i7-2600k + Asus P8Z68-V LX Overclock need help - Page 6 - Overclock.net - An Overclocking Community
post #51 of 69 (permalink) Old 02-14-2020, 08:54 AM - Thread Starter
Rep: 0
Quote: Originally Posted by mattliston View Post
olga-v, lease change the following 2 settings and retest.
VCCIO voltage - change from default 1.05 to 1.15 volts
DRAM voltage - change from default 1.50 to 1.55 volts.
Retest.
When you make your cpu faster, things that TALK to the cpu can get unstable, because of the extra speed.
If the retest fails, one more thing to try. Find memory dram settings, find the command rate setting, this will have a value of 1, 2, or 3. if running value of 1T (or sometimes 1N), change it to 2. This will cause a MINOR memory performance reduction (not noticable) but will help system stability.
Thanks! I will try it!
What about other settings? LLC –Desible? х44? Offset CPU Voltage - +0.045?
*have a value 2
Olga-v is offline
post #52 of 69 (permalink) Old 02-14-2020, 09:04 AM - Thread Starter
Rep: 0
sorry for my english i use google translator
«ASUS P8Z68-V LX» – doesn't have «LLC 1/ 2/ 3» or «medium/ high», only «auto /enable / disable» - no other options.
(please see the photo)
It's not a problem but if i choose «LLC – enable» - I will not see the real Vcore voltage, because this motherboard displays Vcore voltage incorrectly when selected «LLC – enable» («auto \ disable» - displayed Vcore voltage correctly)
Here is an example from one of the reviews ASUS P8Z68-V LX that I found:
In 4 GHz programmed monitoring displays - 1.328v but multimeter (Mastech MY64) displays - 1.357v
In 4.8 GHz programmed monitoring displays - 1.456v but multimeter (Mastech MY64) displays - 1.488v
*I do not have a multimeter, I look at this review https://web-shpargalka.ru/asus-p8z68-v-lx-razgon.php
I think I just need to know when i choose «LLC – enable» that in reality I will have ~0.030v more than I see in cpu-z / HWiNFO64.
«ASUS P8Z68-V LX» set processor voltage only in offset mode. + I have settings VCCIO Voltage and PCH Voltage (I don't know if they work) nothing else..
I try these settings
х43 (+0.045) (DDR3 1600) (LLC Disable)
these are the first settings that did not give an error in prime95 for two hours
prime95 – 2 hours– ok (max 1.312 v \ max 70 C)
LinX 0.6.4 – 10 min test – ok (280 v \ 69 С)
AIDA64 cpu test 2 min – 1.312 v 58 C
AIDA64 fpu test 2 min – 1.288 v 69 C
but i noticed when AIDA64 Cahe & Memory Benchmark – checks L1 Cache - I have 1.344 V
I tried DDR3 - 1866 and timings 11-11-11-28 (but the bios automatically replaced 28 to auto) but I get the first error after 10 minutes in the prime95. I have not tried other settings, because i don't understand anything about timings. I tried only 11-11-11-28.
*for fun I changed Offset CPU Voltage +0.045 to +0.065 test prime95 complete 25min test without errors. I think Offset CPU Voltage affects the memory or this is a coincidence…
1300 timings
1600 timings
1866 timings
Olga-v is offline
post #53 of 69 (permalink) Old 02-14-2020, 09:26 AM
Schmuckley's Avatar
Rep: 705 (Unique: 564)
Quote: Originally Posted by Olga-v View Post
I can set vcore only from offset.. use it to get 1.5 or less?
and i don't have LLC 2 ...
Sorry, I don't understand, do I need instal the latest BIOS? this should give me new options for LLC?
I never updated the bios but i can try if that should help
Load Line Calibration..enable it and set to 2.
With a proper setting, the vcore will droop by .02
Pretty sure you want to keep the temps under 80-ish.
Sandy Bridge has multiplier holes, too. So if 1 fails, try the next one up, just in case..
Schmuckley is offline
post #54 of 69 (permalink) Old 02-14-2020, 09:36 AM - Thread Starter
Rep: 0
sorry, I do not understand
enable - ok
but where i should "set to 2"?
Olga-v is offline
post #55 of 69 (permalink) Old 02-14-2020, 09:58 AM
professional curmudgeon
looniam's Avatar
Rep: 810 (Unique: 457)
Attachment 326684
Attachment 326686
Attachment 326688
hi again
i read that in the link (translated in chrome) and it isn't wrong or bad but i think you're looking at it wrong. i also think you're using too many benchmarks and software readings. pick one and stick with that; different software will give different readings making you pull your hair out. so maybe leave aida64 alone for now(?)
but getting back to LLC. i get you have only disable/enable. if you look you think you get 0.030v more with LLC but look, even disabled you get 0.025v so it only gives 0.005v more when under load. the chip won't need any extra voltage at lower loads. so what you do is subtract the 0.005v from the +offset so use 0.040v instead of 0.045v.
i hope that makes sense and you'll think about experimenting with my suggestion.
and leave the ram alone for now. those voltages are separate (the system agent on the chip for the IMC and dram voltage for the ram). but some lower end motherboards do "tie in" or connect some voltages that are separate on higher end boards but Vcore for the chip is just the chip.
good luck
Remember the golden rule of statistics: A personal sample size of one is a sufficient basis upon which to draw universal conclusions.
Upload the computer to Dropbox and provide a link to it so others may download it to examine and give advice for repairs.
loon 3.2
(18 items)
i7-3770K
Asus P8Z77-V Pro
EVGA 980TI SC+
16Gb PNY ddr3 1866
PNY 1311 240Gb
1 TB Seagate
3 TB WD Blue
Optical Drive
DVD DVDRW+/-
EVGA SuperNova 750 G2
EKWB P280 kit
EK-VGA supremacy
Stryker M [hammered and drilled]
Operating System
Win X
LG 24MC57HQ-P
Keyboard
Ducky Zero [blues]
Mouse
corsair M65
Audio
SB Recon3D
Audio
Klipsch ProMedia 2.1
looniam is offline
post #56 of 69 (permalink) Old 02-14-2020, 10:08 AM
Schmuckley's Avatar
You also need to enable internal PLL voltage to clock higher. Pretty sure you can set the amount and get higher clocks like that.
LLC can be left disabled, just let the chip vdroop to where it does.
I did that especially with 1366, because LLC adds heat.
You may have to set vcore a bit higher.
post #57 of 69 (permalink) Old 02-14-2020, 07:54 PM - Thread Starter
Rep: 0
Quote: Originally Posted by looniam View Post
hi again
good luck
hi
Thanks!
i tried this;
LLC - Enable
x44
offset - (not +)
-0.020
Prime95 - 40 min ok (need to try again)
I got maximum 74 С
but if i use DDR3 - 1866 (10-10-10-26) i get an error in Prime95
Olga-v is offline
post #58 of 69 (permalink) Old 02-14-2020, 08:08 PM - Thread Starter
Rep: 0
Thanks!
internal PLL is needed for 1866 MHz?
i tried 11-11-11-28 but getting Prime95 error anyway
I also tried DRAM voltage - 1.55v but getting Prime95 error anyway...
*with 1600 (1.50v -auto) and auto timings no errors in Prime95
Olga-v is offline
post #59 of 69 (permalink) Old 02-15-2020, 03:18 AM
High IQ Person
DAM20's Avatar
Rep: 1 (Unique: 1)
Try 10 12 11 29 40 2133 1.5v
Yeetus
(10 items)
Brother's heater
(10 items)
Ryzen 2700X (10x -0.106)
Crosshair VII Hero (WiFi)
Sapphire RX 5700XT Nitro+ SE
G.Skill 3466 C14
Crucial P1
Seagate Barracuda
XFX XTR P1-750B-BEFX
NH-D15 AM4
Dark Base 900 Pro
Operating System
Windows 10 Pro
Ryzen 2600X (10x -0.05)
ROG STRIX X470-F GAMING
XFX RX480 GTR (580 BIOS) 1430/2020
Corsair Vengeance LPX 3200Mhz
Crucial P1
Seagate Barracuda
ANTEC HCG-750-GOLD
Corsair H100i
NZXT H510i
Operating System
Windows 10 Pro
DAM20 is offline
post #60 of 69 (permalink) Old 02-15-2020, 03:40 AM - Thread Starter
Rep: 0
ok,
Thanks!
DRAM CAS# Latensy - 10
DRAM RAS# to CAS# - 12
DRAM RAS# PRE Time - 11
DRAM RAS# ACT Time - 29
I can not understand where to write 40?)
Olga-v is offline
