X300 5TB
Corsair H115i Pro
Operating System
LG 24UD58 24" 4K
Keyboard
Mouse
Logitech G502
Mouse
Glorious Model D
Audio
Audio
Micca RB42
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Dierka K1 120GB
Operating System
Operating System
MX Linux
Keyboard
Mouse
i7 860
EVGA GTX 950 2GB
Operating System
Windows XP x86 SP3
Keyboard
Mouse
Logitech M512
The Pook is offline
post #17 of 19 (permalink) Old 02-10-2020, 08:07 PM - Thread Starter
Rep: 0
I never got it to boot at 1.51 so i didnt run any tests at that voltage, i imagine id be replacing this cpu within 2-3 years, as its starting to show its age a bit as is now, i might continue at this voltage, ive read dozens of forum posts with some people saying they run at a high voltage fine for a few years, and others saying not to but without experience in doing so, so may as well find out myself so i know in the future with a newer cpu what is safe and not.
If over time i have to lower the overclock, thats fine.
Is it worth overclocking the Ring Ratio?
post #18 of 19 (permalink) Old 02-14-2020, 07:05 PM - Thread Starter
Rep: 0
Anyone? does overclocking the ring ratio provide any gaming performance benefit?
Also the finished product!
post #19 of 19 (permalink) Old 02-14-2020, 08:59 PM
8051's Avatar
Rep: 27 (Unique: 21)
As far as overclocking the uncore, this video showed it can make a difference going from 4.0 to 4.8 Ghz.:
https://www.youtube.com/watch?time_c...ature=emb_logo
8051 is offline
