9900K Overclock/Temps help - Page 2 - Overclock.net - An Overclocking Community
post #11 of 36 (permalink) Old 05-19-2020, 11:19 AM - Thread Starter
Rep: 0
Quote: Originally Posted by Shawnb99 View Post
Can't hurt. If don't want to go direct die you could delid and then get the Rockit IHS. Flatter and better then Intel's.
I read that re-lid for soldered chips as 9900K doesn't yield meaningful improvements, compared to previous gen chips such as 8700k where they had paste as tim between IHS and the die.
I would go direct die if I choose to remove the IHS.
Vivid Violet
(14 items)
9900k
Gigabyte Aorus Master z390
Asus GTX 1070 Strix
Gskill TridentZ Neo
Samsung 970 Evo+
EVGA G2
EK Velocity CPU block
EK XE 360
EK PE 360
O11D Distro Plate
DDC 3.1 PWM (impeller from 3.25)
LianLi O11 Dynamic XL
LG GN 750B
Audio
AudioTechnica ATH-M50
Hawkjoss is offline
post #12 of 36 (permalink) Old 05-19-2020, 11:29 AM
Shawnb99's Avatar
Rep: 55 (Unique: 36)
Yeah I would as well. If you're delidding, direct die is the next step. IHS can be put back on when reselling.
Even delid doesn't offer that great of a temp difference compared to previous gen but any bit helps, specially when these things like to reach these high temps.
My Baby
(23 items)
Delidded Direct Die I9 9900K
ASUS Maximus XI Apex
EVGA FTW3 Hydro Copper GeForce RTX 2080 Ti
G.SKILL TridentZ Series 16GB DDR4 3600 F4-3600C15D-16GTZ
2x Samsung 970 EVO Plus 1TB
Asus Hyper M.2 card
2 x Intel 660P 2TB
Seasonic PRIME Ultra 1000 Titanium
Optimus Signature V2
2x Swiftech MCP35X2 with MCP35X2 Heat Sink w/ 2x NB-BlackSilent Pro's
2x Hardware Labs Black Ice Nemesis 560GTX w/ 8x Arctic P14 PST PWM's
2x Hardware Labs Black Ice Nemesis 480GTX w/ 16x Noctua NF-A12x25 PWM
Aquacomputer aqualis XT 450 ml with nano coating
9x Noctua NF-S12A PWM
Hardware Labs Black Ice Nemesis 360GTS w/ 6 Arctic P12 PST PWM's
Case Labs Magnum TH10A with Pedestal
Asus PG278Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Light Harmonic Oscar XXI
Audio
Geek Pulse Inifnity DAC/AMP
Audio
Cavalii Audio Liquid Carbon HPA
Other
Aquacomputer Aquaero XT
Shawnb99 is offline
post #13 of 36 (permalink) Old 05-19-2020, 11:30 AM
Nvidia Enthusiast
philhalo66's Avatar
Rep: 270 (Unique: 211)
Those temps look right, 9900k is a poorly engineered chip. The package was designed for 6 cores not 8 so it runs insanely hot even with an open loop. i have a 360MM EVGA AIO on mine and at 5GHz 1.31V im pushing close to 90C in prime95 so your are about right. It's just a really hot chip there isnt much you can do aside from deliding and sanding down the silicon.
gaming rig
(18 items)
Intel Core i9 9900K 5GHz 1.3V
GIGABYTE Z390 AORUS PRO
EVGA RTX 2080 Ti FTW3 Ultra Hybrid
G.SKILL Ripjaws V DDR4 3600MHz 32GB
HGST 2TB
Seagate 2.5 Inch 2TB
Samsung 860 EVO 1TB
Intel 660p NVME 512GB
Optical Drive
LG Blu Ray drive
Corsair RM850i 850W
EVGA CLC 360MM Corsair LL120
Corsair Graphite 780T White
Operating System
windows 10 Pro
MSI OPTIX MAG24C
Acer XFA240 bmjdpr
Keyboard
G.SKILL RIPJAWS KM780 MX
Mouse
Razer Deathadder Elite
Audio
Sound Blaster Z
philhalo66 is online now
post #14 of 36 (permalink) Old 05-19-2020, 11:35 AM - Thread Starter
Rep: 0
Which version of P95 you are running? do you have any AVX offset?
if it is P95 AVX without AVX offset your cooling doing way better then mine, so it is definitely something wrong with my setup
Vivid Violet
(14 items)
9900k
Asus GTX 1070 Strix
Gskill TridentZ Neo
Samsung 970 Evo+
EVGA G2
EK XE 360
EK PE 360
O11D Distro Plate
LG GN 750B
Audio
Hawkjoss is offline
post #15 of 36 (permalink) Old 05-19-2020, 11:36 AM
Darkseid1979's Avatar
Rep: 1 (Unique: 1)
I lost 15°c with delid, direct die+LM (conductonaut)
I used the rockit delid tool. I wanted to heat the IHS with hair dryer (I dont have heatgun) but it went into safety after 10s so I decided to delid without it. It was very easy and remove the TIM with solder remover also
I also use Ek velocity, no problem for contact even with washer.
Darkseid1979 is offline
post #16 of 36 (permalink) Old 05-19-2020, 11:44 AM - Thread Starter
Rep: 0
Nice, Darkseid1979! it is a solid improvement!
I'm trying to figure out if it is the max cooling capacity I have OR I did something wrong with OC/mounting. If the results I posted are the best I can get with current hardware/settings, I will go for direct die.
What were your temps before d-die?
Vivid Violet
(14 items)
9900k
Asus GTX 1070 Strix
Gskill TridentZ Neo
Samsung 970 Evo+
EVGA G2
EK XE 360
EK PE 360
O11D Distro Plate
LG GN 750B
Audio
Hawkjoss is offline
post #17 of 36 (permalink) Old 05-19-2020, 12:00 PM
Rep: 1 (Unique: 1)
To put on perspective I'm on apex XI, 9900ks and 2x8 Go 4500 1T 17 19 39 with tights sub timings so I need a little more voltage to stabilize (0.02v)
So for 5.1 avx -1 I needed 1.315v LLC5. Prime95avx2 Smallfft (2h) push 240w and temp was 85°(88 in peak)
After delid I was at 68° but I don't let Prime95 for long time (because I previously passed the test)
Now I'm at 5.2 avx -1 with 1.355v Prime95 smallfft non avx 71° (2h 200w & 74° in peak) / avx2 76° (2h 253w & 81° in peak)
post #18 of 36 (permalink) Old 05-19-2020, 12:50 PM
Nvidia Enthusiast
philhalo66's Avatar
I used prime95 26.6 and i used the settings der8auer suggested for testing stability. I disabled AVX offset because it kept underclocking to 4.7Ghz i just run full 5GHz.
gaming rig
(18 items)
HGST 2TB
Samsung 860 EVO 1TB
Optical Drive
LG Blu Ray drive
Corsair RM850i 850W
Operating System
windows 10 Pro
MSI OPTIX MAG24C
Acer XFA240 bmjdpr
Keyboard
Mouse
Audio
Sound Blaster Z
post #19 of 36 (permalink) Old 05-19-2020, 01:25 PM - Thread Starter
Rep: 0
Ran a quick 10 min test on 5.0, P95 26.6, run FFT in-place with size of 12-12 - max temp was 80C with avg 76C on cores
Vivid Violet
(14 items)
9900k
Asus GTX 1070 Strix
Gskill TridentZ Neo
Samsung 970 Evo+
EVGA G2
EK XE 360
EK PE 360
O11D Distro Plate
LG GN 750B
Audio
Hawkjoss is offline
post #20 of 36 (permalink) Old 05-19-2020, 02:15 PM
Just hangin' out
Arctucas's Avatar
Rep: 36 (Unique: 35)
Half hour run. 1.225VCore Adaptive.
Radiator heat dump raised ambient 2.4°C.
Direct die with Conductonaut.
Name:	p95 266 5-19-20.jpg
In no way should it be misconstrued that I do not disagree.
https://valid.x86.fr/52sqs5
PC
(15 items)
9900K
eVGA Z390 DARK
eVGA RTX2080 FTW3 ULTRA
GSKILL F4-4500C19D-16GTZKKE
SAMSUNG 960EVO
Optical Drive
TSSTCORP SH-223L
CORSAIR AX1200
LIANG D5, XSPC DUAL BAY RESERVOIR, HEATKILLER IV PRO NICKEL, THERMOCHILL PA140.3, AEROCOOL 140MM SHARK FANS
THERMALTAKE XASER VI
Operating System
W7 U X64 SP1
LG 32GK650F
Keyboard
LOGITECH
Mouse
LOGITECH
Audio
Auzentech X-Meridian 7.1 2G
Audio
Z-5500
Arctucas is offline
