i7-2600k + Asus P8Z68-V LX Overclock need help - Page 3 - Overclock.net - An Overclocking Community
post #21 of 69 (permalink) Old 02-13-2020, 08:27 AM
PC Gamer
oxidized's Avatar
Rep: 26 (Unique: 24)
Quote: Originally Posted by shilka View Post
100mv of ripple is normal and wont have an effect on overclocking? that is simply untrue
The best units around today are doing 5mv on all the rails and you are hard pressed to find anything doing worse than 50mv today so 100mv is just plain horrible
You really should read this but i will quote if you cant be bothered to read it all
https://www.overclock.net/forum/31-p...rclocking.html
Start of quote
Ripple is measured as a peak-to-peak value in milivolts, and is measured using an oscilloscope (software can not detect ripple, nor can a multimeter or voltmeter; you need an oscilloscope with a scanning frequency of at least 30MHz). The ATX specification sets these limits on computer PSU ripple levels:
+12V - 120mV
+5V - 50mV
+3.3V - 50mV
+5VSB - 120mV
-12 - 120mV
My personal preference is to see numbers in or under this range:
+12V - 80mV
+5V - 30mV
+3.3V - 30mV
+5VSB - 50mV
-12V - 80mV
Any power supply which has ripple outside of those proscribed by the ATX specifications can and will cause short term hardware damage (over a period of days to months, depending). Anything outside of my preferences may cause long-term reliability degradation and other issues, though it won't damage your hardware in the short term.
End of quote
The PSU in the OP is rubbish thats simply stating a fact
I agree with your preferences, but they don't make this PSU rubbish, it's probably just subpar, but this won't cause him problems of any sort, and since i don't think that PC is new, i guess it's been working for a while without problems, a little overclocking won't make the system unstable because ripple of his PSU under HEAVY load is subpar, come on you know this too, you're just being picky.
oxidized is offline
post #22 of 69 (permalink) Old 02-13-2020, 09:15 AM - Thread Starter
Rep: 0
~ 5 years working (without overclocking)
Olga-v is offline
post #23 of 69 (permalink) Old 02-13-2020, 09:19 AM
professional curmudgeon
looniam's Avatar
Rep: 810 (Unique: 457)
Quote: Originally Posted by Olga-v View Post
х44 (+0.040) (LLC Auto) – prime95 stopped working error
х44 (+0.050) (LLC Auto) – prime95 stopped working error
х44 (+0.060) (LLC Auto) – prime95 crash BSoD
х44 (+0.065) (LLC Auto) – prime95 stopped working error
х44 (+0.070) (LLC Auto) – prime95 stopped working error
*(+0.060 \ 0.065 \ 0.070 = 1.336v prime95)
LLC Enable - does not work, voltage does not display correctly (1.328 program monitoring = 1.357 real) i can't use it..
x43 (+0.040) (LLC Disable) - 29 min (best result) stopped working error
I can’t replace PSU, but I can remove the video card for testing cpu overclock, this help?
you may not want LLC but you need LLC and auto is not the way. if it wasn't explained to you; LLC adds a small (depending on setting) amount of voltage when the cpu is under a heavy load because the voltage will drop (or droop) a little. that's a characteristic of electricity.
sure you can just increase the (base) voltage to where its stability under a heavy load but then you're over-volting the chip when light or idle loads.
also get off offset mode and switch to manual when looking to find the stable voltage. you can switch back to offset once you find it, but in the meantime it will cause you to pull your hair out being stable one test but not another.
go manual with LLC on high (or maybe start medium) just mind the max voltage reading you get doesn't go over 1.38 if setting 1.35 as an example. thats pretty much written in every sandy/ive bridge OCing guide.
offset with no LLC is sending all sorts of voltages to the chip when under load causing it to fail. you want steady voltage when finding the best stability.
Remember the golden rule of statistics: A personal sample size of one is a sufficient basis upon which to draw universal conclusions.
Upload the computer to Dropbox and provide a link to it so others may download it to examine and give advice for repairs.
loon 3.2
(18 items)
i7-3770K
Asus P8Z77-V Pro
EVGA 980TI SC+
16Gb PNY ddr3 1866
PNY 1311 240Gb
1 TB Seagate
3 TB WD Blue
Optical Drive
DVD DVDRW+/-
EVGA SuperNova 750 G2
EKWB P280 kit
EK-VGA supremacy
Stryker M [hammered and drilled]
Operating System
Win X
LG 24MC57HQ-P
Keyboard
Ducky Zero [blues]
Mouse
corsair M65
Audio
SB Recon3D
Audio
Klipsch ProMedia 2.1
looniam is offline
post #24 of 69 (permalink) Old 02-13-2020, 10:08 AM - Thread Starter
Rep: 0
There is a problem
no «manual» , only «+» and «-»
LLC – no «high» \ «medium», only «auto» \ « enable» \ «disable»
I read what 's on this motherboard LLC not working properly
auto=disable, enable - very very high voltage (4 MHz – 1.357 v) + displayed incorrectly
https://web-shpargalka.ru/asus-p8z68-v-lx-razgon.php
at the moment I have
х43 (+0.045) (DDR3 1600) (LLC Disable)
prime95 – 2 hours– ok (max 1.312 v \ max 70 C)
LinX 0.6.4 – 10 min test – ok (280 v \ 69 С)
AIDA64 cpu test 2 min – 1.312 v 58 C
AIDA64 fpu test 2 min – 1.288 v 69 C
but i noticed when AIDA64 Cahe & Memory Benchmark – checks L1 Cache - I have 1.344 V
my settings unsafe? Would it be better not to overlocking? I can 't risk this computer
Thank you!
Name:	LinX 0.6.4.jpg
Name:	prime95 - 2 часа тест ок.jpg
Olga-v is offline
post #25 of 69 (permalink) Old 02-13-2020, 12:20 PM
High IQ Person
DAM20's Avatar
Rep: 1 (Unique: 1)
Well, the mobo is trash for oc :/
Yeetus
(10 items)
Brother's heater
(10 items)
Ryzen 2700X (10x -0.106)
Crosshair VII Hero (WiFi)
Sapphire RX 5700XT Nitro+ SE
G.Skill 3466 C14
Crucial P1
Seagate Barracuda
XFX XTR P1-750B-BEFX
NH-D15 AM4
Dark Base 900 Pro
Operating System
Windows 10 Pro
Ryzen 2600X (10x -0.05)
ROG STRIX X470-F GAMING
XFX RX480 GTR (580 BIOS) 1430/2020
Corsair Vengeance LPX 3200Mhz
Crucial P1
Seagate Barracuda
ANTEC HCG-750-GOLD
Corsair H100i
NZXT H510i
Operating System
Windows 10 Pro
DAM20 is offline
post #26 of 69 (permalink) Old 02-13-2020, 12:30 PM
Rep: 66 (Unique: 61)
Dude questioning shilka on his PSU knowledge. SMH
OP you wanna get Prime95 stable or daily stable? In my second system I'm running a 2600k 5ghz @ 1.44v and I didn't Prime95 it... just Handbrake. During the encode of Handbrake it bluescreen at 1.40v. 1.425v Handbrake would stop at around 1 hour.... Progress? 1.41-1.44v it passed 5+ hours of encoding so I just rolled with that. Never bluescreened once during the 5+ years of having it there.
I would overclock the memory and tighten the timings. You'll get better performance from that, rather than worrying about 100-200mhz more. I have crappy sticks this is the best they could do.
boot318 is offline
post #27 of 69 (permalink) Old 02-13-2020, 12:40 PM
Schmuckley's Avatar
Rep: 705 (Unique: 564)
Are you trolling?
R U Srs?
There was a guy b4 Shilka, but Shilka knows his stuff. Who are you? Hmm? Sup?
Schmuckley is online now
post #28 of 69 (permalink) Old 02-13-2020, 01:01 PM
Schmuckley's Avatar
Set 1.4v solid and see how high you can OC.
or 1.28 if you want chip longevity.
Dadgum, that's some old stuff these days.
http://valid.canardpc.com/show_oc.php?id=2284794
post #29 of 69 (permalink) Old 02-13-2020, 01:06 PM
Schmuckley's Avatar
A) Cannot mess with Bclck on Sandy Bridge.
B) Multi and voltage you can.
Somebody once said : "Even a monkey can OC Sandy Bridge."
I've done SB/IB Sb/E, IB/E, that worked for a while. X79.
Same RAM, decent chips, these days an X1650-70 V2 is pretty cheap. The boards are hit or miss, though.
Fairly stable platform.
P8z68 was in between p67 and Ivy Bridge and kinda wonky.
post #30 of 69 (permalink) Old 02-13-2020, 02:33 PM
looniam's Avatar
There is a problem
Spoiler!
ah! i see now. sorry i did not see in your other post w/screen shots of bios.
mine (p8z77-v pro) has:
Spoiler!
to explain myself, i thought you had the z68 -v (no lx even though its in the title ) ((edit) the asus v, v pro and sabertooth for z68/77 chipsets all have about the same bios settings)
so yes, it's different and then i can't give you the best advice for your bios, sorry. i did do a quick google for a review of your board:
The AI Tweaker panel is the main section for overclocking. With a decent air cooler, 4.6ghz was easily achievable from this motherboard @ 1.42 volts. More should be possible with improved cooling, however the hard core audience are likely to invest more on a high end motherboard, specifically just for overclocking.
i don't know what temps that was at but but w/4+2 power phases i'd think of ~1.45v as the limit of the board though most any sandy bridge chip can handle 1.50-1.55 under 85c.
i still will suggest LLC on medium if not high. english is my only language; i used translate (chrome) to read the link. i see they mention disabled but i will insist that one person settings does not mean everyone. maybe disabled it could work for you but i'm sure most people it won't.
but most of all, have fun (?)
loon 3.2
(18 items)
i7-3770K
Asus P8Z77-V Pro
EVGA 980TI SC+
16Gb PNY ddr3 1866
PNY 1311 240Gb
1 TB Seagate
3 TB WD Blue
Optical Drive
DVD DVDRW+/-
EKWB P280 kit
EK-VGA supremacy
Operating System
Win X
LG 24MC57HQ-P
Keyboard
Ducky Zero [blues]
Mouse
corsair M65
Audio
SB Recon3D
Audio
looniam is offline
